Cisco Systems vlan translation - cheat
Subject Author Date
vlan translation - cheat flamer die.spam@hotmail.com 06-30-09
Posted by flamer die.spam@hotmail.com on June 30, 2009, 12:36 am
This is my setup:
Site a:
interface GigabitEthernet5/2
switchport
switchport trunk encapsulation dot1q
switchport trunk native vlan 2500
switchport trunk allowed vlan 444,333
switchport mode trunk
site b:
interface Gi0/1
switchport trunk native vlan 123
interface Fa0/1
switchport access vlan 123
switchport mode access
what im trying to do, is have a edge port in vlan 123, go out a trunk
port (set as native vlan so it should strip its tag) come in on the
other port untagged (in native vlan 2500) so it should be tagged as
2500. hence it should be a fairly straight forward one to one vlan
translation.
site b switch doesnt support system extended vlan ID's and that
particular vlan is a must. anyways, on switch A I have 5 mac addresses
in that vlan, on switch B, doing show mac-address-table int g0/1 I
can't see any mac's from anything other than 444,333 so it doesnt
appear to be working.
any ideas?
Flamer.
Posted by flamer die.spam@hotmail.com on June 30, 2009, 12:38 am
I think one of the issues is that im running PV-RSTP. so if I dont
"trunk allow" that vlan on the port that vlan is forwarded on that
port. and if I do add it on the port at the same time as its a native
vlan im not sure it will still add/strip the dot1q tag.
Posted by brink on July 2, 2009, 4:37 am
On Jun 30, 6:36=A0am, "flamer die.s...@hotmail.com"
..... straight forward one to one vlan translation....
On the 6500s there is a "switchport vlan mapping" command which does
just that, and might be usable for your situation.
Unfortunately support is dependent on the module port asic and it
seems it is not usable on most of the newer hardware. If your
hardware does support it : it works per port asic, meaning the
mapping will be applied to ALL ports on that asic. Just how many ports
that would be is again hardware dependent, but there is an "enable"
command per port. I've used this once and it worked just fine, and
yes, I've also used external links between two ports.
Luck, Frans
Similar ThreadsPosted
vlan translation - cheat June 30, 2009, 12:36 am
Dot1Q Tunneling and VLAN Translation November 8, 2006, 2:37 pm
Are Cisco Exam candidates forced to cheat? June 15, 2007, 1:13 pm
Nat Translation June 2, 2006, 1:56 pm
Re: VPN with NAT translation June 24, 2005, 10:48 am
IP translation - It's possible? May 8, 2007, 4:53 pm
PIX translation November 21, 2007, 2:06 am
Dynamic Outside Translation October 17, 2005, 4:29 pm
Using Cisco PIX without translation? November 9, 2005, 1:35 am
T1/ethernet translation August 9, 2006, 10:02 am
Static Translation September 16, 2006, 2:28 pm
translation rule February 9, 2007, 10:51 am
PIX 535 firewall translation January 26, 2008, 10:29 pm
Translation between router July 14, 2008, 11:08 am
Cisco PIX NAT Translation August 8, 2008, 3:25 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
