VLAN on catalyst WS-C2916M-XL
Does this model with c2900XL-hs-mz-112.8.12-SA6 image support 802.1q vlan tagging? If yes, how to enable it ?
rzirzi
rzirzi
It would seem so according to
Did this model have an enterprise model and a desktop model too like the WS-C2924XL did?
Ie. the full part number WS-C2924-EN-XL supported VLAN trunking, while the full part number WS-C2924-A-XL does not support VLAN trunking, and you had to buy the upgrade up to the Enterprise version to get it to do VLAN trunking. Since these switches have been EOL'd for years and years, I doubt you could buy that license upgrade any longer.
Doug McIntyre
Full part number is at the topic this post: WS-C2916M-XL Does it support 8021.q? how to enable it?
rzirzi
rzirzi
Hi rzirzi,
Catalyst 2900 series XL switches support the following trunking methods for transmitting VLAN traffic over 100BaseT and Gigabit Ethernet ports:
Inter-Switch Link (ISL)
IEEE 802.1Q
Configuring a Trunk Port
This section describes how to use the CLI to configure an ISL or IEEE
802.1Q trunk port, how to define the VLANs that can use a port, and how to disable a trunk port.
Sincerely,
Brad Reese Cisco IOS Software - Compatible Partner Matrix by Technology
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Global Cisco Systems Pre-Sales Support
www.BradReese.Com
Thank you, but still i don't know why my switch does not support 802.1q, could you help me please? Some screenshots from console:
Switch>ena Switch#sh ver Cisco Internetwork Operating System Software IOS (tm) C2900XL Software (C2900XL-HS-M), Version 11.2(8.12)SA6, MAINTENANCE INTERIM SOFTWARE Copyright (c) 1986-1904 by cisco Systems, Inc. Compiled Fri 09-Apr-04 19:46 by antonino Image text-base: 0x00003000, data-base: 0x0020E310
ROM: Bootstrap program is C2900XL boot loader
Switch uptime is 0 minutes System restarted by power-on System image file is "flash:c2900XL-hs-mz-112.8.12-SA6.bin", booted via
cisco WS-C2916M-XL (PowerPC403GA) processor (revision 0x11) with 4096K/640K bytes of memory. Processor board ID 0x0C, with hardware revision 0x00 Last reset from power-on
Processor is running Enterprise Edition Software Cluster member switch capable
16 Ethernet/IEEE 802.3 interface(s)
Switch#conf t Enter configuration commands, one per line. End with CNTL/Z. Switch(config)#int fastether 0/1 Switch(config-if)#switchport mode trunk ^ % Invalid input detected at '^' marker.
Switch(config-if)#switchport mode ? access Set trunking mode to ACCESS unconditionally multi Set trunking mode to multi-VLAN mode
best regards rzirzi
rzirzi
Hi rzirzi,
Apologize that BradReese.Com has no answer for you.
Please contact your local Cisco TAC Representative in Poland for assistance:
Sincerely and with apology,
Brad Reese Cisco Authorized Distributors Worldwide
www.BradReese.Com
WS-C2916M-XL is the only 4 MB switch that supports trunking at all, but the table in "Important Notes" could be interpreted as indicating that 802.1Q trunking is supported on the device only in Standard Edition and not in Enterprise Edition (which would likely be tighter on memory.).
The table there does imply that with your release you should be able to do ISL trunking.
Walter Roberson
