Hi! I changed compoactflash cards on one of our cisco 2801's power connected trying to get a 512MB card partitioned to 128MB to work, and when I Installed this 512MB card, router dropped suddenly to rommon. I Switched power off and tried to boot with original Card but router finds image and decompresses and loads it but hangs after "Installed image archive" prompt.
I tried booting also with flashcards from other (working) 2801's without success. I made sure that config-register is 0x2102 and also tried with 0x2142, 0x2141 and
0x2101. I tried to dowload new version of IOS to flash from Romboot with tftpdnld command, but it does not work as router has lost it's MAC address. Correct port (fa0/0) was connected and link was up. Any ideas how to fix this problem?Best Regads
Marko Uusitalo
Router output below
*************************************************************rommon 11 > tftpdnld
IP_ADDRESS: 192.168.1.27 IP_SUBNET_MASK: 255.255.255.0 DEFAULT_GATEWAY: 192.168.1.254 TFTP_SERVER: 10.19.18.52 TFTP_FILE: c2801-ipbase-mz.124-1c.binget_mac_address(): Search T_IDPR OM_MACADDR (0xc3) failed
Illegal MAC address.
************************************************************ Boot sequence: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1) Technical Support:Readonly ROMMON initialized program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library....... program load complete, entry point: 0x8000f000, size: 0xc100
program load complete, entry point: 0x8000f000, size: 0x1d2be3c Self decompressing the image : ################################################# ################################################################################ ################################################################################ ################################################################################ ##################################################### [OK]
Smart Init is enabled smart init is sizing iomem ID MEMORY_REQ TYPE 0X003AA110 public buffer pools 0X00211000 public particle pools 0X00020000 Crypto module pools 0X00120000 VPM buffer pools
0X0012 0X00035000 Card in slot 1 0X0013 0X00035000 Card in slot 2 0X000021B8 Onboard USBIf any of the above Memory Requirements are "UNKNOWN", you may be using an unsupported configuration or there is a software problem and system operation may be compromised.
Allocating additional 29011745 bytes to IO Memory. PMem allocated: 362807296 bytes; IOMem allocated: 39845888 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706
Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version
12.4(9)T, R ELEASE SOFTWARE (fc1) Technical Support:This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
MACHINE JUST HANGS AFTER "Installed image Archive"
**********************************************************************Boot sequence from Rommon
rommon 1 > dir flash: program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library....... Directory of flash:
2 30588892 -rw- c2801-advipservicesk9-mz.124-9.T.bin rommon 2 > boot flash:c2801-advipservicesk9-mz.124-9.T.bin program load complete, entry point: 0x8000f000, size: 0xc100Initializing ATA monitor library.......
JUST HANG AFTER THIS
