i've problems building up an vpn tunnel from a notebook to my soho 91. I'm newbee, sorry for that, but here i post my config and it will be fine, if someone can check it.
Thanks Chris
------------------------ cisco(config)#do sh conf Using 2639 out of 131072 bytes ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname cisco ! boot-start-marker boot-end-marker ! enable secret 5 XXX ! username XXX password 0 XXX username CRWS_Giri privilege 15 password 0 XXX aaa new-model ! ! aaa authorization network hw-client-groupname local aaa session-id common ip subnet-zero no ip source-route ip dhcp excluded-address 192.168.0.1 ip dhcp excluded-address 192.168.0.1 192.168.0.49 ip dhcp excluded-address 192.168.0.100 192.168.0.254 ! ip dhcp pool CLIENT import all network 192.168.0.0 255.255.255.0 default-router 192.168.0.1 lease 0 2 ! ! ip name-server 195.158.xxx.xxx ip name-server 195.158.xxx.xxx ! ! ! ! ! crypto isakmp policy 1 encr 3des authentication pre-share group 2 crypto isakmp client configuration address-pool local dynpool ! crypto isakmp client configuration group USERID1 key PASSWORD dns 192.168.0.1 pool dynpool acl 199 ! crypto isakmp client configuration group USERID2 key PASSWORD dns 192.168.0.1 pool dynpool acl 199 ! ! crypto ipsec transform-set transform-1 esp-3des esp-sha-hmac ! crypto dynamic-map dynmap 1 set transform-set transform-1 reverse-route ! ! crypto map dynmap isakmp authorization list hw-client-groupname crypto map dynmap client configuration address respond crypto map dynmap 1 ipsec-isakmp dynamic dynmap ! ! ! interface Ethernet0 ip address 192.168.0.1 255.255.255.0 ip nat inside ip tcp adjust-mss 1452 ! interface Ethernet1 no ip address duplex auto pppoe enable pppoe-client dial-pool-number 1 crypto map dynmap ! interface Dialer1 ip address negotiated ip mtu 1492 ip nat outside encapsulation ppp ip tcp adjust-mss 1452 dialer pool 1 dialer-group 1 ppp authentication chap pap callin ppp chap hostname *** ppp chap password 0 *** ppp pap sent-username *** password 0 **** ppp ipcp dns request ppp ipcp wins request ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ip http server no ip http secure-server ! ip nat inside source list 102 interface Dialer1 overload ! ! access-list 102 permit ip 192.168.0.0 0.0.0.255 any access-list 199 permit ip 192.168.0.0 0.0.0.255 any dialer-list 1 protocol ip permit ! control-plane ! ! line con 0 no modem enable transport preferred all transport output all line aux 0 transport preferred all transport output all line vty 0 4 exec-timeout 120 0 length 0 transport preferred all transport input all transport output all ! scheduler max-task-time 5000 end
