Hi, I have a problem to get VPN connection from a pix 501 to another pix 501. I can't see the error in this config:
interface ethernet0 100basetx interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password lhSmIyUoB09JU/08 encrypted passwd lhSmIyUoB09JU/08 encrypted hostname pix domain-name X.local fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol pptp 1723 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list acl_out permit icmp any any access-list inside_outbound_nat0_acl permit ip x.x.x.x 255.255.255.0 x.x.x.x 255.255.255.0 access-list outside_cryptomap_20 permit ip x.x.x.x 255.255.255.0 x.x.x.x 255.255.255.0 pager lines 24 logging on logging monitor errors mtu outside 1500 mtu inside 1500 ip address outside x.x.x.x 255.255.255.0 ip address inside x.x.x.x 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location x.x.x.x 255.255.255.0 outside pdm location x.x.x.x 255.255.255.255 inside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list inside_outbound_nat0_acl nat (inside) 1 0.0.0.0 0.0.0.0 0 0 route outside 0.0.0.0 0.0.0.0 x.x.x.x timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http x.x.x.x 255.255.255.0 outside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set myset esp-des esp-md5-hmac crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto ipsec transform-set Test esp-3des esp-md5-hmac crypto map outside_map 20 ipsec-isakmp crypto map outside_map 20 match address outside_cryptomap_20 crypto map outside_map 20 set peer x.x.x.x crypto map outside_map 20 set transform-set Nordalen crypto map outside_map interface outside isakmp enable outside isakmp key ******** address x.x.x.x netmask 255.255.255.255 no-xauth no-config-mode isakmp peer ip x.x.x.x no-xauth no-config-mode isakmp identity address isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 telnet x.x.x.x 255.255.255.0 inside telnet timeout 5 ssh x.x.x.x 255.255.255.255 outside ssh timeout 5 console timeout 0Is there anyone who can see the error here?
Leif
