Cisco Systems unable to authenticate via a c5400 when using PPP connection
Subject Author Date
unable to authenticate via a c5400 when using PPP connection FixitDave 06-08-06
Posted by FixitDave on June 8, 2006, 6:50 am
I'm trying to configure DialOut/IP utility to make an outbound DUN
connection to a remote site.
If you telnet to the 5400 on port 7001 you are able to dial out fine,
but it's as though I don't get authenticated on the 5400 when I to
connect with DUN.
very cut down version of the config is (if you need more, please ask);
aaa authentication login modemaccess local group tacacs+ none
aaa authentication ppp ppptac local group tacacs+ none
interface Serial7/0:15
no ip address
encapsulation ppp
dialer rotary-group 1
dialer-group 1
isdn switch-type primary-net5
isdn incoming-voice modem
isdn calling-number xxxx
no fair-queue
no cdp enable
ppp authentication chap pap callin
interface Group-Async0
ip unnumbered FastEthernet0/0
no ip mroute-cache
dialer in-band
dialer idle-timeout 900
async mode interactive
peer default ip address pool pool_dialup
group-range 1/00 1/107
line 1/00 1/107
exec-timeout 0 0
privilege level 0
no flush-at-activation
script activation dialstart
no vacant-message
login authentication modemaccess
no modem InOut
rotary 1
transport input all
autoselect during-login
autoselect ppp
GW-DIAL1#show debug
General OS:
AAA Authentication debugging is on
AAA Authorization debugging is on
PPP:
PPP authentication debugging is on
PPP protocol errors debugging is on
PPP protocol negotiation debugging is on
I try to connect and get the following output...
Jan 30 17:38:33.972 gmt: AAA/BIND(00000381): Bind i/f Async1/05
Jan 30 17:38:33.972 gmt: AAA/AUTHEN/LOGIN (00000381): Pick method list
'modemaccess'
Jan 30 17:38:34.532 gmt: AAA/AUTHOR (00000381): Method list id=3D0 not
configured. Skip author
Jan 30 17:38:52.081 gmt: AAA/BIND(00000382): Bind i/f Async1/05
Jan 30 17:38:52.081 gmt: AAA/AUTHEN/LOGIN (00000382): Pick method list
'modemaccess'
Jan 30 17:38:52.497 gmt: AAA/AUTHOR (00000382): Method list id=3D0 not
Output from the DialOut/IP trace...
11:47:00.667 COM7 : | Open
11:47:00.667 COM7 : | Current UART Settings:
11:47:00.667 COM7 : | Baud: 00115200
11:47:00.667 COM7 : | Framing: 08,N,1
11:47:00.667 COM7 : | RTSFlow: 1 CTSFlow: 1
11:47:00.667 COM7 : | DTR: 1 RTS: 0 CTS: 1 DSR: 1 CD: 0
11:47:00.667 COM7 : | CTS: 1 DSR: 1 CD: 0
11:47:00.667 COM7 : | Port open
11:47:00.667 COM7 : | Enable Telnet
11:47:00.667 COM7 : | Disable Telnet CR-padding
11:47:00.667 COM7 : | Enable DTR emulation (Unimodem)
11:47:00.667 COM7 : | Disable DCD emulation (pcAnywhere)
11:47:00.667 COM7 : | Enable user authentication
11:47:00.667 COM7 : | Connecting to server gw-dial1[7001]
11:47:00.667 COM7 : | Baud: 00009600
11:47:00.667 COM7 : | Framing: 07,E,1
11:47:00.667 COM7 : | FlushTX
11:47:00.667 COM7 : | FlushRX
11:47:00.714 COM7 : | Waiting to authenticate to server
11:47:00.808 COM7 : | Sent username to server
11:47:00.808 COM7 : | COM Port Control negotiated (RFC-2217)
11:47:01.059 COM7 : | Sent password to server
11:47:01.575 COM7 : =BB AT^M
11:47:01.590 COM7 : =AB AT^M
11:47:02.560 COM7 : | Site auth failed
11:47:02.685 COM7 : | FlushTX
11:47:02.685 COM7 : | DTR: 1
11:47:02.701 COM7 : =BB AT^M
11:47:04.704 COM7 : | FlushTX
11:47:04.704 COM7 : | DTR: 1
11:47:04.704 COM7 : =BB AT^M
11:47:06.706 COM7 : | FlushTX
11:47:06.706 COM7 : | DTR: 1
11:47:06.722 COM7 : =BB AT^M
11:47:08.724 COM7 : | FlushTX
11:47:08.724 COM7 : | DTR: 1
11:47:08.740 COM7 : =BB AT^M
11:47:10.742 COM7 : | FlushTX
11:47:10.742 COM7 : | DTR: 1
11:47:10.742 COM7 : =BB AT^M
11:47:12.745 COM7 : | FlushTX
11:47:12.745 COM7 : | DTR: 1
11:47:12.760 COM7 : =BB AT^M
11:47:14.763 COM7 : | FlushTX
11:47:14.763 COM7 : | DTR: 1
11:47:14.778 COM7 : =BB AT^M
11:47:16.781 COM7 : | FlushTX
11:47:16.781 COM7 : | DTR: 1
11:47:16.796 COM7 : =BB AT^M
11:47:18.799 COM7 : | FlushTX
11:47:18.799 COM7 : | FlushRX
Any help would be appreciated.
Regards
Dave
Similar ThreadsPosted
unable to authenticate via a c5400 when using PPP connection June 8, 2006, 6:50 am
PIX 525 Does Not Authenticate Password September 11, 2006, 5:16 am
authenticate host name September 15, 2006, 4:49 pm
Authenticate 5510 against AD November 20, 2007, 12:03 pm
AP 1232G authenticate against RAIDUS ( Win2k3 IAS) October 27, 2005, 5:43 am
Authenticate VPN3k-clients against AD group February 1, 2006, 2:52 pm
Suggestions on How to Authenticate? Passwords, Certs, SecureID or? November 25, 2008, 5:00 pm
Can 2600 Router ver. 12.3 use Radius Server to Authenticate Logon July 13, 2007, 3:30 pm
Failover and Load balancing with 1 Cable connection and one T1 connection on Cisco 2801 router November 13, 2006, 2:23 pm
VPN connection issue; no data passing after connection August 22, 2007, 11:37 am
PIX 501 unable to map port. Plx help August 30, 2006, 1:58 pm
unable to "lock" mac address March 20, 2006, 10:42 am
Unable to connect with router May 23, 2006, 9:24 pm
Unable to get VoIP QoS working on PIX March 27, 2007, 2:26 pm
Very odd that we're unable to get to Internet from PIX 506E April 10, 2007, 8:03 pm
