Cisco Systems subnetting
Subject Author Date
subnetting mmark751969 07-21-08
Posted by mmark751969 on July 21, 2008, 2:25 pm
we have a 400 node network running on multple 3750 stackable switches
at access layer and a 6509 at the core. We are talking about
subnetting the network. 8 different subnets have been proposed. I
agree that vlan subnetting has it's advantages(i.e reducing broadcast
domains). But i am wondering at what point it's too much. Or what is
the drawback of having too many subnets and would 8 be considered that
on a 400 node network. Thanks
Posted by Trendkill on July 21, 2008, 2:47 pm
> at access layer and a 6509 at the core. =A0We are talking about
> subnetting the network. =A08 different subnets have been proposed. =A0I
> domains). =A0But i am wondering at what point it's too much. =A0Or what i=
s
> on a 400 node network. =A0Thanks
It all depends on the nature of the traffic. If these are all user
stations, I have seen many times where a /22 is used (1000+
addresses), and 4-500 are active during regular usage. If its a mixed
use vlan with real-time traffic (such as video or voice, which would
not be good architecture anyway), then subnetting to smaller subnets
makes more sense. In short, 8 segments for 50 nodes each is
overkill. I would personally not do smaller than /25, and /24 in most
cases, unless of course the network is a retail or small site network
which will never get larger than that space, or there are special vlan
or traffic requirements. When you are talking modern gig speed
networks, broadcast traffic is minimal unless you have an issue (ie
bad worm or virus), or a network design problem.
Posted by Thrill5 on July 21, 2008, 5:28 pm
There is no drawback to having too many subnets when routing with a 6500!!!!
Layer 2 switching is not any faster than layer 3 switching and smaller
subnets means a smaller broadcast domain. If you are running windows, than
smaller broadcast domains are good because windows workstations send out
quite a bit of broadcast traffic.
I never ever, ever use subnets bigger than a /24, and most subnets usually
have an average of only about 60 workstations. On my network, each and
every wiring closet has its own subnet, plus a voice subnet if it is a VoIP
is being used.
The speed of the interface has nothing to do with the amount of broadcast
traffic, that is a function of the number of devices in the broadcast
domain. Each and every broadcast packet is sent to, and processed by, every
device in the broadcast domain.
Posted by Trendkill on July 21, 2008, 5:53 pm
> There is no drawback to having too many subnets when routing with a 6500!=
> subnets means a smaller broadcast domain. =A0If you are running windows, =
than
> I never ever, ever use subnets bigger than a /24, and most subnets usuall=
y
> have an average of only about 60 workstations. =A0On my network, each and
> every wiring closet has its own subnet, plus a voice subnet if it is a Vo=
IP
> is being used.
> >It all depends on the nature of the traffic. =A0If these are all user
> >addresses), and 4-500 are active during regular usage. =A0If its a mixed
> >makes more sense. =A0In short, 8 segments for 50 nodes each is
> >overkill. =A0I would personally not do smaller than /25, and /24 in most
> >or traffic requirements. =A0When you are talking modern gig speed
> domain. =A0Each and every broadcast packet is sent to, and processed by, =
every
I agree, but in the days of 10/half interfaces, broadcast could easily
overwhelm a link or subnet. Today, it would take one hell of a
broadcast storm to overwhelm a modern backbone or LAN link. While I
don't disagree with your subnet solution (can't really go wrong here,
and have to design to your requirements), my experience is in two
global Fortune 50 companies, and when you have dozens of datacenters,
subnetting like that adds up quick on wasted addresses. That being
said, I would not go larger than a /22. And, always subnet real time
traffic if possible, particularly VoIP since the requirements/
segmentation work nicely.
Posted by Trendkill on July 21, 2008, 5:55 pm
than
y
IP
> is being used.
every
I should also qualify that this entire discussion assumes centralized
layer 2, which in itself is becoming a legacy design for very large
networks. Distributed layer 3 is not necessarily cheap, but is
feasible in most l3 switches today, and can help alleviate backbone
traffic, broadcast traffic, and inter vlan routing since subnets are
local to switch pairs only.
Similar ThreadsPosted
subnetting July 21, 2008, 2:25 pm
/23 subnetting question April 19, 2007, 7:26 pm
Learn subnetting at http://easysubnet.com January 25, 2008, 8:53 pm
Subnetting, private networks & default routes April 22, 2006, 12:49 pm
A kind data structure and arithmetic for subnetting April 30, 2006, 10:36 pm
A kind of arithmetic for subnetting and ip address management May 8, 2006, 5:32 am
Subnetting Question from ccna - sybex book October 6, 2006, 11:29 am
How to manage IP address and how to perform subnetting, i have a good idea March 23, 2006, 9:43 pm
Cisco announces a new subnetting game for CCNA seekers March 6, 2007, 5:51 am
IP Subnetting Tips&Tricks - Study + Workbook Package September 24, 2008, 10:36 am
IP Subnetting Tips&Tricks - Study + Workbook Package September 24, 2008, 10:40 am
