Cisco Systems vpdn problem after upgrading to 12.3(14)
Subject Author Date
vpdn problem after upgrading to 12.3(14) John Rennie 07-12-05
Posted by John Rennie on July 12, 2005, 7:53 pm
I been using the attached vpdn config on Cisco 837s for ages and it's always
worked. However after upgrading a 837 to IOS 12.3(14) I can make a VPN
connection to the router but I can only ping the router and not anything else
on the remote network. If I switch back to an older IOS e.g. 12.3(7) it works,
but when I switch to 12.3(14) it stops again. This is with exactly the same
config file.
Any ideas? This one has me baffled.
JR
Config is (local network is 192.168.1.0/24):
vpdn enable
vpdn-group pptp
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
exit
exit
interface Virtual-Template1
ip unnumbered Ethernet0
peer default ip address pool default
ppp encrypt mppe auto
ppp authentication ms-chap
ip local pool default 192.168.1.224 192.168.1.239
Posted by Uli Link on July 12, 2005, 10:26 pm
> config file.
> JR
> vpdn enable
> vpdn-group pptp
> accept-dialin
> protocol pptp
> virtual-template 1
> exit
> exit
NAT, FW, AAA ?
Uli
Similar ThreadsPosted
vpdn problem after upgrading to 12.3(14) July 12, 2005, 7:53 pm
vpdn problem after upgrading to ios 12.3(14) July 18, 2005, 6:24 pm
Catalyst and VPDN. October 2, 2006, 5:34 am
VPDN Enable December 1, 2006, 10:10 am
PIX 501 vpdn debug help December 11, 2006, 10:15 pm
vpdn 6500 May 30, 2007, 10:14 am
Split tunneling with vpdn August 21, 2005, 2:42 am
How to disconnect VPDN user? June 22, 2005, 11:05 am
Multiple VPDN PPTP Groups on PIX December 14, 2005, 11:29 am
AS5300 VPDN and local auth March 27, 2007, 10:28 am
Ho to prevent vpdn users to access router ? October 16, 2006, 6:44 am
vpdn-config kills leased-line with ppp ??? November 11, 2006, 4:49 pm
Reky Failure XP l2tp/ipsec client and vpdn July 27, 2006, 10:15 am
VPDN L2TP pb for routing on virtual acces interface July 13, 2007, 1:39 pm
Rekey failure between Windows XP L2TP?IPSec and Cisco vpdn July 27, 2006, 10:18 am
