I'm trying to login to CISCO VPN Client using command line, it logs in but asks for confirmation to continue
Is there any way to suppress this confirmation?
to login i'm using command as follows vpnclient connect user pwd
i think what you are seeing is a Banner after connection which asks you to continue. this has nothing to with the vpn client, the box which you are establishing the vpn connection is pushing a banner and thats why you are asked for a confirmation.
there is nothing can be done on vpn client.
Thanks for reply. Can we do some configuration on remote box i'm connecting so that it will not ask for confirmation?
