Hopefully this will save someone some grief. After much messing around with junk that did not work, I finally found a USB serial port that works properly and is fully-functional. The break function even works for password recovery on Cisco routers.
Manufacturer: BAFO Technologies Model: BF-810
That is the 9 pin version. There is a 25 pin version which I assume works as well.
--- Mooron
