Cisco Systems two routers on the same lan
Subject Author Date
two routers on the same lan sali 06-30-09
Posted by sali on June 30, 2009, 10:39 am
i have cisco router to wan connection [only wan interface card], with my
internal lan being 10.10.0.x, router being 10.10.0.1, now i need additional
router to connect to adjacent building [with high speed etehrent lan] having
their lan on 10.20.0.x
is it possible to somehow attach additional router [for ex 10.10.0.2] with
net interface to connect my lan with this adjacent building?
i have read somewhere that there is some inter-router discovery protocol,
and that my default router [wan] may discover and redirect traffic to this
additional router, in case that subnet is required? of course, this my
router 10.10.0.1 should remain as default gateway
thnx
Posted by Rob on June 30, 2009, 1:03 pm
In your first router, configure a route to 10.20.0.x via gateway 10.10.0.2.
Make sure you have not turned off redirects.
All your client systems will send the traffic for 10.20.0.x via their
default gateway 10.10.0.1 (your first router), which will send it on via
its route to 10.10.0.2. But it will also send an ICMP redirect packet
to the client, which will then send the next packets directly to the
gateway 10.10.0.2.
This usually works quite well, but you have to beware that sometimes
such redirect packets are turned off or filtered in a firewall. In that
case all your traffic to 10.20.0.x will take an unnecessary hop via
your first router.
Of course you could also set a fixed route to 10.20.0.x via 10.10.0.2
in all your client systems. But that may be a lot of work and when
you change the network you may need to do it all over again.
Similar ThreadsPosted
2 routers one lan June 29, 2005, 4:44 pm
NAT-T and routers. October 3, 2006, 12:09 pm
No NAT between two routers June 28, 2007, 1:21 pm
VTP across routers March 6, 2008, 11:11 pm
Using RIP v2 between two routers December 20, 2008, 10:17 pm
DS3 routers February 6, 2009, 1:28 pm
two routers on the same lan June 30, 2009, 10:39 am
Help with used Cisco Routers September 17, 2005, 3:30 pm
2610XM routers and VPN September 26, 2005, 5:44 pm
802.11i for Cisco 870 routers December 26, 2005, 4:41 pm
ACL layer 2 on routers. January 24, 2006, 6:14 am
VPN termination on routers. January 31, 2006, 4:58 am
splitting ATM PVC between different routers April 19, 2006, 6:51 pm
LAN-to-LAN with ASA55xx or routers May 14, 2006, 6:14 pm
routers and certificates May 30, 2006, 8:20 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
