I am setting up VLANs for each floor plus one for the servers. All the servers will be connected to a separate switch, which is connected to a 4507 that will will do all the routing.
- Should the server switch ports be configured as access or trunk?
- Whatever VLANs are carried by a trunk, do those VLANs need to be configured on the switches on both sides of the trunk? For example, none of the floor switches are directly connected to the server switch. Do the floor switches need to be configured with the server VLAN?
