Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by jlmjlist on August 6, 2008, 9:38 am
Please log in for more thread options I can't get this to work and now wonder if it's even possible. If possible how do I config intermediate 2621 router to handle rspan traffic. I have RSPAN working on LAN. Thanks for any hints, etc. | |||||||||||||
Posted by Trendkill on August 6, 2008, 2:09 pm
Please log in for more thread options I don't think this is possible. The way a RSPAN works (from my old experience), is that a switch will copy each frame/packet into a special RSPAN VLAN. Then any node in any switch on that vlan, can 'sniff' the traffic. Of course we have to then understand that the RSPAN vlan would need to available in all switches (i.e. trunked). Unless you are doing l2 over the WAN, I don't see how this would work. Not to mention the major concerns I have about copying all LAN traffic to a particular node of VLAN over a limited bandwidth WAN. Not to say you don't know what you are doing (I'm sure you are aware of your network limitations), but I would be very careful in this circumstance. | |||||||||||||
Posted by Trendkill on August 6, 2008, 2:13 pm
> > If possible how do I config intermediate 2621 router to handle rspan > > traffic. > > I have RSPAN working on LAN. > > Thanks for any hints, etc. >
> I don't think this is possible. =A0The way a RSPAN works (from my old > experience), is that a switch will copy each frame/packet into a > special RSPAN VLAN. =A0Then any node in any switch on that vlan, can > 'sniff' the traffic. =A0Of course we have to then understand that the > RSPAN vlan would need to available in all switches (i.e. trunked). > Unless you are doing l2 over the WAN, I don't see how this would > work. =A0Not to mention the major concerns I have about copying all LAN > traffic to a particular node of VLAN over a limited bandwidth WAN. > Not to say you don't know what you are doing (I'm sure you are aware > of your network limitations), but I would be very careful in this > circumstance. I think you are looking for Encapsulated Remote Span (ERSPAN). ERSPAN will work over a routed network, but not sure your gear will support you. Here are a few links: http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/nativ= e/configuration/guide/span.html#wp1059482 http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/nativ= e/configuration/guide/span.html#wp1063324' These are for a 6500 series, so you'll need to check your switch code and your WAN. Very possible, but if I had to guess on a 2621, you are probably out of luck. | |||||||||||||
| Similar Threads | Posted |
| switch newbie - rspan over wan possible? | August 6, 2008, 9:38 am |
| Newbie ACL Help on Cisco Switch | November 10, 2005, 12:49 pm |
| Newbie question - What's wrong with my switch? | April 27, 2008, 7:50 pm |
| RSPAN no workie... | December 16, 2005, 6:04 pm |
| 4500 RSPAN ?? Does it work? | January 30, 2006, 4:06 pm |
| Combined SPAN and RSPAN | July 10, 2006, 6:18 am |
| RSPAN Ingress Problem | July 25, 2007, 9:11 am |
| RSPAN Trunked port - 6509 | October 27, 2005, 7:46 pm |
| Switch/Switch problem fibre gigbit ethernet | September 6, 2005, 12:33 pm |
| turn part of the cisco switch into a plain switch | February 13, 2007, 1:27 am |
| trunking between Cisco Catalyst 500 switch and other type of switch | March 28, 2006, 1:13 am |
| VLAN - switch -> trunk -> switch - priority queuing ? | August 19, 2006, 2:31 pm |
| why cisco 2950 switch is called as catalyst switch | December 8, 2006, 10:40 am |
| 2950 switch to switch question | July 17, 2007, 11:35 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> traffic.
