This is 2620 router, any ideas why it can be so high? It's killing my router. Thanks, Tom
19 2439020996 15073273 161821 60.48% 60.63% 60.55% 0 TTY Background- posted
19 years ago
19 2439020996 15073273 161821 60.48% 60.63% 60.55% 0 TTY BackgroundNo. Also this is weird, if I ping the router from the host on the same network I get response times like this:
5ms 1500ms 5ms 1500ms 5ms 1500msweird.
Any ideas, thanks, Tom
TTY Background
The TTY Background process is a generic process used by all terminal lines (console, aux, async, and so on). Normally there should not be any impact on the performance of the router since this process has a lower priority compared to the other processes that need to be scheduled by the Cisco IOS software.
If this process takes high CPU utilization, check whether "logging synchronous" is configured under "line con 0". One possible cause could be CSCdy01705 (registered customers only) .
CSCdy01705 Bug Details
Headline High cpu at process TTY Background Product all Model Component os Duplicate of Severity 3 Severity help Status Resolved Status help First Found-in Version 12.2(10A) All affected versions First Fixed-in Version 12.3(1.6), 12.3(1.6)T, 12.2(11)T09, 12.3(2.3)B,
12.2(21), 12.2(21.6), 12.2(21.5)S, 12.2(21.7)S, 12.1(21.3)E04, 12.3(7)XI, 12.2(20)S05, 12.1(21.4)EC, 12.2(18)S06, 12.2(15)BC02e Version help Release NotesA Cisco router may experience high cpu utilization at process TTY Background when the command "logging synchronous" is configured under line con 0.
The possible workaround is to remove the command "logging synchronous" from line con 0, however, this should only be performed during a scheduled maintenance window as the router could pause indefinitely just after removal of the command, possibly requiring a manual reboot of the router.
Do you have some type of dial backup or something?
One of the redudant links is a dialup....or you have a bug. I guess you would know if you have dialup links or not. Router generated packets are process swtiched. You might have a redundant link that's being hammered.
Also, are you debugging something? "no console logging" (no logging console??) may be in order.
I was able to get some downtime for the router. Reloaded and everything is back to normal just like MS Windows. :-)
Thank you, Tom
