I just received a C2960S-24TS-L, and discovered that it doesn't understand the "switchport trunk encapsulation dot1q" interface command. I did a Web search, and found a response about the fact that this was unrecognized because this model of switch only supports dot1q encapsulation, so the command was unnecessary. Is this accurate? I want to make sure the "vlan trunking protocol" is configured correctly before I put the switch into production.
Thanks, Mike
