Cisco Systems unregistered TCP/UDP ports
Subject Author Date
unregistered TCP/UDP ports erik 09-04-08
Posted by erik on September 4, 2008, 3:32 am
I see traffic on my network to a number of unregistered TCP/UDP ports. Where
can I find a list with possible protocols that are using these ports (1535,
4889 and 8092)?
Posted by Lars Christensen on September 4, 2008, 4:54 am
Try
http://www.google.co.uk/search?hl=en&q=udp+tcp+port+1535&meta=
http://www.google.co.uk/search?hl=en&q=udp+tcp+port+4889&meta=
http://www.google.co.uk/search?hl=en&q=udp+tcp+port+8092&meta=
Regards,
Lars Christensen
Posted by Scott Perry on September 4, 2008, 9:19 am
The Internet Assigned Numbers Authority (IANA) is responsible for official
assignment of a TCP or UDP port to a known application.  That does not mean
that any software designer could create a program to use any unregistered
TCP or UDP port that they want.
There is a Wikipedia listing for common used TCP and UDP service ports:
     http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers
I did not easily find information about the three port numbers which you
listed.  That leads me to believe that they are not commonly associated with
any particular application or program.  Also keep in mind that only the
destination TCP or UDP port number is the relevant portion, not the source
port number.
Scott Perry
Indianapolis, IN
Posted by Tilman Schmidt on September 5, 2008, 9:21 am
erik schrieb:
Strictly speaking, every protocol is possible on every port. In order to
find out for sure what it is you'll have to look on the destination machine
what service is listening on the port. The picture is further complicated
by protocols that allocate ports dynamically.
Of course there are typical services for many ports. I have in the past had
good results looking up port numbers on the SANS Internet Storm Center's
"PortDetails" page at http://isc.sans.org/port.html . The ports you list,
however, didn't turn up anything interesting there.
HTH
T.
Please excuse my bad English/German/French/Greek/Cantonese/Klingon/...
Similar ThreadsPosted
unregistered TCP/UDP ports September 4, 2008, 3:32 am
871 and USB ports September 9, 2005, 11:58 am
ports in pix November 1, 2005, 6:44 pm
PIX & Ports August 18, 2006, 2:17 pm
QoS on some ports April 6, 2007, 8:23 am
PIX 501 LAN Ports May 5, 2008, 11:48 pm
ports May 11, 2010, 11:50 am
protected ports December 15, 2005, 2:06 pm
AUX/Consol ports April 13, 2006, 7:54 am
trunk ports September 1, 2006, 6:46 pm
NAT doesn't seem to work on all ports June 14, 2005, 5:29 pm
range of ports in ACL on PIX? June 16, 2005, 2:53 pm
LANs and ports September 7, 2006, 1:21 pm
VPN Firewall ports September 8, 2006, 11:09 am
firewall ports October 1, 2006, 9:37 pm
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
