Cisco Systems turning off auto-negotiation on gigabit interface
Subject Author Date
turning off auto-negotiation on gigabit interface noah davids 01-27-08
Posted by noah davids on January 27, 2008, 11:36 am
It is my understanding that the gigabit spec requires auto-negotiation, so
what does turning it off really do?
Noah Davids
Serendipity is a function of bandwidth
E-mail: ndav1@cox.net
Web: http://members.cox.net/~ndav1
Posted by Trendkill on January 27, 2008, 11:51 am
> Noah Davids
> E-mail: nd...@cox.net
Well, technically auto-negotiation is only for slower than gig
settings, since a gigabit connection cannot be half-duplex. However,
and per Cisco Best Practices, either auto/auto or gig/gig is fine, so
long as you match on both sides. I have also noticed some NICs that
do not have a gig/full setting, and therefore you must go gig/gig. I
have also noticed other boxes that seem to have issues when
configuring auto on both ends. The bottom line is, match on both
sides, and look at vendor documentation to see what they recommend for
their specific device.
The above being said, I am not sure where you have seen that gig
requires auto negotiation, as that is not correct. Perhaps it is for
a specific server or hardware? Turning it off simply implies that the
speed and duplex is hard set, and is not negotiated on that side of
the configuration. Auto negotiation is required if the hardware/
server does not have gig/full as a set option, in which case both
sides would be configured to negotiate to the optimal setting.
Posted by stephen on January 27, 2008, 3:00 pm
so
> > Noah Davids
negotiate is needed on 1000M to sort out the wiring, master / slave etc for
1000 Base-T. It doesnt set the speed (unless the other end is slower), but
it does set up the interface.
However,
the reference comes from the IEEE standard - auto negotiation is a required
part of the standard for GigE 1000 Base-T, not just optional as it was with
100 Base-Tx.
remember that as part of setup on 1000 Base-T, the 2 ends negotiate to sort
out pairing etc, so this sort of makes sense.
as a practical issue, some devices REQUIRE a linked device to be using auto
at Gigabit, or they dont work, even with fibre ports.
For example, a recent wierdness trying to bring up fibre GigE links to a
Foundry MLX-4 turned out to be the SDH mux it was plugged into was set for
no negotiate, and the Foundry insists that auto is enabled.
the really annoying bit was that the MLX port had a "negotiate" option, but
the only allowed setting was "yes".
When we had a mismatch, the Foundry lit the green light against the
interface on the card, but no L3 traffic..... Serious head scratching until
we ignored the lights and went thru the logs.
i have other similar issues on GigE - so i suggest that if you have a GigE
or a 10/100/1000 device, you might need "auto".
Perhaps it is for
Regards
stephen_hope@xyzworld.com - replace xyz with ntl
Posted by Thrill5 on January 28, 2008, 12:27 am
>> so
>> Noah Davids
Actually the specification for 1000BaseT REQUIRES autonegotiation. But I
have seen issues where auto/auto did not work but this was always due to
driver issues on the device. Updating the driver on the PC/Server always
fixed the problem.
Posted by Trendkill on January 28, 2008, 5:58 am
> >> so
> >> Noah Davids
> fixed the problem.
After looking more in depth at the Best Practices, you are indeed
correct, although I was talking about specific speed/duplex settings
and did not realize there was a higher level term of 'autonegotiation'
for flow control and other interface settings (does not include
speed). Apparently auto-negotiation is what I was referring to, and
autonegotiation (without the hyphen) is the broader topic. Here is
the link, and here are some excerpts:
"Unlike autonegotiation with 10/100-Mbps FE, GE autonegotiation does
not involve the negotiation of port speed. Also, you cannot issue the
set port speed command in order to disable autonegotiation. GE port
negotiation is enabled by default, and the ports on both ends of a GE
link must have the same setting. The link does not come up if the
ports at each end of the link are set inconsistently, which means that
the exchanged parameters are different."
"The configuration of autonegotiation is much more critical in a GE
environment than in a 10/100 Mbps environment. Only disable
autonegotiation in these situations:
On switch ports that attach to devices that are not able to
support negotiation
Where connectivity issues arise from interoperability issues
http://www.cisco.com/en/US/products/hw/switches/ps700/products_white_paper09186a00801b49a4.shtml
http://www.cisco.com/en/US/tech/tk389/tk214/technologies_tech_note09186a0080094781.shtml
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af0.shtml
Similar ThreadsPosted
turning off auto-negotiation on gigabit interface January 27, 2008, 11:36 am
Troubleshooting Overruns on a Gigabit interface March 12, 2006, 1:17 pm
Cisco 7609 - optical gigabit interface December 16, 2006, 10:44 am
Autonegotiation time on a Cisco 5500 switch November 14, 2006, 5:33 pm
Using a Gigabit copper to Gigabit fiber media converter for an IDF May 3, 2006, 7:56 pm
Turning off the '?' in IOS December 17, 2005, 8:00 am
Gigabit WAN March 18, 2007, 5:30 am
Gigabit Throughput November 23, 2006, 12:42 am
Gigabit over 2 pair? July 4, 2007, 1:58 pm
Monitoring gigabit interfaces ? February 6, 2005, 2:39 pm
gigabit ethernet speed on 3550 October 24, 2006, 2:46 pm
new 6509 "Gigabit Ethernet x/x not a switching port" November 14, 2005, 8:42 am
Tunnel trafic in a MPLS , 1 Gigabit connection May 30, 2008, 1:25 am
Gigabit ethernet fiber optic set in 100Mbit on 6509 May 8, 2007, 4:14 am
Human priced 8 gigabit ports Cisco switch February 9, 2008, 4:41 am
