I'm trying to connect a Cisco 1841 to Sonicwall 170.
The tunnel is establishing successfully, but I can't ping computers from any LAN to the other side of the tunnel.
When running Tunnel Diagnostics on Cisco SDM I get the following report:
------------------------------------------------------------ VPN Troubleshooting Report Details
Router Details
Attribute Value Router Model 1841 Image Name c1841-advsecurityk9-mz.124-5.bin IOS Version 12.4(5)
Test Activity Summary
Activity Status Checking the tunnel status... Up
Test Activity Details
Activity Status Checking the tunnel status... Up Encapsulation :0 Decapsulation :0 Send Error :0 Received Error :0
Troubleshooting Results Failure Reason(s) A ping with data size of this VPN interface MTU size and 'Do not Fragment' bit set to the other end VPN device is failing. This may happen if there is a lesser MTU network which drops the 'Do not fragment' packets
Recommended Action(s)
1)Contact your ISP/Administrator to resolve this issue. 2)Issue the command 'crypto ipsec df-bit clear' under the VPN interface to avoid packets drop due to fragmentation.------------------------------------------------------------
On the Sonicwall side, I see this message whenever I try to access the other side: Message - "Malformed or unhandled IP packet dropped" Source - , 0, WAN Destination - Notes - IP Protocol 51"
Do you have any ideas what can I do to fix the tunnel?
Thanks a lot in advance.
Amit Gatenyo
