Using VMware when Cisco VPN client is connected
Hello,
When I am working from home I have to use Cisco VPN Client (ver
4.8.02.0010) to access the company network. This works fine with the host operative system WinXP SP2.
However, in my work I uses VMware quite a lot and have IBM software installed on the Guest OS (WinXP SP2). The host OS have IBM development environment installed that has to communicate with Guest system via TCP/IP but I can't get this working.
I know that the purpose of VPN is to secure a tunnel from my machine to company network (and block other network trafic) but the VMware is part of my machine and should be trusted.
I have tested with different configurations, without any success.
Do you have any hint/workaround to get this working? Is it worth to test more configurations or is out of luck?
Best Regards Joacim
4integration
Are you running NAT to the VM instance, i.e. its represented externally by your physical NIC address, or are you running in bridge mode?
Trendkill
The default (and current) setup is NAT but have tested with Brigde and Host-Only.
4integration
I'll bet its natt'ing to your physical address, rather than the logical VPN address assigned by the concentrator. If this is the issue, I'm not really sure how you would get this to work. Can you still get to local hosts (ie your home router, etc) with the VM instance?
Trendkill
Hello, 4integration! You wrote on Tue, 30 Sep 2008 11:55:47 -0700 (PDT):
i> When I am working from home I have to use Cisco VPN Client (ver i> 4.8.02.0010) to access the company network. This works fine with the i> host operative system WinXP SP2.
i> However, in my work I uses VMware quite a lot and have IBM software i> installed on the Guest OS (WinXP SP2). The host OS have IBM i> development environment installed that has to communicate with Guest i> system via TCP/IP but I can't get this working.
i> I know that the purpose of VPN is to secure a tunnel from my machine i> to company network (and block other network trafic) but the VMware is i> part of my machine and should be trusted.
i> I have tested with different configurations, without any success.
i> Do you have any hint/workaround to get this working? i> Is it worth to test more configurations or is out of luck?
"split-tunnel" on server side ciscoEasyVPN?
Andrew Lutov
Hello, Andrew!
AL> "split-tunnel" on server side ciscoEasyVPN?
or on client-side: "Transport" - "Allow Local LAN Access"
(not sure).
Andrew Lutov
Hello, Andrew!
AL>> "split-tunnel" on server side ciscoEasyVPN?
AL> or on client-side: AL> "Transport" - "Allow Local LAN Access"
Allowing Local LAN Access In a multiple-NIC configuration, Local LAN access pertains only to network traffic on the interface on which the tunnel was established. The Allow Local LAN Access parameter gives you access to the resources on your local LAN (printer, fax, shared files, other systems) when you are connected through a secure gateway to a central-site VPN device. When this parameter is enabled and your central site is configured to permit it, you can access local resources while connected. When this parameter is disabled, all traffic from your Client system goes through the IPSec connection to the secure gateway.
To enable this feature, check Allow Local LAN Access; to disable it, uncheck the check box. If the local LAN you are using is not secure, you should disable this feature. For example, you would disable this feature when you are using a local LAN in a hotel or airport.
A network administrator at the central site configures a list of networks at the Client side that you can access. You can access up to 10 networks when this feature is enabled. When Allow Local LAN Access is enabled and you are connected to a central site, all traffic from your system goes through the IPSec tunnel except traffic to the networks excluded from doing so (in the network list).
When this feature is enabled and configured on the VPN Client and permitted on the central-site VPN device, you can see a list of the local LANs available by looking at the Routes table.
To display the Routes table, use the following procedure:
1.. Display the Status menu and choose Statistics. 2.. Choose Route Details from the Statistics dialog box.
The routes table shows local LAN routes, which do not traverse and IPSec tunnel and secured routes, which do traverse an IPSec tunnel to a central-site device. The routes in the local LAN routes column are for locally available resources.
Note This feature works only on one NIC card, the same NIC card as the tunnel.
Note While connected, you cannot print or browse the local LAN by name; when disconnected, you can print and browse by name. For more information on this limitation refer to VPN Client Administrator Guide, Chapter 1.
Andrew Lutov
