Hello, I have recently installed a Cisco 3750 on my network to give me the ability to create VLAN's to segment my POS system from the rest of my network. I need to configure helper addresses in the switch to relay DHCP from one segment to another. I am copying the current config (no helper addresses) and what I think is the proper commands to configure the helpers. My question is does it look correct? Here is the current config followed by the helper address commands:
! version 12.2 no service pad service timestamps debug uptime service timestamps log datetime no service password-encryption service sequence-numbers !
no aaa new-model clock timezone UTC -6 clock summer-time UTC recurring switch 1 provision ws-c3750g-12s system mtu routing 1500 udld aggressive
ip subnet-zero ! ! mls qos map cos-dscp 0 8 16 26 32 46 46 56 ! ! macro global description cisco-global errdisable recovery cause link-flap errdisable recovery interval 60 no file verify auto ! spanning-tree mode rapid-pvst spanning-tree loopguard default spanning-tree extend system-id ! vlan internal allocation policy ascending ! interface GigabitEthernet1/0/1 ! interface GigabitEthernet1/0/2 ! interface GigabitEthernet1/0/3 ! interface GigabitEthernet1/0/4 switchport access vlan 10 switchport mode access ! interface GigabitEthernet1/0/5 ! interface GigabitEthernet1/0/6 ! interface GigabitEthernet1/0/7 switchport trunk encapsulation dot1q switchport mode trunk macro description cisco-switch auto qos voip trust spanning-tree link-type point-to-point ! interface GigabitEthernet1/0/8 ! interface GigabitEthernet1/0/9 ! interface GigabitEthernet1/0/10 ! interface GigabitEthernet1/0/11 ! interface GigabitEthernet1/0/12 switchport trunk encapsulation dot1q switchport mode dynamic desirable ! interface Vlan1 ip address 172.25.2.26 255.255.254.0 ! interface Vlan10 ip address 172.25.4.10 255.255.255.0 ! ip default-gateway 172.25.2.2 ip classless ip http server ! ! control-plane ! !
end
And the helper address commands:
TSFF-CORE#conf t TSFF-CORE(config)#int GigabitEthernet1/0/4 TSFF-CORE(config-if)#ip helper-address 172.25.2.10 TSFF-CORE(config-if)#exit TSFF-CORE(config)#exit TSFF-CORE#wr mem
TSFF-CORE#conf t TSFF-CORE(config)#int GigabitEthernet1/0/12 TSFF-CORE(config-if)#ip helper-address 172.25.4.20 Server TSFF-CORE(config-if)#ip helper-address 172.25.4.21 Server TSFF-CORE(config-if)#ip helper-address 172.25.4.22 Server TSFF-CORE(config-if)#ip helper-address 172.25.4.30 Register TSFF-CORE(config-if)#ip helper-address 172.25.4.31 Register TSFF-CORE(config-if)#ip helper-address 172.25.4.32 Register TSFF-CORE(config-if)#ip helper-address 172.25.4.33 Register TSFF-CORE(config-if)#ip helper-address 172.25.4.34 Register TSFF-CORE(config-if)#ip helper-address 172.25.4.35 Register TSFF-CORE(config-if)#ip helper-address 172.25.4.36 Register TSFF-CORE(config-if)#exit TSFF-CORE(config)#exit TSFF-CORE#wr mem
