Can someone recommend a small router that can support at least three L3 VLAN's and a single WAN port? We are looking at an inexpensive router that we may be able to add to our product.
Thanks in advance!
Thanks in advance!
Perhaps a 1700 series router? You can find them on ebay for cheap (less than $75).
- Blob
Thanks Blob:)
It depends on what you want to do with the router. When you want more than a few megabit/s performance I would not recommend a 1700...
An 87x or 88x, although a lower model line, will outperform those old boxes. I don't know US pricing but I expect them to be about $500.
TOM,
I have found the 871 and 871W to be quite ideal and a good bang for your buck. Have to agree, you need to know what you want out of the device. There are even elchepo Linksys that has the RV082 with VLAN allocation... So look at your requirements and look at budget... 1700 might be too much
At the end of the day only you know what you want...
Regards,
Vincent
Thanks Vincent!
So true...
Note that the 871/871W , while it states supports 5 VLANs, in practice you can only use 1 because there are 4 hardcoded VLANs you can't remove.
There is supposed to be some additional software you can get to enable more vlans. but I haven't been able to put my hands on it.
