Cisco Systems strange cisco 7604 password recovery problem
Subject Author Date
strange cisco 7604 password recovery problem Marko Uusitalo 04-03-09
Posted by Marko Uusitalo on April 3, 2009, 5:05 pm
Hi!
We have in our lab a cisco 7604 and I canīt remember itīs enable password.
I tried standard password recovery procedure (reboot, confreg 0x2142
reset) but for some reason this box allways loads configuration (it
canges configuration register to 0x2102 automagically)
Any help is greatly appreciatted
Here is copy.paste from my termina session:
R7604_1>
System Bootstrap, Version 12.2(18r)SX2, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2004 by cisco Systems, Inc.
Cat6k-Sup32 platform with 524288 Kbytes of main memory
Autoboot executing command: "boot "
monitor: command "boot" aborted due to user interrupt
rommon 1 > confreg 0x2142
rommon 2 > reset
Resetting .......
Initializing ATA monitor library...
string is bootdisk:s3223-adventerprisek9_wan-mz.122-33.SRA3.bin
Self extracting the image... [OK]
Self decompressing the image :
########################################################### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, s3223_sp Software (s3223_sp-ADVENTERPRISEK9_WAN-M),
Version 12.2(33
)SRA3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Feb-07 11:56 by prod_rel_team
Image text-base: 0x4023131C, data-base: 0x41714000
MAC based EOBC installed
00:00:05: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console
debugging output.
00:00:05: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
00:00:07: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console
debugging output.
00:00:05: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to
ensure console debug
ging output.
00:00:07: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
Cat6k-MSFC2A platform with 524288 Kbytes of main memory
Download Start
Download Completed! Booting the image.
cisco Systems, Inc.
Cisco IOS Software, s3223_rp Software (s3223_rp-ADVENTERPRISEK9_WAN-M),
Version 12.2(33
Compiled Wed 28-Feb-07 11:35 by prod_rel_team
Image text-base: 0x401012FC, data-base: 0x433A0000
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be
found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco CISCO7604 (R7000) processor (revision 2.0) with 458752K/65536K
bytes of memory.
Processor board ID FOX103105HB
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
1 Virtual Ethernet interface
9 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
ICMP redirect is disabled on interfaces with secondary IP address
Press RETURN to get started!
00:01:10: RP: Currently running ROMMON from S (Gold) region
*Apr 3 10:33:54.287: %SYS-6-CLOCKUPDATE: System clock has been updated
from 08:33:54 U
TC Fri Apr 3 2009 to 10:33:54 EET Fri Apr 3 2009, configured from
console by console.
*Apr 3 11:33:54.291: %SYS-6-CLOCKUPDATE: System clock has been updated
from 10:33:54 E
ET Fri Apr 3 2009 to 11:33:54 EET Fri Apr 3 2009, configured from
console by console.
*Apr 3 11:33:54.383: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled
for type vlan
*Apr 3 11:33:55.680: %SYS-5-CONFIG_I: Configured from memory by console
*Apr 3 11:33:57.200: %SYS-5-RESTART: System restarted --
Version 12.2(33
*Apr 3 11:33:57.212: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Apr 3 11:33:57.212: %NTP-6-RESTART: NTP process starts
*Apr 3 11:33:57.820: %MFIB_CONST_RP-6-REPLICATION_MODE_CHANGE:
Replication Mode Change
Detected. Current system replication mode is Ingress
ging output.
*Apr 3 11:33:59.568: %MLSM-6-MMLS_MODE_CHANGE: MMLS: Replication Mode
Changed to Egres
s mode (Oir event)
00:00:07: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to
ensure console de
bugging output.
Firmware compiled 07-Jul-06 18:10 by integ Build [100]
00:01:19: %SPANTREE-SP-5-EXTENDED_SYSID: Extended SysId enabled for type
vlan
00:01:28: %SYS-SP-5-RESTART: System restarted --
Version 12.2(33
00:01:28: SP: Currently running ROMMON from S (Gold) region
*Apr 3 11:33:59.600: %OIR-SP-6-INSPS: Power supply inserted in slot 1
*Apr 3 11:33:59.616: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
*Apr 3 11:34:06.276: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal
Diagnostics...
Tata reititinta ei konfiguroida laboratoriotoissa!!!!
HAND OFF!!!!!!!
No configuration changes in this router!!!!
T. Marko Uusitalo, puh 050-3525975
R7604_1>
*Apr 3 11:34:19.100: %MLSM-6-MMLS_MODE_CHANGE: MMLS: Replication Mode
Changed to Ingre
ss mode (Oir event)
*Apr 3 11:34:18.444: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online
Diagnostics
R7604_1>
*Apr 3 11:34:19.596: %OIR-SP-6-INSCARD: Card inserted in slot 1,
interfaces are now on
line
R7604_1>
*Apr 3 11:36:21.213: %NTP-4-PEERUNREACH: Peer 192.168.1.254 is unreachable
R7604_1>
*Apr 3 11:36:28.213: %NTP-4-PEERUNREACH: Peer 193.167.196.1 is unreachable
*Apr 3 11:36:28.213: %NTP-4-PEERUNREACH: Peer 10.20.76.10 is unreachable
R7604_1>
*Apr 3 11:36:30.213: %NTP-4-PEERUNREACH: Peer 192.168.1.17 is unreachable
*Apr 3 11:36:31.213: %NTP-4-PEERUNREACH: Peer 194.137.39.68 is unreachable
R7604_1>
*Apr 3 11:36:35.214: %NTP-4-PEERUNREACH: Peer 194.137.39.67 is unreachable
*Apr 3 11:36:35.214: %NTP-4-PEERUNREACH: Peer 192.168.2.253 is unreachable
R7604_1>
Posted by Thrill5 on April 3, 2009, 8:26 pm
Instead of doing a "reset" after changing the configuration register, try
doing a "boot". I think the problem is that you are changing the
configuration register and it's not saved, so when you do a reset it gets
changed back to the original value.
> Hi!
> reset) but for some reason this box allways loads configuration (it canges
> R7604_1>
> rommon 2 > reset
> Resetting .......
> cisco Systems, Inc.
> Version 12.2(33
> debugging output.
> debugging output.
> 00:00:05: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure
> console debug
> ging output.
> Download Start
> cisco Systems, Inc.
> Version 12.2(33
> A summary of U.S. laws governing Cisco cryptographic products may be found
> at:
> export@cisco.com.
> cisco CISCO7604 (R7000) processor (revision 2.0) with 458752K/65536K bytes
> of memory.
> Cache
> from 08:33:54 U
> TC Fri Apr 3 2009 to 10:33:54 EET Fri Apr 3 2009, configured from console
> by console.
> from 10:33:54 E
> ET Fri Apr 3 2009 to 11:33:54 EET Fri Apr 3 2009, configured from console
> by console.
> for type vlan
> Version 12.2(33
> console debug
> ging output.
> Changed to Egres
> s mode (Oir event)
> ensure console de
> bugging output.
> vlan
> Version 12.2(33
> Diagnostics...
> HAND OFF!!!!!!!
> R7604_1>
> Changed to Ingre
> ss mode (Oir event)
> Diagnostics
> R7604_1>
> line
> R7604_1>
> unreachable
> R7604_1>
> unreachable
> R7604_1>
> unreachable
> R7604_1>
> unreachable
> unreachable
> R7604_1>
Similar ThreadsPosted
strange cisco 7604 password recovery problem April 3, 2009, 5:05 pm
Password recovery problem July 20, 2005, 1:48 pm
PIX 520 with 5.1(4) OS enable password recovery problem October 7, 2006, 5:27 pm
Password Recovery for CISCO 836 September 5, 2006, 9:16 am
cisco 857 password recovery June 30, 2009, 1:45 pm
Cisco 1900 Password Recovery October 6, 2006, 12:01 pm
Avoid Password Recovery on Cisco 5300 October 6, 2005, 5:15 pm
Password recovery disabled on Cisco 1711 Router - cannot login or reset May 17, 2006, 8:50 am
Password Recovery November 20, 2005, 12:00 pm
Password recovery - 2900XL July 28, 2006, 11:09 pm
NO SERVICE PASSWORD RECOVERY March 6, 2008, 1:35 pm
HELP ON 2525 ROUTER PASSWORD RECOVERY February 12, 2005, 12:56 pm
Need password recovery util for LocalDirector 430 March 22, 2006, 1:53 am
Password recovery without serial port January 5, 2009, 7:45 am
aironet ap350 PASSWORD RECOVERY OR RESET ENTIRE CONFIG September 13, 2006, 7:24 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
