Sorry if I start a new threat, is I explained I have problems connecting with vpn client to my inside network, I connect but the client sends and not recieves packets . I checked with other client that works, and comparing both logs I could see, before enabling the Virtual adapter this eror :
MODE_CFG_REPLY: MODECFG_UNITY_SPLIT_INCLUDE attribute with no data to PIX
I noticed that the tunnel doesn't enable as transparent tunnel, in stadistics there's no link to the network it's all 0.0.0.0 .
Here's again a bit of my config hope some one has intuition about this.
access-list split_tunnel_ac permit ip X.Y.1.0 255.255.255.0 172.16.1.0
255.255.255.0 access-list split_tunnel_ac permit icmp X.Y.1.0 255.255.255.0 172.16.1.0 255.255.255.0ip local pool vpndkm_pool 172.16.1.1
global (outside) 1 interface global (intf2) 1 interface nat (inside) 0 access-list nonat_acl nat (inside) 1 0.0.0.0 0.0.0.0 0 0 nat (intf2) 1 0.0.0.0 0.0.0.0 0 0
vpngroup vpndecom address-pool vpndecom_pool vpngroup vpndecom dns-server X.Y.1.15 vpngroup vpndecom default-domain valdisme.net vpngroup vpndecom split-tunnel split_tunnel_ac vpngroup vpndecom idle-time 1800 vpngroup vpndecom password ********
