All,
I have a 3750 switch that I am trying to upgrade the image on. My switvh IP address is 10.1.1.1 workstation is 10.1.1.2
all-filesystems List files on all filesystems bs: Directory or file name cns: Directory or file name flash1: Directory or file name flash: Directory or file name null: Directory or file name nvram: Directory or file name system: Directory or file name vb: Directory or file name xmodem: Directory or file name ymodem: Directory or file name
test#dir /all Directory of flash:/
2 -rwx 1275 Mar 1 1993 02:34:18 +00:00 config.text 3 -rwx 7268352 Mar 1 1993 03:02:05 +00:00 flash 4 -rwx 5 Mar 1 1993 02:34:18 +00:00 private-config.text 5 drwx 192 Mar 1 1993 00:07:38 +00:00 c3750-ipbase-mz.122-25.SEB 415998976 bytes total (1620480 bytes free) test#
test>
test>
test>
test>
test>
test>en test#copy tftp://10.1.1.3/c3750me-i5-mz.122-25.SEE.bin flash
Destination filename [c3750me-i5-mz.122-25.SEE.bin]?
Accessing tftp://10.1.1.3/c3750me-i5-mz.122-25.SEE.bin...
Loading c3750me-i5-mz.122-25.SEE.bin from 10.1.1.3 (via Vlan1): !!!!!!!!!!!!!OOO
!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!OO
OO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!
OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!
!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!
!!!!OOOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!
%Error writing flash:/c3750me-i5-mz.122-25.SEE.bin (No space left on device)
test#copy tftp flash ?
test#copy tftp flash Address or name of remote host [10.1.1.3]?
Source filename [c3750me-i5-mz.122-25.SEE.bin]?
!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!OOO
O!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!O
OOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!
!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!
!!!OOOO!!!!!!!!!!!!!OOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!!OOOO!!!!!!!!!!!!
test#sh ver Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version
12.2(25)SEB4, RELEASE SOFTWARE (fc1) Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 15:47 by yenanh
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR
E (fc4)
test uptime is 49 minutes System returned to ROM by power-on System image file is "flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.S
EB4.bin"
cisco WS-C3750-24TS (PowerPC405) processor (revision L0) with
118784K/12280K bytes of memory. Processor board ID CAT0948Z422 Last reset from power-on
1 Virtual Ethernet interface 24 FastEthernet interfaces 2 Gigabit Ethernet interfaces The password-recovery mechanism is enabled.512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:16:47:3C:AF:00 Motherboard assembly number : 73-9677-09 Power supply part number : 341-0034-01 Motherboard serial number : CAT094810D8 Power supply serial number : DAB09420JUU Model revision number : L0 Motherboard revision number : A0 Model number : WS-C3750-24TS-S System serial number : CAT0948Z422 Top Assembly Part Number : 800-25857-02 Top Assembly Revision Number : C0 Version ID : V05 CLEI Code Number : CNMV100CRE Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
- 1 26 WS-C3750-24TS 12.2(25)SEB4 C3750-IPBASE-M
Configuration register is 0xF
I even tried another way still no luck
test>
test>
test>
test>
test>
E (fc4)
EB4.bin"
Motherboard serial number Power supply serial number : DAB09420JUU
Version ID : V05
test# test#ar test#archive test#archive ? config Archive the running config
download-sw Download a new copy of software from a server
download-ucode Download a new copy of microcode from a server
tar List or extract files in a tar image
upload-sw Upload an existing copy of the software to a server
test#archive tar ? /create create a tar file /table List files in tar file /xtract Extract files in tar file
test#archive tar /create ? WORD Tar filename
test#archive tar /create test ? WORD Dir to archive files from
test#archive tar /create test test1 ?
WORD File or Dir
test#archive test#archive test#archive test#archive so test#archive so test#archive ? config Archive the running config
test#archive download ? % Unrecognized command test#archive download ? % Unrecognized command test#archive download-sw ? /force-reload Unconditionally reload system after successful sw upgrade
/imageonly Load only the IOS image(s)
/leave-old-sw Leave old sw installed after successful sw upgrade
/no-set-boot Don't set BOOT -- leave existing boot config alone
/no-version-check skip version check that prevents incompatible image
install /overwrite OK to overwrite an existing image
/reload Reload system (if no unsaved config changes) after
/safe Always load before deleting old version
flash1: Image file flash: Image file ftp: Image file http: rcp: Image file tftp: Image file
test#archive download-sw /ovwewrite ?
% Unrecognized command test#archive download-sw /overwrite ?
install /reload Reload system (if no unsaved con
flash1: Image file flash: Image file ftp: Image file http: Image file rcp: Image file tftp: Image file
test#archive download-sw /overwrite /reload ?
install flash1: Image file flash: Image file ftp: Image file http: Image file rcp: Image file tftp: Image file
test#$overwrite /reload tftp://10.1.1.3/c3750me-i5-mz.122-25.SEE.bin ?
Loading c3750me-i5-mz.122-25.SEE.bin from 10.1.1.3 (via Vlan1): !!!!!!!!!!!!!!!!
[OK - 8535177 bytes]Loading c3750me-i5-mz.122-25.SEE.bin from 10.1.1.3 (via Vlan1): !!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! [OK - 8535177 bytes]
examining image... %Tar checksum error in tftp://10.1.1.3/c3750me-i5-mz.122-25.SEE.bin %Error opening flash:update/info (No such file or directory) ERROR: Image is not a valid IOS image archive. test#$overwrite /reload tftp://10.1.1.3/c3750me-i5-mz.122-25.SEE.bin
