Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on September 29, 2006, 6:41 pm
Please log in for more thread options it can be used. Also I am interested in knowing if I can change the native VLAN from 1 to 2 since we use foundry equipment and our native vlan is 2. Regards, pat | ||||||||||||||||
Posted by www.BradReese.Com on September 29, 2006, 7:13 pm
Please log in for more thread options The Virtual-Dot11Radio interface is used to indicate whether or not there are any clients associated to a given access point or radio within that access point. When clients are associated, the Virtual-Dot11Radio interface is up; when there are no clients associated, it shows down.. Use the infrastructure-client configuration interface command to configure a virtual interface for a workgroup bridge client. Use the no form of the command to disable the workgroup bridge client virtual interface. This is dynamically created when the AP is configured for infrastructure client mode. When debugging the virtual interface the management traffics are not included. http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_command_reference_chapter09186a008041757f.html#wp2455938 If the native VLAN on the switchport is configured as VLAN 12 and on the AP, the native VLAN is configured as VLAN 1, then when the AP sends a frame on its native VLAN to the switch, the switch considers the frame as belonging to VLAN 12 since the frames from the native VLAN of the AP are untagged. This causes confusion in the network and results in connectivity problems. The same happens when the switchport forwards a frame from its native VLAN to the AP. The configuration of native VLAN becomes even more important when you have a Repeater AP setup in your wireless network. You cannot configure multiple VLANs on the Repeater APs. Repeater APs support only the native VLAN. Therefore, the native VLAN configuration on the root AP, the switch port to which the AP is connected, and the Repeater AP, must be the same. Otherwise traffic through the switch does not pass to and from the Repeater AP. Using VLANs with Cisco Aironet Wireless Equipment: http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801d0815.shtml Hope this helps. Brad Reese BradReese.Com - Cisco Repair http://www.bradreese.com/cisco-big-iron-repair.htm 1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Power Supply Headquarters http://www.bradreese.com/cisco-power-supply-inventory.htm | ||||||||||||||||
virtual-dot11radio what for?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
