VOIP GSM GATEWAY - HG-4000 SERIES
Hypermedia Systems VoIP GSM Gateway for UMTS, GSM, CDMA and E1 / T1-PRI are the leading professional equipment for total connectivity solutions. The HyperGateway VoIP GSM Gateway line of products provides a tailor-made solution for SMEs (small and medium-sized enterprises), alternative carrier call termination and for call origination providers. One of Hypermedia VoIP products which have been recently launched, called HG-4000vs, also belongs to the Gateway family. HG-4000vs supports H.323. It is a complementary product to H.323-based IP equipments and supports up to 72 GSM ports. By using HG-4000vs there is no need for any external VoIP Gateways such as Cisco or Quintum. HG-4000vs VoIP GSM Gateway main features: · From 16 to 72 GSM ports · Up to 288 SIM cards · Advanced LCR and routing groups · IP address and DDI pattern restrictions · Remote pre-paid SIM recharge · Integrated antenna splitter · GSM worldwide use (850MHz / 1,800MHz / 1,900MHz) · Redounded power supply · WEB management and control The HG-4000vs VoIP GSM Gateway fixed cellular terminal can be used not only as a GSM Gateway but also for UMTS and CDMA (850 / 1900). For more information on this company:
