Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on May 18, 2006, 5:57 pm
Please log in for more thread options running 6.3.3. The clients get authenticated, and connect fine. Onc ethe vpn client tries to go to any machine on the inside (192.168.10.0/24) the following message is generated on the pix: No translation group found for tcp src <vpn ip>
The sanitized conf is below. Any help is appreciated. thanks ############################################# PIX Version 6.3(3) interface ethernet0 100full interface ethernet1 100full interface ethernet2 100full interface ethernet3 100full interface ethernet4 auto shutdown interface ethernet5 auto shutdown nameif ethernet0 outside security0 nameif ethernet1 inside security100 nameif ethernet2 failover security20 nameif ethernet3 dmz security20 nameif ethernet4 e4 security0 nameif ethernet5 e5 security0 enable password ************ encrypted passwd ************ encrypted hostname spix domain-name ******** fixup protocol dns maximum-length 512 fixup protocol domain 53 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 no fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 no fixup protocol skinny 2000 no fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 no names access-list soc2800 permit ip host 216.74.163.199 host 65.197.254.5 access-list soc2800 permit ip host 216.74.163.199 63.108.175.0 255.255.255.0 access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.1 access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.2 access-list inside permit udp 192.168.0.0 255.255.0.0 host 216.74.163.194 eq ntp access-list inside permit udp 192.168.0.0 255.255.0.0 host 216.74.163.195 eq ntp access-list inside permit icmp any any echo access-list inside permit icmp any any unreachable access-list inside permit icmp any any source-quench access-list inside permit icmp any any time-exceeded access-list inside remark ###### allow ftp to ftp.lim.com access-list inside permit tcp 192.168.10.0 255.255.255.0 host 12.43.226.2 eq ftp access-list inside permit tcp host 192.168.10.80 any eq www access-list inside permit tcp host 192.168.10.80 any eq ftp access-list inside permit tcp host 192.168.10.80 any eq https access-list inside permit tcp host 192.168.10.80 any eq ssh access-list inside permit tcp host 192.168.10.80 any eq smtp access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.1 access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.2 access-list inside permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.0.0 access-list inside permit ip 192.168.0.0 255.255.0.0 192.168.0.0 255.255.0.0 access-list inside permit tcp host 192.168.10.80 any eq telnet access-list inside permit tcp host 192.168.10.157 any eq https access-list inside permit tcp host 192.168.10.156 any eq smtp access-list inside permit tcp host 192.168.10.156 any eq https access-list inside permit udp host 192.168.10.156 any eq ntp access-list inside permit udp host 192.168.10.157 any eq ntp access-list inside permit udp host 192.168.10.157 any eq domain access-list inside permit udp host 192.168.10.156 any eq domain access-list inside permit tcp host 192.168.10.157 any eq domain access-list inside permit tcp host 192.168.10.156 any eq domain access-list inside permit tcp host 192.168.10.199 any eq domain access-list inside permit udp host 192.168.10.199 any eq domain access-list inside permit tcp host 192.168.10.197 any eq domain access-list inside permit udp host 192.168.10.197 any eq domain access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 255.255.255.0 eq www access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 255.255.255.0 eq https access-list inside permit tcp 192.168.0.0 255.255.0.0 host 208.173.140.54 eq smtp access-list inside permit tcp host 192.168.10.199 host 192.88.69.69 eq ftp access-list inside permit tcp host 192.168.10.197 host 192.88.69.69 eq ftp access-list inside permit tcp host 192.168.10.185 any eq smtp access-list inside remark ##### allow all machines out to futuresource.com and xml.marketcenter.com on 4004 access-list inside permit tcp 192.168.10.0 255.255.255.0 any eq 4004 access-list inside remark ###### allow specific machines out access-list inside permit tcp host 192.168.10.185 any eq www access-list inside permit tcp host 192.168.10.185 any eq https access-list inside permit tcp host 192.168.10.200 any eq www access-list inside permit tcp host 192.168.10.201 any eq www access-list inside permit tcp host 192.168.10.200 any eq https access-list inside permit tcp host 192.168.10.201 any eq https access-list inside permit tcp host 192.168.10.200 any eq ftp access-list inside permit tcp host 192.168.10.201 any eq ftp access-list inside remark ###### LAN --> border network
access-list inside permit tcp 192.168.10.0 255.255.255.0 216.74.163.192
255.255.255.224 eq telnet access-list inside remark #### allw VPN local pool ips access-list inside permit ip 192.168.0.0 255.255.0.0 172.16.1.0 255.255.255.0 access-list outside permit icmp any any echo-reply access-list outside permit icmp any any unreachable access-list outside permit icmp any any time-exceeded access-list outside permit tcp any host 216.74.163.204 eq https access-list outside permit tcp any host 216.74.163.204 eq www access-list outside permit tcp any host 216.74.163.209 eq www access-list outside permit tcp any host 216.74.163.209 eq https access-list outside permit tcp any host 216.74.163.205 eq www access-list outside permit tcp any host 216.74.163.205 eq https access-list outside permit tcp any host 216.74.163.203 eq www access-list outside permit tcp any host 216.74.163.203 eq https access-list outside permit tcp any host 216.74.163.201 eq www access-list outside permit tcp any host 216.74.163.201 eq https access-list outside permit tcp any host 216.74.146.250 eq www access-list outside remark ###### line 15-22 may be obsolete DSP 2.6.06 access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq ssh access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq 10000 access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq 8888 access-list outside permit esp host 12.146.1.11 host 216.74.146.244 access-list outside permit esp host 12.146.1.11 host 216.74.146.245 access-list outside permit tcp any host 216.74.163.202 eq 24 access-list outside permit tcp any host 216.74.146.244 eq ssh access-list outside permit tcp any host 216.74.146.245 eq ssh access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.10.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.11.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.12.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.13.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.20.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.21.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.22.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.23.0 255.255.255.0 access-list dmz permit udp 216.74.146.240 255.255.255.240 host 216.74.163.194 eq ntp access-list dmz permit udp 216.74.146.240 255.255.255.240 host 216.74.163.195 eq ntp access-list dmz permit icmp any any echo access-list dmz permit icmp any any unreachable access-list dmz permit icmp any any time-exceeded access-list dmz permit tcp host 216.74.146.250 host 24.213.162.100 eq smtp access-list dmz permit tcp host 216.74.146.250 any eq domain access-list dmz permit udp host 216.74.146.250 any eq domain access-list dmz permit tcp host 216.74.146.250 any eq ssh access-list dmz permit udp host 216.74.146.244 host 12.146.1.11 eq isakmp access-list dmz permit udp host 216.74.146.245 host 12.146.1.11 eq isakmp access-list dmz permit esp host 216.74.146.245 host 12.146.1.11 access-list dmz permit esp host 216.74.146.244 host 12.146.1.11 access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq ssh access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq ssh access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq ssh access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq ssh access-list 628broadway permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.0.0 access-list 628broadway permit ip 172.16.1.0 255.255.255.0 192.168.0.0 255.255.0.0 access-list 628broadway permit ip 192.168.0.0 255.255.0.0 172.16.1.0 255.255.255.0 pager lines 24 logging on logging timestamp logging standby logging trap debugging logging history informational logging facility 23 logging device-id hostname logging host outside 63.108.175.80 logging host inside 192.168.10.156 no logging message 302015 no logging message 302014 no logging message 302013 icmp permit any inside mtu outside 1500 mtu inside 1500 mtu failover 1500 mtu dmz 1500 mtu e4 1500 mtu e5 1500 ip address outside x.x.x.x ip address inside 192.168.12.1 255.255.255.0 ip address failover 192.168.14.1 255.255.255.252 ip address dmz x.x.x.x no ip address e4 no ip address e5 ip audit info action alarm ip audit attack action alarm ip local pool vpn 172.16.1.1-172.16.1.100 failover failover timeout 0:00:00 failover poll 15 failover ip address outside x.x.x.x failover ip address inside 192.168.12.2 failover ip address failover 192.168.14.2 failover ip address dmz x.x.x.x no failover ip address e4 no failover ip address e5 failover link failover no pdm history enable arp outside x.x.x.x 0000.0c07.ac00 alias arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list 628broadway nat (inside) 1 192.168.10.0 255.255.255.0 0 0 nat (inside) 1 192.168.11.0 255.255.255.0 0 0 nat (inside) 1 192.168.12.0 255.255.255.0 0 0 nat (inside) 1 192.168.13.0 255.255.255.0 0 0 nat (inside) 1 192.168.20.0 255.255.255.0 0 0 nat (inside) 1 192.168.21.0 255.255.255.0 0 0 nat (inside) 1 192.168.22.0 255.255.255.0 0 0 nat (inside) 1 192.168.23.0 255.255.255.0 0 0 static (inside,outside) tcp 216.74.163.205 www 192.168.10.99 8022 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.205 https 192.168.10.99 8021 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.201 www 192.168.10.99 8002 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.201 https 192.168.10.99 8001 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.203 www 192.168.10.99 9002 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.203 https 192.168.10.99 9001 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.204 www 192.168.10.99 8032 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.204 https 192.168.10.99 8031 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.202 24 192.168.10.156 24 netmask 255.255.255.255 0 0 static (inside,dmz) 192.168.10.0 192.168.10.0 netmask 255.255.255.0 0 0 static (inside,dmz) 192.168.11.0 192.168.11.0 netmask 255.255.255.0 0 0 static (inside,dmz) 192.168.12.0 192.168.12.0 netmask 255.255.255.0 0 0 static (inside,dmz) 192.168.13.0 192.168.13.0 netmask 255.255.255.0 0 0 static (dmz,outside) 216.74.146.240 216.74.146.240 netmask 255.255.255.240 0 0 access-group outside in interface outside access-group inside in interface inside access-group dmz in interface dmz router ospf 100 network 192.168.12.0 255.255.255.0 area 0 log-adj-changes redistribute static subnets route outside 0.0.0.0 0.0.0.0 x.x.x.x 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ (inside) host 192.168.10.156 *********** timeout 10 aaa-server TACACS+ (inside) host 192.168.10.157 *********** timeout 10 aaa-server RADIUS protocol radius aaa-server RADIUS (inside) host 192.168.10.201 ********** timeout 10 aaa-server LOCAL protocol local aaa authentication telnet console TACACS+ aaa authentication ssh console TACACS+ aaa accounting include telnet inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ aaa accounting include tcp/22 inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ aaa accounting include tcp/22 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ aaa accounting include telnet outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ no snmp-server location no snmp-server contact snmp-server community public snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp crypto ipsec transform-set kiodex esp-3des esp-md5-hmac crypto ipsec transform-set riptech esp-3des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set kiodex crypto map outside 1 ipsec-isakmp crypto map outside 1 match address 628broadway crypto map outside 1 set peer 24.213.162.102 crypto map outside 1 set transform-set kiodex crypto map outside 10 ipsec-isakmp crypto map outside 10 match address soc2800 crypto map outside 10 set peer 65.201.134.9 crypto map outside 10 set transform-set riptech crypto map outside 20 ipsec-isakmp dynamic dynmap crypto map outside client authentication RADIUS crypto map outside interface outside isakmp enable outside isakmp key ******** address x.x.x.x netmask 255.255.255.255 isakmp key ******** address x.x.x.x netmask 255.255.255.255 isakmp identity address isakmp policy 10 authentication pre-share isakmp policy 10 encryption 3des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup exovpn address-pool vpn vpngroup exovpn dns-server 192.168.10.156 192.168.10.157 vpngroup exovpn wins-server 192.168.10.200 vpngroup exovpn default-domain kdx.int vpngroup exovpn split-tunnel 628broadway vpngroup exovpn idle-time 900 vpngroup exovpn password ******** telnet timeout 10 ssh 192.168.10.0 255.255.255.0 inside ssh timeout 10 console timeout 0 vpdn group exo-pptp accept dialin pptp vpdn group exo-pptp ppp authentication mschap vpdn group exo-pptp ppp encryption mppe auto vpdn group exo-pptp client configuration address local vpn vpdn group exo-pptp client configuration dns 192.168.10.156 192.168.10.157 vpdn group exo-pptp client configuration wins 192.168.10.200 10.0.0.10 vpdn group exo-pptp client authentication aaa RADIUS vpdn group exo-pptp pptp echo 60 vpdn enable outside terminal width 80 Cryptochecksum:a32890423cd33fe6d6eaf4852149721a | |||||||||||||||||||||||||||||||
Posted by mcaissie on May 18, 2006, 7:20 pm
Please log in for more thread options tunneling and the noNAT. I think it's not even permitted . And in your case you also use the same list on the crypto map. ***** nat (inside) 0 access-list 628broadway vpngroup exovpn split-tunnel 628broadway crypto map outside 1 match address 628broadway access-list 628broadway permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.0.0 access-list 628broadway permit ip 172.16.1.0 255.255.255.0 192.168.0.0 255.255.0.0 access-list 628broadway permit ip 192.168.0.0 255.255.0.0 172.16.1.0 255.255.255.0 ip local pool vpn 172.16.1.1-172.16.1.100 ******* --So i strongly suggest to create a separate acl for the split-tunneling and nat (inside ) 0 and we can see from there. -split tunnel list is "permit ip [ip pool] [internal address]" access-list split-exovpn permit ip 172.16.1.0 255.255.255.0 192.168.0.0 255.255.0.0 vpngroup exovpn split-tunnel split-exovpn -nonat list must include the inverse; "permit ip [internal address] [ip pool] access-list nonat permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.0.0 access-list nonat permit ip 192.168.0.0 255.255.0.0 172.16.1.0 255.255.255.0 nat (inside) 0 access-list nonat > Hi, I'm trying to set up a cisco ipsec client connection to a pix 515
> running 6.3.3. > > The clients get authenticated, and connect fine. > > Onc ethe vpn client tries to go to any machine on the inside > (192.168.10.0/24) the following message is generated on the pix: > > No translation group found for tcp src <vpn ip> > > The sanitized conf is below. Any help is appreciated. > thanks > > > ############################################# > PIX Version 6.3(3) > interface ethernet0 100full > interface ethernet1 100full > interface ethernet2 100full > interface ethernet3 100full > interface ethernet4 auto shutdown > interface ethernet5 auto shutdown > nameif ethernet0 outside security0 > nameif ethernet1 inside security100 > nameif ethernet2 failover security20 > nameif ethernet3 dmz security20 > nameif ethernet4 e4 security0 > nameif ethernet5 e5 security0 > enable password ************ encrypted > passwd ************ encrypted > hostname spix > domain-name ******** > fixup protocol dns maximum-length 512 > fixup protocol domain 53 > fixup protocol ftp 21 > fixup protocol h323 h225 1720 > fixup protocol h323 ras 1718-1719 > fixup protocol http 80 > no fixup protocol rsh 514 > fixup protocol rtsp 554 > fixup protocol sip 5060 > fixup protocol sip udp 5060 > no fixup protocol skinny 2000 > no fixup protocol smtp 25 > fixup protocol sqlnet 1521 > fixup protocol tftp 69 > no names > access-list soc2800 permit ip host 216.74.163.199 host 65.197.254.5 > access-list soc2800 permit ip host 216.74.163.199 63.108.175.0 > 255.255.255.0 > access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.1 > access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.2 > access-list inside permit udp 192.168.0.0 255.255.0.0 host > 216.74.163.194 eq ntp > access-list inside permit udp 192.168.0.0 255.255.0.0 host > 216.74.163.195 eq ntp > access-list inside permit icmp any any echo > access-list inside permit icmp any any unreachable > access-list inside permit icmp any any source-quench > access-list inside permit icmp any any time-exceeded > access-list inside remark ###### allow ftp to ftp.lim.com > access-list inside permit tcp 192.168.10.0 255.255.255.0 host > 12.43.226.2 eq ftp > access-list inside permit tcp host 192.168.10.80 any eq www > access-list inside permit tcp host 192.168.10.80 any eq ftp > access-list inside permit tcp host 192.168.10.80 any eq https > access-list inside permit tcp host 192.168.10.80 any eq ssh > access-list inside permit tcp host 192.168.10.80 any eq smtp > access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.1 > access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.2 > access-list inside permit ip 192.168.0.0 255.255.0.0 10.0.0.0 > 255.255.0.0 > access-list inside permit ip 192.168.0.0 255.255.0.0 192.168.0.0 > 255.255.0.0 > access-list inside permit tcp host 192.168.10.80 any eq telnet > access-list inside permit tcp host 192.168.10.157 any eq https > access-list inside permit tcp host 192.168.10.156 any eq smtp > access-list inside permit tcp host 192.168.10.156 any eq https > access-list inside permit udp host 192.168.10.156 any eq ntp > access-list inside permit udp host 192.168.10.157 any eq ntp > access-list inside permit udp host 192.168.10.157 any eq domain > access-list inside permit udp host 192.168.10.156 any eq domain > access-list inside permit tcp host 192.168.10.157 any eq domain > access-list inside permit tcp host 192.168.10.156 any eq domain > access-list inside permit tcp host 192.168.10.199 any eq domain > access-list inside permit udp host 192.168.10.199 any eq domain > access-list inside permit tcp host 192.168.10.197 any eq domain > access-list inside permit udp host 192.168.10.197 any eq domain > access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 > 255.255.255.0 eq www > access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 > 255.255.255.0 eq https > access-list inside permit tcp 192.168.0.0 255.255.0.0 host > 208.173.140.54 eq smtp > access-list inside permit tcp host 192.168.10.199 host 192.88.69.69 eq > ftp > access-list inside permit tcp host 192.168.10.197 host 192.88.69.69 eq > ftp > access-list inside permit tcp host 192.168.10.185 any eq smtp > access-list inside remark ##### allow all machines out to > futuresource.com and xml.marketcenter.com on 4004 > access-list inside permit tcp 192.168.10.0 255.255.255.0 any eq 4004 > access-list inside remark ###### allow specific machines out > access-list inside permit tcp host 192.168.10.185 any eq www > access-list inside permit tcp host 192.168.10.185 any eq https > access-list inside permit tcp host 192.168.10.200 any eq www > access-list inside permit tcp host 192.168.10.201 any eq www > access-list inside permit tcp host 192.168.10.200 any eq https > access-list inside permit tcp host 192.168.10.201 any eq https > access-list inside permit tcp host 192.168.10.200 any eq ftp > access-list inside permit tcp host 192.168.10.201 any eq ftp > access-list inside remark ###### LAN --> border network > access-list inside permit tcp 192.168.10.0 255.255.255.0 216.74.163.192 > 255.255.255.224 eq telnet > access-list inside remark #### allw VPN local pool ips > access-list inside permit ip 192.168.0.0 255.255.0.0 172.16.1.0 > 255.255.255.0 > access-list outside permit icmp any any echo-reply > access-list outside permit icmp any any unreachable > access-list outside permit icmp any any time-exceeded > access-list outside permit tcp any host 216.74.163.204 eq https > access-list outside permit tcp any host 216.74.163.204 eq www > access-list outside permit tcp any host 216.74.163.209 eq www > access-list outside permit tcp any host 216.74.163.209 eq https > access-list outside permit tcp any host 216.74.163.205 eq www > access-list outside permit tcp any host 216.74.163.205 eq https > access-list outside permit tcp any host 216.74.163.203 eq www > access-list outside permit tcp any host 216.74.163.203 eq https > access-list outside permit tcp any host 216.74.163.201 eq www > access-list outside permit tcp any host 216.74.163.201 eq https > access-list outside permit tcp any host 216.74.146.250 eq www > access-list outside remark ###### line 15-22 may be obsolete DSP 2.6.06 > access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq > ssh > access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq > 10000 > access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq > 8888 > access-list outside permit esp host 12.146.1.11 host 216.74.146.244 > access-list outside permit esp host 12.146.1.11 host 216.74.146.245 > access-list outside permit tcp any host 216.74.163.202 eq 24 > access-list outside permit tcp any host 216.74.146.244 eq ssh > access-list outside permit tcp any host 216.74.146.245 eq ssh > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.10.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.11.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.12.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.13.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.20.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.21.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.22.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.23.0 > 255.255.255.0 > access-list dmz permit udp 216.74.146.240 255.255.255.240 host > 216.74.163.194 eq ntp > access-list dmz permit udp 216.74.146.240 255.255.255.240 host > 216.74.163.195 eq ntp > access-list dmz permit icmp any any echo > access-list dmz permit icmp any any unreachable > access-list dmz permit icmp any any time-exceeded > access-list dmz permit tcp host 216.74.146.250 host 24.213.162.100 eq > smtp > access-list dmz permit tcp host 216.74.146.250 any eq domain > access-list dmz permit udp host 216.74.146.250 any eq domain > access-list dmz permit tcp host 216.74.146.250 any eq ssh > access-list dmz permit udp host 216.74.146.244 host 12.146.1.11 eq > isakmp > access-list dmz permit udp host 216.74.146.245 host 12.146.1.11 eq > isakmp > access-list dmz permit esp host 216.74.146.245 host 12.146.1.11 > access-list dmz permit esp host 216.74.146.244 host 12.146.1.11 > access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq > 2036 > access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq > 2036 > access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq > ssh > access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq > ssh > access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq > 2036 > access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq > 2036 > access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq > ssh > access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq > ssh > access-list 628broadway permit ip 192.168.0.0 255.255.0.0 10.0.0.0 > 255.255.0.0 > access-list 628broadway permit ip 172.16.1.0 255.255.255.0 192.168.0.0 > 255.255.0.0 > access-list 628broadway permit ip 192.168.0.0 255.255.0.0 172.16.1.0 > 255.255.255.0 > pager lines 24 > logging on > logging timestamp > logging standby > logging trap debugging > logging history informational > logging facility 23 > logging device-id hostname > logging host outside 63.108.175.80 > logging host inside 192.168.10.156 > no logging message 302015 > no logging message 302014 > no logging message 302013 > icmp permit any inside > mtu outside 1500 > mtu inside 1500 > mtu failover 1500 > mtu dmz 1500 > mtu e4 1500 > mtu e5 1500 > ip address outside x.x.x.x > ip address inside 192.168.12.1 255.255.255.0 > ip address failover 192.168.14.1 255.255.255.252 > ip address dmz x.x.x.x > no ip address e4 > no ip address e5 > ip audit info action alarm > ip audit attack action alarm > ip local pool vpn 172.16.1.1-172.16.1.100 > failover > failover timeout 0:00:00 > failover poll 15 > failover ip address outside x.x.x.x > failover ip address inside 192.168.12.2 > failover ip address failover 192.168.14.2 > failover ip address dmz x.x.x.x > no failover ip address e4 > no failover ip address e5 > failover link failover > no pdm history enable > arp outside x.x.x.x 0000.0c07.ac00 alias > arp timeout 14400 > global (outside) 1 interface > nat (inside) 0 access-list 628broadway > nat (inside) 1 192.168.10.0 255.255.255.0 0 0 > nat (inside) 1 192.168.11.0 255.255.255.0 0 0 > nat (inside) 1 192.168.12.0 255.255.255.0 0 0 > nat (inside) 1 192.168.13.0 255.255.255.0 0 0 > nat (inside) 1 192.168.20.0 255.255.255.0 0 0 > nat (inside) 1 192.168.21.0 255.255.255.0 0 0 > nat (inside) 1 192.168.22.0 255.255.255.0 0 0 > nat (inside) 1 192.168.23.0 255.255.255.0 0 0 > static (inside,outside) tcp 216.74.163.205 www 192.168.10.99 8022 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.205 https 192.168.10.99 8021 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.201 www 192.168.10.99 8002 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.201 https 192.168.10.99 8001 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.203 www 192.168.10.99 9002 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.203 https 192.168.10.99 9001 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.204 www 192.168.10.99 8032 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.204 https 192.168.10.99 8031 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.202 24 192.168.10.156 24 netmask > 255.255.255.255 0 0 > static (inside,dmz) 192.168.10.0 192.168.10.0 netmask 255.255.255.0 0 0 > > static (inside,dmz) 192.168.11.0 192.168.11.0 netmask 255.255.255.0 0 0 > > static (inside,dmz) 192.168.12.0 192.168.12.0 netmask 255.255.255.0 0 0 > > static (inside,dmz) 192.168.13.0 192.168.13.0 netmask 255.255.255.0 0 0 > > static (dmz,outside) 216.74.146.240 216.74.146.240 netmask > 255.255.255.240 0 0 > access-group outside in interface outside > access-group inside in interface inside > access-group dmz in interface dmz > router ospf 100 > network 192.168.12.0 255.255.255.0 area 0 > log-adj-changes > redistribute static subnets > route outside 0.0.0.0 0.0.0.0 x.x.x.x 1 > timeout xlate 3:00:00 > timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 > 1:00:00 > timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 > timeout uauth 0:05:00 absolute > aaa-server TACACS+ protocol tacacs+ > aaa-server TACACS+ (inside) host 192.168.10.156 *********** timeout 10 > aaa-server TACACS+ (inside) host 192.168.10.157 *********** timeout 10 > aaa-server RADIUS protocol radius > aaa-server RADIUS (inside) host 192.168.10.201 ********** timeout 10 > aaa-server LOCAL protocol local > aaa authentication telnet console TACACS+ > aaa authentication ssh console TACACS+ > aaa accounting include telnet inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 > TACACS+ > aaa accounting include tcp/22 inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 > TACACS+ > aaa accounting include tcp/22 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 > TACACS+ > aaa accounting include telnet outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 > TACACS+ > no snmp-server location > no snmp-server contact > snmp-server community public > snmp-server enable traps > floodguard enable > sysopt connection permit-ipsec > sysopt connection permit-pptp > crypto ipsec transform-set kiodex esp-3des esp-md5-hmac > crypto ipsec transform-set riptech esp-3des esp-md5-hmac > crypto dynamic-map dynmap 10 set transform-set kiodex > crypto map outside 1 ipsec-isakmp > crypto map outside 1 match address 628broadway > crypto map outside 1 set peer 24.213.162.102 > crypto map outside 1 set transform-set kiodex > crypto map outside 10 ipsec-isakmp > crypto map outside 10 match address soc2800 > crypto map outside 10 set peer 65.201.134.9 > crypto map outside 10 set transform-set riptech > crypto map outside 20 ipsec-isakmp dynamic dynmap > crypto map outside client authentication RADIUS > crypto map outside interface outside > isakmp enable outside > isakmp key ******** address x.x.x.x netmask 255.255.255.255 > isakmp key ******** address x.x.x.x netmask 255.255.255.255 > isakmp identity address > isakmp policy 10 authentication pre-share > isakmp policy 10 encryption 3des > isakmp policy 10 hash md5 > isakmp policy 10 group 2 > isakmp policy 10 lifetime 86400 > vpngroup exovpn address-pool vpn > vpngroup exovpn dns-server 192.168.10.156 192.168.10.157 > vpngroup exovpn wins-server 192.168.10.200 > vpngroup exovpn default-domain kdx.int > vpngroup exovpn split-tunnel 628broadway > vpngroup exovpn idle-time 900 > vpngroup exovpn password ******** > telnet timeout 10 > ssh 192.168.10.0 255.255.255.0 inside > ssh timeout 10 > console timeout 0 > vpdn group exo-pptp accept dialin pptp > vpdn group exo-pptp ppp authentication mschap > vpdn group exo-pptp ppp encryption mppe auto > vpdn group exo-pptp client configuration address local vpn > vpdn group exo-pptp client configuration dns 192.168.10.156 > 192.168.10.157 > vpdn group exo-pptp client configuration wins 192.168.10.200 10.0.0.10 > vpdn group exo-pptp client authentication aaa RADIUS > vpdn group exo-pptp pptp echo 60 > vpdn enable outside > terminal width 80 > Cryptochecksum:a32890423cd33fe6d6eaf4852149721a > | |||||||||||||||||||||||||||||||
Posted by on May 19, 2006, 5:30 pm
Please log in for more thread options ok, the updated conf is below. this did solve the "No translation group
found for src" errors, but I still cant connect to anythign on 192.168.0.0./16 once I (sucessfully) make the vpn connection. I noticed on the client side, after connecting, that I didnt have any routes to 192.168.x.x thanks david -------------------------------------------------------------------- PIX Version 6.3(3) interface ethernet0 100full interface ethernet1 100full interface ethernet2 100full interface ethernet3 100full interface ethernet4 auto shutdown interface ethernet5 auto shutdown nameif ethernet0 outside security0 nameif ethernet1 inside security100 nameif ethernet2 failover security20 nameif ethernet3 dmz security20 nameif ethernet4 e4 security0 nameif ethernet5 e5 security0 enable password ************ encrypted passwd ************ encrypted hostname spix domain-name x.x.x fixup protocol dns maximum-length 512 fixup protocol domain 53 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 no fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 no fixup protocol skinny 2000 no fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 no names access-list soc2800 permit ip host 216.74.163.199 host 65.197.254.5 access-list soc2800 permit ip host 216.74.163.199 63.108.175.0 255.255.255.0 access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.1 access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.2 access-list inside permit udp 192.168.0.0 255.255.0.0 host 216.74.163.194 eq ntp access-list inside permit udp 192.168.0.0 255.255.0.0 host 216.74.163.195 eq ntp access-list inside permit icmp any any echo access-list inside permit icmp any any unreachable access-list inside permit icmp any any source-quench access-list inside permit icmp any any time-exceeded access-list inside remark ###### allow ftp to ftp.lim.com access-list inside permit tcp 192.168.10.0 255.255.255.0 host 12.43.226.2 eq ftp access-list inside permit tcp host 192.168.10.80 any eq www access-list inside permit tcp host 192.168.10.80 any eq ftp access-list inside permit tcp host 192.168.10.80 any eq https access-list inside permit tcp host 192.168.10.80 any eq ssh access-list inside permit tcp host 192.168.10.80 any eq smtp access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.1 access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.2 access-list inside permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.0.0 access-list inside permit ip 192.168.0.0 255.255.0.0 192.168.0.0 255.255.0.0 access-list inside permit tcp host 192.168.10.80 any eq telnet access-list inside permit tcp host 192.168.10.157 any eq https access-list inside permit tcp host 192.168.10.156 any eq smtp access-list inside permit tcp host 192.168.10.156 any eq https access-list inside permit udp host 192.168.10.156 any eq ntp access-list inside permit udp host 192.168.10.157 any eq ntp access-list inside permit udp host 192.168.10.157 any eq domain access-list inside permit udp host 192.168.10.156 any eq domain access-list inside permit tcp host 192.168.10.157 any eq domain access-list inside permit tcp host 192.168.10.156 any eq domain access-list inside permit tcp host 192.168.10.199 any eq domain access-list inside permit udp host 192.168.10.199 any eq domain access-list inside permit tcp host 192.168.10.197 any eq domain access-list inside permit udp host 192.168.10.197 any eq domain access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 255.255.255.0 eq www access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 255.255.255.0 eq https access-list inside permit tcp 192.168.0.0 255.255.0.0 host 208.173.140.54 eq smtp access-list inside permit tcp host 192.168.10.199 host 192.88.69.69 eq ftp access-list inside permit tcp host 192.168.10.197 host 192.88.69.69 eq ftp access-list inside permit tcp host 192.168.10.185 any eq smtp access-list inside remark ##### allow all machines out to futuresource.com and xml.marketcenter.com on 4004 access-list inside permit tcp 192.168.10.0 255.255.255.0 any eq 4004 access-list inside remark ###### allow specific machines out access-list inside permit tcp host 192.168.10.185 any eq www access-list inside permit tcp host 192.168.10.185 any eq https access-list inside permit tcp host 192.168.10.200 any eq www access-list inside permit tcp host 192.168.10.201 any eq www access-list inside permit tcp host 192.168.10.200 any eq https access-list inside permit tcp host 192.168.10.201 any eq https access-list inside permit tcp host 192.168.10.200 any eq ftp access-list inside permit tcp host 192.168.10.201 any eq ftp access-list inside remark ###### LAN --> border network
255.255.255.224 eq telnet access-list inside remark #### allw VPN local pool ips access-list inside permit ip 192.168.0.0 255.255.0.0 172.16.1.0 255.255.255.0 access-list outside permit icmp any any echo-reply access-list outside permit icmp any any unreachable access-list outside permit icmp any any time-exceeded access-list outside permit tcp any host 216.74.163.204 eq https access-list outside permit tcp any host 216.74.163.204 eq www access-list outside permit tcp any host 216.74.163.209 eq www access-list outside permit tcp any host 216.74.163.209 eq https access-list outside permit tcp any host 216.74.163.205 eq www access-list outside permit tcp any host 216.74.163.205 eq https access-list outside permit tcp any host 216.74.163.203 eq www access-list outside permit tcp any host 216.74.163.203 eq https access-list outside permit tcp any host 216.74.163.201 eq www access-list outside permit tcp any host 216.74.163.201 eq https access-list outside permit tcp any host 216.74.146.250 eq www access-list outside remark ###### line 15-22 may be obsolete DSP 2.6.06 access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq ssh access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq 10000 access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq 8888 access-list outside permit esp host 12.146.1.11 host 216.74.146.244 access-list outside permit esp host 12.146.1.11 host 216.74.146.245 access-list outside permit tcp any host 216.74.163.202 eq 24 access-list outside permit tcp any host 216.74.146.244 eq ssh access-list outside permit tcp any host 216.74.146.245 eq ssh access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.10.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.11.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.12.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.13.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.20.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.21.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.22.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.23.0 255.255.255.0 access-list outside remark ##### deny below added per SOC incident 19319363 access-list outside deny tcp any host 67.85.186.115 access-list dmz permit udp 216.74.146.240 255.255.255.240 host 216.74.163.194 eq ntp access-list dmz permit udp 216.74.146.240 255.255.255.240 host 216.74.163.195 eq ntp access-list dmz permit icmp any any echo access-list dmz permit icmp any any unreachable access-list dmz permit icmp any any time-exceeded access-list dmz permit tcp host 216.74.146.250 host 24.213.162.100 eq smtp access-list dmz permit tcp host 216.74.146.250 any eq domain access-list dmz permit udp host 216.74.146.250 any eq domain access-list dmz permit tcp host 216.74.146.250 any eq ssh access-list dmz permit udp host 216.74.146.244 host 12.146.1.11 eq isakmp access-list dmz permit udp host 216.74.146.245 host 12.146.1.11 eq isakmp access-list dmz permit esp host 216.74.146.245 host 12.146.1.11 access-list dmz permit esp host 216.74.146.244 host 12.146.1.11 access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq ssh access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq ssh access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq ssh access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq ssh access-list 628broadway permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.0.0 access-list 628broadway permit ip 192.168.0.0 255.255.0.0 172.16.1.0 255.255.255.0 access-list exovpn permit ip 172.16.1.0 255.255.255.0 192.168.0.0 255.255.0.0 pager lines 24 logging on logging timestamp logging standby logging trap debugging logging history informational logging facility 23 logging device-id hostname logging host outside x.x.x.x logging host inside x.x.x.x icmp permit any inside mtu outside 1500 mtu inside 1500 mtu failover 1500 mtu dmz 1500 mtu e4 1500 mtu e5 1500 ip address outside x.x.x.x 255.255.255.224 ip address inside 192.168.12.1 255.255.255.0 ip address failover 192.168.14.1 255.255.255.252 ip address dmz x.x.x.x 255.255.255.240 no ip address e4 no ip address e5 ip audit info action alarm ip audit attack action alarm ip local pool vpn 172.16.1.1-172.16.1.100 failover failover timeout 0:00:00 failover poll 15 failover ip address outside x.x.x.x failover ip address inside 192.168.12.2 failover ip address failover 192.168.14.2 failover ip address dmz x.x.x.x no failover ip address e4 no failover ip address e5 failover link failover no pdm history enable arp outside x.x.x.x 0000.0c07.ac00 alias arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list 628broadway nat (inside) 1 192.168.10.0 255.255.255.0 0 0 nat (inside) 1 192.168.11.0 255.255.255.0 0 0 nat (inside) 1 192.168.12.0 255.255.255.0 0 0 nat (inside) 1 192.168.13.0 255.255.255.0 0 0 nat (inside) 1 192.168.20.0 255.255.255.0 0 0 nat (inside) 1 192.168.21.0 255.255.255.0 0 0 nat (inside) 1 192.168.22.0 255.255.255.0 0 0 nat (inside) 1 192.168.23.0 255.255.255.0 0 0 static (inside,outside) tcp 216.74.163.205 www 192.168.10.99 8022 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.205 https 192.168.10.99 8021 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.201 www 192.168.10.99 8002 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.201 https 192.168.10.99 8001 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.203 www 192.168.10.99 9002 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.203 https 192.168.10.99 9001 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.204 www 192.168.10.99 8032 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.204 https 192.168.10.99 8031 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.202 24 192.168.10.156 24 netmask 255.255.255.255 0 0 static (inside,dmz) 192.168.10.0 192.168.10.0 netmask 255.255.255.0 0 0 static (inside,dmz) 192.168.11.0 192.168.11.0 netmask 255.255.255.0 0 0 static (inside,dmz) 192.168.12.0 192.168.12.0 netmask 255.255.255.0 0 0 static (inside,dmz) 192.168.13.0 192.168.13.0 netmask 255.255.255.0 0 0 static (dmz,outside) 216.74.146.240 216.74.146.240 netmask 255.255.255.240 0 0 access-group outside in interface outside access-group inside in interface inside access-group dmz in interface dmz router ospf 100 network 192.168.12.0 255.255.255.0 area 0 log-adj-changes redistribute static subnets route outside 0.0.0.0 0.0.0.0 216.74.163.193 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ (inside) host 192.168.10.156 ******** timeout 10 aaa-server TACACS+ (inside) host 192.168.10.157 ******** timeout 10 aaa-server RADIUS protocol radius aaa-server RADIUS (inside) host 192.168.10.201 ******** timeout 10 aaa-server LOCAL protocol local aaa authentication telnet console TACACS+ aaa authentication ssh console TACACS+ aaa accounting include telnet inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ aaa accounting include tcp/22 inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ aaa accounting include tcp/22 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ aaa accounting include telnet outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ no snmp-server location no snmp-server contact snmp-server community xxxxx snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp crypto ipsec transform-set kiodex esp-3des esp-md5-hmac crypto ipsec transform-set riptech esp-3des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set kiodex crypto map outside 1 ipsec-isakmp crypto map outside 1 match address 628broadway crypto map outside 1 set peer x.x.x.x crypto map outside 1 set transform-set kiodex crypto map outside 10 ipsec-isakmp crypto map outside 10 match address soc2800 crypto map outside 10 set peer xxxx crypto map outside 10 set transform-set riptech crypto map outside 20 ipsec-isakmp dynamic dynmap crypto map outside client authentication RADIUS crypto map outside interface outside isakmp enable outside isakmp key ******** address x.x.x.x netmask 255.255.255.255 isakmp key ******** address x.x.x.x netmask 255.255.255.255 isakmp identity address isakmp policy 10 authentication pre-share isakmp policy 10 encryption 3des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup exovpn address-pool vpn vpngroup exovpn dns-server 192.168.10.156 192.168.10.157 vpngroup exovpn wins-server 192.168.10.200 vpngroup exovpn default-domain kdx.int vpngroup exovpn split-tunnel exovpn vpngroup exovpn idle-time 900 vpngroup exovpn password ******** telnet timeout 10 ssh 192.168.10.0 255.255.255.0 inside ssh timeout 10 console timeout 0 vpdn group exo-pptp accept dialin pptp vpdn group exo-pptp ppp authentication mschap vpdn group exo-pptp ppp encryption mppe auto vpdn group exo-pptp client configuration address local vpn vpdn group exo-pptp client configuration dns 192.168.10.156 192.168.10.157 vpdn group exo-pptp client configuration wins 192.168.10.200 10.0.0.10 vpdn group exo-pptp client authentication aaa RADIUS vpdn group exo-pptp pptp echo 60 vpdn enable outside terminal width 80 | |||||||||||||||||||||||||||||||
Posted by mcaissie on May 23, 2006, 10:15 am
> found for src" errors, but I still cant connect to anythign on > 192.168.0.0./16 once I (sucessfully) make the vpn connection. > > I noticed on the client side, after connecting, that I didnt have any > routes to 192.168.x.x > -On your Cisco client, what do you see in Status-Statistics-Route Details after connecting ? >
> -------------------------------------------------------------------- > PIX Version 6.3(3) > interface ethernet0 100full > interface ethernet1 100full > interface ethernet2 100full > interface ethernet3 100full > interface ethernet4 auto shutdown > interface ethernet5 auto shutdown > nameif ethernet0 outside security0 > nameif ethernet1 inside security100 > nameif ethernet2 failover security20 > nameif ethernet3 dmz security20 > nameif ethernet4 e4 security0 > nameif ethernet5 e5 security0 > enable password ************ encrypted > passwd ************ encrypted > hostname spix > domain-name x.x.x > fixup protocol dns maximum-length 512 > fixup protocol domain 53 > fixup protocol ftp 21 > fixup protocol h323 h225 1720 > fixup protocol h323 ras 1718-1719 > fixup protocol http 80 > no fixup protocol rsh 514 > fixup protocol rtsp 554 > fixup protocol sip 5060 > fixup protocol sip udp 5060 > no fixup protocol skinny 2000 > no fixup protocol smtp 25 > fixup protocol sqlnet 1521 > fixup protocol tftp 69 > no names > access-list soc2800 permit ip host 216.74.163.199 host 65.197.254.5 > access-list soc2800 permit ip host 216.74.163.199 63.108.175.0 > 255.255.255.0 > access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.1 > access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.2 > access-list inside permit udp 192.168.0.0 255.255.0.0 host > 216.74.163.194 eq ntp > access-list inside permit udp 192.168.0.0 255.255.0.0 host > 216.74.163.195 eq ntp > access-list inside permit icmp any any echo > access-list inside permit icmp any any unreachable > access-list inside permit icmp any any source-quench > access-list inside permit icmp any any time-exceeded > access-list inside remark ###### allow ftp to ftp.lim.com > access-list inside permit tcp 192.168.10.0 255.255.255.0 host > 12.43.226.2 eq ftp > access-list inside permit tcp host 192.168.10.80 any eq www > access-list inside permit tcp host 192.168.10.80 any eq ftp > access-list inside permit tcp host 192.168.10.80 any eq https > access-list inside permit tcp host 192.168.10.80 any eq ssh > access-list inside permit tcp host 192.168.10.80 any eq smtp > access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.1 > access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.2 > access-list inside permit ip 192.168.0.0 255.255.0.0 10.0.0.0 > 255.255.0.0 > access-list inside permit ip 192.168.0.0 255.255.0.0 192.168.0.0 > 255.255.0.0 > access-list inside permit tcp host 192.168.10.80 any eq telnet > access-list inside permit tcp host 192.168.10.157 any eq https > access-list inside permit tcp host 192.168.10.156 any eq smtp > access-list inside permit tcp host 192.168.10.156 any eq https > access-list inside permit udp host 192.168.10.156 any eq ntp > access-list inside permit udp host 192.168.10.157 any eq ntp > access-list inside permit udp host 192.168.10.157 any eq domain > access-list inside permit udp host 192.168.10.156 any eq domain > access-list inside permit tcp host 192.168.10.157 any eq domain > access-list inside permit tcp host 192.168.10.156 any eq domain > access-list inside permit tcp host 192.168.10.199 any eq domain > access-list inside permit udp host 192.168.10.199 any eq domain > access-list inside permit tcp host 192.168.10.197 any eq domain > access-list inside permit udp host 192.168.10.197 any eq domain > access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 > 255.255.255.0 eq www > access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 > 255.255.255.0 eq https > access-list inside permit tcp 192.168.0.0 255.255.0.0 host > 208.173.140.54 eq smtp > access-list inside permit tcp host 192.168.10.199 host 192.88.69.69 eq > ftp > access-list inside permit tcp host 192.168.10.197 host 192.88.69.69 eq > ftp > access-list inside permit tcp host 192.168.10.185 any eq smtp > access-list inside remark ##### allow all machines out to > futuresource.com and xml.marketcenter.com on 4004 > access-list inside permit tcp 192.168.10.0 255.255.255.0 any eq 4004 > access-list inside remark ###### allow specific machines out > access-list inside permit tcp host 192.168.10.185 any eq www > access-list inside permit tcp host 192.168.10.185 any eq https > access-list inside permit tcp host 192.168.10.200 any eq www > access-list inside permit tcp host 192.168.10.201 any eq www > access-list inside permit tcp host 192.168.10.200 any eq https > access-list inside permit tcp host 192.168.10.201 any eq https > access-list inside permit tcp host 192.168.10.200 any eq ftp > access-list inside permit tcp host 192.168.10.201 any eq ftp > access-list inside remark ###### LAN --> border network > access-list inside permit tcp 192.168.10.0 255.255.255.0 216.74.163.192 > 255.255.255.224 eq telnet > access-list inside remark #### allw VPN local pool ips > access-list inside permit ip 192.168.0.0 255.255.0.0 172.16.1.0 > 255.255.255.0 > access-list outside permit icmp any any echo-reply > access-list outside permit icmp any any unreachable > access-list outside permit icmp any any time-exceeded > access-list outside permit tcp any host 216.74.163.204 eq https > access-list outside permit tcp any host 216.74.163.204 eq www > access-list outside permit tcp any host 216.74.163.209 eq www > access-list outside permit tcp any host 216.74.163.209 eq https > access-list outside permit tcp any host 216.74.163.205 eq www > access-list outside permit tcp any host 216.74.163.205 eq https > access-list outside permit tcp any host 216.74.163.203 eq www > access-list outside permit tcp any host 216.74.163.203 eq https > access-list outside permit tcp any host 216.74.163.201 eq www > access-list outside permit tcp any host 216.74.163.201 eq https > access-list outside permit tcp any host 216.74.146.250 eq www > access-list outside remark ###### line 15-22 may be obsolete DSP 2.6.06 > access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq > ssh > access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq > 10000 > access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq > 8888 > access-list outside permit esp host 12.146.1.11 host 216.74.146.244 > access-list outside permit esp host 12.146.1.11 host 216.74.146.245 > access-list outside permit tcp any host 216.74.163.202 eq 24 > access-list outside permit tcp any host 216.74.146.244 eq ssh > access-list outside permit tcp any host 216.74.146.245 eq ssh > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.10.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.11.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.12.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.13.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.20.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.21.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.22.0 > 255.255.255.0 > access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.23.0 > 255.255.255.0 > access-list outside remark ##### deny below added per SOC incident > 19319363 > access-list outside deny tcp any host 67.85.186.115 > access-list dmz permit udp 216.74.146.240 255.255.255.240 host > 216.74.163.194 eq ntp > access-list dmz permit udp 216.74.146.240 255.255.255.240 host > 216.74.163.195 eq ntp > access-list dmz permit icmp any any echo > access-list dmz permit icmp any any unreachable > access-list dmz permit icmp any any time-exceeded > access-list dmz permit tcp host 216.74.146.250 host 24.213.162.100 eq > smtp > access-list dmz permit tcp host 216.74.146.250 any eq domain > access-list dmz permit udp host 216.74.146.250 any eq domain > access-list dmz permit tcp host 216.74.146.250 any eq ssh > access-list dmz permit udp host 216.74.146.244 host 12.146.1.11 eq > isakmp > access-list dmz permit udp host 216.74.146.245 host 12.146.1.11 eq > isakmp > access-list dmz permit esp host 216.74.146.245 host 12.146.1.11 > access-list dmz permit esp host 216.74.146.244 host 12.146.1.11 > access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq > 2036 > access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq > 2036 > access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq > ssh > access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq > ssh > access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq > 2036 > access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq > 2036 > access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq > ssh > access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq > ssh > access-list 628broadway permit ip 192.168.0.0 255.255.0.0 10.0.0.0 > 255.255.0.0 > access-list 628broadway permit ip 192.168.0.0 255.255.0.0 172.16.1.0 > 255.255.255.0 > access-list exovpn permit ip 172.16.1.0 255.255.255.0 192.168.0.0 > 255.255.0.0 > pager lines 24 > logging on > logging timestamp > logging standby > logging trap debugging > logging history informational > logging facility 23 > logging device-id hostname > logging host outside x.x.x.x > logging host inside x.x.x.x > icmp permit any inside > mtu outside 1500 > mtu inside 1500 > mtu failover 1500 > mtu dmz 1500 > mtu e4 1500 > mtu e5 1500 > ip address outside x.x.x.x 255.255.255.224 > ip address inside 192.168.12.1 255.255.255.0 > ip address failover 192.168.14.1 255.255.255.252 > ip address dmz x.x.x.x 255.255.255.240 > no ip address e4 > no ip address e5 > ip audit info action alarm > ip audit attack action alarm > ip local pool vpn 172.16.1.1-172.16.1.100 > failover > failover timeout 0:00:00 > failover poll 15 > failover ip address outside x.x.x.x > failover ip address inside 192.168.12.2 > failover ip address failover 192.168.14.2 > failover ip address dmz x.x.x.x > no failover ip address e4 > no failover ip address e5 > failover link failover > no pdm history enable > arp outside x.x.x.x 0000.0c07.ac00 alias > arp timeout 14400 > global (outside) 1 interface > nat (inside) 0 access-list 628broadway > nat (inside) 1 192.168.10.0 255.255.255.0 0 0 > nat (inside) 1 192.168.11.0 255.255.255.0 0 0 > nat (inside) 1 192.168.12.0 255.255.255.0 0 0 > nat (inside) 1 192.168.13.0 255.255.255.0 0 0 > nat (inside) 1 192.168.20.0 255.255.255.0 0 0 > nat (inside) 1 192.168.21.0 255.255.255.0 0 0 > nat (inside) 1 192.168.22.0 255.255.255.0 0 0 > nat (inside) 1 192.168.23.0 255.255.255.0 0 0 > static (inside,outside) tcp 216.74.163.205 www 192.168.10.99 8022 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.205 https 192.168.10.99 8021 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.201 www 192.168.10.99 8002 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.201 https 192.168.10.99 8001 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.203 www 192.168.10.99 9002 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.203 https 192.168.10.99 9001 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.204 www 192.168.10.99 8032 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.204 https 192.168.10.99 8031 > netmask 255.255.255.255 0 0 > static (inside,outside) tcp 216.74.163.202 24 192.168.10.156 24 netmask > 255.255.255.255 0 0 > static (inside,dmz) 192.168.10.0 192.168.10.0 netmask 255.255.255.0 0 0 > > static (inside,dmz) 192.168.11.0 192.168.11.0 netmask 255.255.255.0 0 0 > > static (inside,dmz) 192.168.12.0 192.168.12.0 netmask 255.255.255.0 0 0 > > static (inside,dmz) 192.168.13.0 192.168.13.0 netmask 255.255.255.0 0 0 > > static (dmz,outside) 216.74.146.240 216.74.146.240 netmask > 255.255.255.240 0 0 > access-group outside in interface outside > access-group inside in interface inside > access-group dmz in interface dmz > router ospf 100 > network 192.168.12.0 255.255.255.0 area 0 > log-adj-changes > redistribute static subnets > route outside 0.0.0.0 0.0.0.0 216.74.163.193 1 > timeout xlate 3:00:00 > timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 > 1:00:00 > timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 > timeout uauth 0:05:00 absolute > aaa-server TACACS+ protocol tacacs+ > aaa-server TACACS+ (inside) host 192.168.10.156 ******** timeout 10 > aaa-server TACACS+ (inside) host 192.168.10.157 ******** timeout 10 > aaa-server RADIUS protocol radius > aaa-server RADIUS (inside) host 192.168.10.201 ******** timeout 10 > aaa-server LOCAL protocol local > aaa authentication telnet console TACACS+ > aaa authentication ssh console TACACS+ > aaa accounting include telnet inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 > TACACS+ > aaa accounting include tcp/22 inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 > TACACS+ > aaa accounting include tcp/22 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 > TACACS+ > aaa accounting include telnet outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 > TACACS+ > no snmp-server location > no snmp-server contact > snmp-server community xxxxx > snmp-server enable traps > floodguard enable > sysopt connection permit-ipsec > sysopt connection permit-pptp > crypto ipsec transform-set kiodex esp-3des esp-md5-hmac > crypto ipsec transform-set riptech esp-3des esp-md5-hmac > crypto dynamic-map dynmap 10 set transform-set kiodex > crypto map outside 1 ipsec-isakmp > crypto map outside 1 match address 628broadway > crypto map outside 1 set peer x.x.x.x > crypto map outside 1 set transform-set kiodex > crypto map outside 10 ipsec-isakmp > crypto map outside 10 match address soc2800 > crypto map outside 10 set peer xxxx > crypto map outside 10 set transform-set riptech > crypto map outside 20 ipsec-isakmp dynamic dynmap > crypto map outside client authentication RADIUS > crypto map outside interface outside > isakmp enable outside > isakmp key ******** address x.x.x.x netmask 255.255.255.255 > isakmp key ******** address x.x.x.x netmask 255.255.255.255 > isakmp identity address > isakmp policy 10 authentication pre-share > isakmp policy 10 encryption 3des > isakmp policy 10 hash md5 > isakmp policy 10 group 2 > isakmp policy 10 lifetime 86400 > vpngroup exovpn address-pool vpn > vpngroup exovpn dns-server 192.168.10.156 192.168.10.157 > vpngroup exovpn wins-server 192.168.10.200 > vpngroup exovpn default-domain kdx.int > vpngroup exovpn split-tunnel exovpn > vpngroup exovpn idle-time 900 > vpngroup exovpn password ******** > telnet timeout 10 > ssh 192.168.10.0 255.255.255.0 inside > ssh timeout 10 > console timeout 0 > vpdn group exo-pptp accept dialin pptp > vpdn group exo-pptp ppp authentication mschap > vpdn group exo-pptp ppp encryption mppe auto > vpdn group exo-pptp client configuration address local vpn > vpdn group exo-pptp client configuration dns 192.168.10.156 > 192.168.10.157 > vpdn group exo-pptp client configuration wins 192.168.10.200 10.0.0.10 > vpdn group exo-pptp client authentication aaa RADIUS > vpdn group exo-pptp pptp echo 60 > vpdn enable outside > terminal width 80 > | |||||||||||||||||||||||||||||||
Posted by sampark on May 24, 2006, 7:21 am
Please log in for more thread options Hi,
The reason you should not have the same acl for nonat, crypto and split tunnel because they all serve different purposes. The idea is to put all the things in one acl and apply it to different commands, could be a shortcut however it leads to alot of problems when the configuration starts to grow. So, if you have a lan to lan tunnel and VPN clients terminating and only one acl acting as nonat,crypto and split will cause problems. The PIX will get the traffic destined for VPN clients it will hit the inside interface, based on the crypto map priorities it will start checking the SPD, if you have VPN client policy greater then lan to lan you will have trouble in this phase, the spd will say ok, I found the policy for the traffic in L2L (because you specified the traffic in one acl) and if the policy number of L2L is higher than dynamic crypto the traffic will go to L2L rather VPN. In this case you will feed too much traffic to the L2L tunnel (which is getting discarded at the other end, and if you break the tunnel it will not come up because of a policy mismatch on the otherside) and your VPN client will starve. Coming back to the problem: access-list 628broadway permit ip 192.168.0.0 255.255.0.0 10.0.0.0 > 255.255.0.0
You have the same acl in nonat and crypto.
> access-list 628broadway permit ip 192.168.0.0 255.255.0.0 172.16.1.0 > 255.255.255.0 You are feeding all the traffic to the tunnel and your VPN client is starving. To check this you can connect with the VPN client and start pinging a server come to the PIX and run sh access-list 628broadway and notice the coutners Also, show crypto ipsec sa command's encry and decy should be balanced -- for 3 pings received (decrypted) should have 3 echo-responses (encrypted) You will notice that your encry counter is increasing and decry counter will stay constant. To double check use this: sh crypto ipsec sa will show you two sa's to the remote side one from 192.168.0.0/16 going to 10.0.0.0/16 and one from 192.168.0.0/16 to 172.16.1.0/24 ... this sa will have no value and if you turn the debugs on you will notice that when the tunnel is trying to comeup it is reporting proxy identities not found. It is in this SA you will find encry counters increasing. Your traffic is just going to oblivion. Based on the above configuration you should only have one sa from 192 address going to 10/16 address. Please create different acls for nonat, crypto and split. Please tell us if this is working. -Vikas | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| vpngroup to pix515 | May 18, 2006, 5:57 pm |
| vpngroup to pix515 (repost) | June 7, 2006, 10:30 am |
| vpngroup to pix515 (repost 2) | June 21, 2006, 3:58 pm |
| PIX - VPNgroup statistics. | February 9, 2006, 9:27 am |
| VPNGROUP password | September 22, 2006, 2:04 pm |
| How to log or account PIX vpngroup connections? | December 13, 2005, 5:05 am |
| VPNGROUP command help with PIX 506e | September 1, 2006, 12:32 pm |
| Cisco PIX 501 vpngroup user need to be assigned a static IP | February 5, 2007, 1:59 pm |
| How to rename a vpngroup in Cisco PIX 515e firewall | September 18, 2007, 12:50 pm |
| Help with DMZ on Pix515 | August 28, 2006, 5:03 am |
| 2 ISP on PIX515 | November 25, 2005, 5:03 am |
| Help! DMZ on Pix515 | October 6, 2006, 6:16 am |
| PPTP VPN through PIX515 | January 25, 2006, 8:02 am |
| VPNclient and PIX515. | January 11, 2007, 7:01 am |
| Pix515 and Activesync | February 9, 2007, 9:27 pm |
vpngroup to pix515
Yahoo!
Windows Live
del.icio.us
digg
Netscape
