Still have the problem... Please help me !!!
Hello, I really need help to solve this problem. A cisco 2611 is connected to the Internet on interface Ethernet0/1 with an ethernet ADSL modem. When you turn on the cisco, after his boot initialization, it get his ip address. But the ISP change the Internet address every two or three days, but the Cisco doesn't detect the new IP address send by the new ISP DHCP/Gateway. I must shut / no shut the ethernet0/1 interface and the it take the new address. The ISP have IP address sometimes in range 62.147.x.y , sometimes
82.252.X.Y,etc... , but the Gateway (which is too the DHCP server for this subnet) is always 62.147.X.254 or 82.252.X.254 or etc .....
What's wrong in my configuration below ? I paste examples (after config file) of :
- show dhcp lease
- dhcp debug details
Thanks a lot for your help !!
Here is the configuration
***** toto.free.fr#show run Building configuration...
Current configuration : 3494 bytes ! ! Last configuration change at 18:26:10 PCTime Sun Apr 17 2005 ! NVRAM config last updated at 18:29:19 PCTime Sun Apr 17 2005 ! version 12.3 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname toto.free.fr ! boot-start-marker boot-end-marker ! enable password 7 xxxxxxx ! clock timezone PCTime 1 clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00 no aaa new-model ip subnet-zero no ip source-route ip cef ! ! no ip domain lookup ip dhcp excluded-address 192.168.0.1 192.168.0.200 ip dhcp excluded-address 192.168.0.210 192.168.0.254 ! ip dhcp pool wifi host 192.168.0.250 255.255.255.0 client-identifier 0100.4005.d042.b8 ! ip dhcp pool 1 network 192.168.0.0 255.255.255.0 default-router 192.168.0.244 dns-server 212.27.32.177 194.149.160.9 ! no ip bootp server ip audit notify log ip audit po max-events 100 no ftp-server write-enable ! ! ! ! interface Null0 no ip unreachables ! interface Ethernet0/0 description connected to EthernetLAN ip address 192.168.0.244 255.255.255.0 ip access-group 100 in no ip redirects no ip unreachables no ip proxy-arp ip nat inside half-duplex ! interface Ethernet0/1 description connected to Internet ip address dhcp ip access-group 103 in no ip proxy-arp ip nat outside half-duplex no cdp enable ! router rip version 1 passive-interface Ethernet0/1 network 192.168.0.0 no auto-summary ! ip nat inside source list 1 interface Ethernet0/1 overload ip nat inside source static udp 192.168.0.10 5555 interface Ethernet0/1 5555 ip nat inside source static tcp 192.168.0.10 5555 interface Ethernet0/1 5555 ip nat inside source static udp 192.168.0.10 6666 interface Ethernet0/1 6666 ip nat inside source static tcp 192.168.0.10 6666 interface Ethernet0/1 6666 no ip http server ip classless ! ! access-list 1 remark Regle NAT genereale access-list 1 permit 192.168.0.0 0.0.0.255 access-list 100 remark LAN In access-list 100 permit udp any any eq bootpc access-list 100 deny ip host 255.255.255.255 any access-list 100 deny ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip any any access-list 103 remark ENTRANT Interface Wan access-list 103 permit udp any eq bootpc host 192.168.0.244 eq bootpc access-list 103 deny udp any any eq bootps access-list 103 deny udp any any eq snmp access-list 103 deny udp any any eq snmptrap access-list 103 permit ip any any snmp-server community public RO 1 snmp-server enable traps tty banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user! ****** Acces reserve - Deconnectez vous immediatement ****!^C ! line con 0 exec-timeout 0 0 password 7 xxxxxx login line aux 0 line vty 0 4 access-class 1 in password 7 xxxx login ! ntp clock-period 17208826 ntp server 195.83.132.135 ntp server 138.195.130.71 ntp server 195.83.66.36 ntp server 207.46.130.100 ! ! end
And for information
toto.free.fr#show dhcp server DHCP server: ANY (255.255.255.255) Leases: 423 Offers: 2 Requests: 426 Acks: 423 Naks: 0 Declines: 0 Releases: 3 Bad: 0 DNS0: 213.228.0.212, DNS1: 212.27.32.177 Subnet: 255.255.255.0
toto.free.fr#show dhcp lease Temp IP addr: 82.252.134.XXX for peer on Interface: Ethernet0/1 Temp sub net mask: 255.255.255.0 DHCP Lease server: 82.252.134.254, state: 3 Bound DHCP transaction id: 364230A Lease: 600 secs, Renewal: 60 secs, Rebind: 600 secs Temp default-gateway addr: 82.252.134.254 Next timer fires after: 00:00:32 Retry count: 0 Client-ID: cisco-0008.ZZZZ.YYYY-Et0/1 Hostname: toto.free.fr toto.free.fr#
toto.free.fr#show dhcp lease Temp IP addr: 82.252.134.xxx for peer on Interface: Ethernet0/1 Temp sub net mask: 255.255.255.0 DHCP Lease server: 82.252.134.254, state: 4 Rebinding DHCP transaction id: 3D6C09F Lease: 600 secs, Renewal: 60 secs, Rebind: 600 secs Temp default-gateway addr: 82.252.134.254 No timer running Retry count: 1 Client-ID: 0008.21ea.aa81 Hostname: toto.free.fr
Notice the No timer running that don't understand. I again do a shut/no shut on the E0/1 interface and now this is the new show dhcp lease command : toto.free.fr#show dhcp lease Temp IP addr: 62.147.217.XXX for peer on Interface: Ethernet0/1 Temp sub net mask: 255.255.255.0 DHCP Lease server: 62.147.217.254, state: 5 Renewing DHCP transaction id: 8E99607 Lease: 600 secs, Renewal: 60 secs, Rebind: 600 secs Temp default-gateway addr: 62.147.217.254 Next timer fires after: 00:07:45 Retry count: 1 Client-ID: 0008.21ea.aa81 Hostname: toto.free.fr toto.free.fr#
and now there is a Next timer fires after: 00:07:45
toto.free.fr#debug dhcp detail DHCP client activity debugging is on (detailed) toto.free.fr#
2d22h: DHCP: QScan: Bound..T1 fired..Renewing 2d22h: DHCP: SRequest attempt # 1 for entry: 2d22h: Temp IP addr: 82.252.138.229 for peer on Interface: Ethernet0/1 2d22h: Temp sub net mask: 255.255.255.0 2d22h: DHCP Lease server: 82.252.138.254, state: 5 Renewing 2d22h: DHCP transaction id: B0C85C3 2d22h: Lease: 600 secs, Renewal: 60 secs, Rebind: 600 secs 2d22h: Temp default-gateway addr: 82.252.138.254 2d22h: Next timer fires after: 00:08:59 2d22h: Retry count: 1 Client-ID: cisco-0008.21ea.aa81-Et0/1 2d22h: Hostname: toto.free.fr 2d22h: DHCP: SRequest - ciaddr: 82.252.138.229 2d22h: DHCP: SRequest placed lease len option: 600 2d22h: DHCP: SRequest: 310 bytes 2d22h: DHCP: SRequest: 310 bytes 2d22h: DHCP: Received a BOOTREP pkt 2d22h: DHCP: Scan: Message type: DHCP Ack 2d22h: DHCP: Scan: Server ID Option: 82.252.138.254 = 52FC8AFE 2d22h: DHCP: Scan: Renewal time: 60 2d22h: DHCP: Scan: Rebind time: 600 2d22h: DHCP: Scan: Lease Time: 600 2d22h: DHCP: Scan: Subnet Address Option: 255.255.255.0 2d22h: DHCP: Scan: Router Option: 82.252.138.254 2d22h: DHCP: Scan: DNS Name Server Option: 213.228.0.212, 212.27.32.177 2d22h: DHCP: rcvd pkt source: 82.252.138.254, destination: 82.252.138.229 2d22h: UDP sport: 43, dport: 44, length: 556 2d22h: DHCP op: 2, htype: 1, hlen: 6, hops: 0 2d22h: DHCP server identifier: 82.252.138.254 2d22h: xid: B0C85C3, secs: 0, flags: 0 2d22h: client: 0.0.0.0, your: 82.252.138.229 2d22h: srvr: 82.252.138.254, gw: 0.0.0.0 2d22h: options block length: 308
2d22h: DHCP Ack Message
2d22h: DHCP: Lease Seconds: 600 Renewal secs: 60 Rebind secs: 600 2d22h: DHCP: Server ID Option: 82.252.138.254 2d22h: DHCP: Applying DHCP options: 2d22h: DHCP: Releasing ipl options: 2d22h: Setting default_gateway to 82.252.138.254 2d22h: Adding DNS server address 213.228.0.212 2d22h: Adding DNS server address 212.27.32.177 2d22h: DHCP Client Pooling: ***Allocated IP address: 82.252.138.229 toto.free.fr#no debug dhcp DHCP client activity debugging is off toto.free.fr#
toto.free.fr#show arp Protocol Address Age (min) Hardware Addr Type Interface Internet 62.147.221.83 11 0007.cb09.a2b7 ARPA Ethernet0/1 Internet 192.168.0.9 9 00e0.4cbc.b3fb ARPA Ethernet0/0 Internet 62.147.221.254 30 0007.cb09.a2b7 ARPA Ethernet0/1 Internet 192.168.0.244 - 0008.21ea.aa80 ARPA Ethernet0/0 Internet 62.147.221.205 - 0008.21ea.aa81 ARPA Ethernet0/1
(notice that 0007.cb09.a2b7 is Mac address of ethernet ADSL modem and 0008.21ea.aa81 is Mac Address of the Ethernet0/1
toto.free.fr#traceroute 212.27.32.177
Type escape sequence to abort. Tracing the route to 212.27.32.177
1 192.168.254.254 36 msec 32 msec 37 msec 2 212.27.37.61 36 msec 36 msec 36 msec 3 212.27.51.81 40 msec 36 msec 36 msec 4 212.27.32.177 36 msec 36 msec 36 msec toto.free.fr#
toto.free.fr#show ip interface Ethernet0/0 is up, line protocol is up Internet address is 192.168.0.244/24 Broadcast address is 255.255.255.255 Address determined by non-volatile memory MTU is 1500 bytes Helper address is not set Directed broadcast forwarding is disabled Multicast reserved groups joined: 224.0.0.9 Outgoing access list is not set Inbound access list is 100 Proxy ARP is disabled Local Proxy ARP is disabled Security level is default Split horizon is enabled ICMP redirects are never sent ICMP unreachables are never sent ICMP mask replies are never sent IP fast switching is enabled IP fast switching on the same interface is disabled IP Flow switching is disabled IP CEF switching is enabled IP CEF Feature Fast switching turbo vector IP multicast fast switching is enabled IP multicast distributed fast switching is disabled IP route-cache flags are Fast, CEF Router Discovery is disabled IP output packet accounting is disabled IP access violation accounting is disabled TCP/IP header compression is disabled RTP/IP header compression is disabled Policy routing is disabled Network address translation is enabled, interface in domain inside WCCP Redirect outbound is disabled WCCP Redirect inbound is disabled WCCP Redirect exclude is disabled BGP Policy Mapping is disabled Ethernet0/1 is up, line protocol is up Internet address is 62.147.221.205/24 Broadcast address is 255.255.255.255 Address determined by DHCP MTU is 1500 bytes Helper address is not set Directed broadcast forwarding is disabled Outgoing access list is not set Inbound access list is 103 Proxy ARP is disabled Local Proxy ARP is disabled Security level is default Split horizon is enabled ICMP redirects are always sent ICMP unreachables are always sent ICMP mask replies are never sent IP fast switching is enabled IP fast switching on the same interface is disabled IP Flow switching is disabled IP CEF switching is enabled IP CEF Feature Fast switching turbo vector IP multicast fast switching is enabled IP multicast distributed fast switching is disabled IP route-cache flags are Fast, CEF Router Discovery is disabled IP output packet accounting is disabled IP access violation accounting is disabled TCP/IP header compression is disabled RTP/IP header compression is disabled Policy routing is disabled Network address translation is enabled, interface in domain outside WCCP Redirect outbound is disabled WCCP Redirect inbound is disabled WCCP Redirect exclude is disabled BGP Policy Mapping is disabled toto.free.fr# toto.free.fr#show interfaces Ethernet0/0 is up, line protocol is up Hardware is AmdP2, address is 0008.21ea.aa80 (bia 0008.21ea.aa80) Description: connected to EthernetLAN Internet address is 192.168.0.244/24 MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:06, output 00:00:03, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 4172347 packets input, 1220388978 bytes, 0 no buffer Received 53153 broadcasts, 0 runts, 0 giants, 0 throttles 21 input errors, 0 CRC, 0 frame, 0 overrun, 21 ignored 0 input packets with dribble condition detected 5623482 packets output, 935378313 bytes, 0 underruns 0 output errors, 34856 collisions, 3 interface resets 0 babbles, 0 late collision, 54663 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Ethernet0/1 is up, line protocol is up Hardware is AmdP2, address is 0008.21ea.aa81 (bia 0008.21ea.aa81) Description: connected to Internet Internet address is 62.147.221.205/24 MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:09, output 00:00:01, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 5642038 packets input, 941936111 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 4243738 packets output, 1212690519 bytes, 0 underruns 202 output errors, 38583 collisions, 9 interface resets 0 babbles, 0 late collision, 188974 deferred 202 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out toto.free.fr#
If you need anything else... ask me.
Thanks very much
sam
- show dhcp lease
And for information
Thanks very much
sam
If I were you, I would search for bugs using Bug toolkit because this might be one...
Ivan Ostres
Is there any chance this could be a bug with the ethernet adsl modem? Have you ever plugged a PC into the modem via the ethernet port for 3 days, does the PC manage to resolve the new IP?
John Smith
No bug from the modem : it works well for a year in the past with a Bewan/draytek router, a netgear router (RP614) . Someone tell me about a possible bug in Cisco IOS 12.3 .... that the broadcast isn't 255.255.255.255 .... Have you heard about that ? My ios version seems to be : Version 12.3(5a)
Thanks for your help
sam
Thanks , but i can't log into bug toolkit... does it need payement ? My ios version is : Version 12.3(5a)
sam
Yes, you'll need a CCO account. My other suggestion should have been to open a TAC case which seems it is out of the question for you.
Ivan Ostres
When i identify to Cisco website , here is the reply : You have logged in with registered guest level access
I had fill the register form (for free) on cisco website a month ago ... Need to pay to access bug toolkit ? to access TAC ( what is TAC ? incident ticket ?) Thanks
sam
I belive that you need a Support Contract of some kind to access bug toolkit and TAC. TAC is Technical Assistance Center.
Ivan Ostres
Ok.
1) I have another idea... as i know how to solve the pb by a shut / no shut the interface ethernet0/1, is it possible to do like a "linux cron-job" on a cisco 2611 ? My idea is to make a ping every 5 minutes for example, and when there is no reply , make the cisco do itself a shut/no shut of the interface .... Is it possible or am i dreaming ?
2) Is it possible to store somewhere in the cisco this sequence below , and just write in enable mode : MyBatchCommand and all the line below are executed : conf t interface ethernet0/1 shut (here wait a little) no shut end
Thanks again for your help
sam
You can do that because I think that your IOS supports TCL scripting...
Ivan Ostres
Ok... I have a quick look at cisco web site... it doesn't seem so easy for a first time trie...
An idea for the second point of my last message ?
Real thanks for your precious help ! Sam
sam
Something new to understand my problem. This morning, i don't have internet because the wan ip change. So i write with debug dhcp detail mode on toto.free.fr#conf t Enter configuration commands, one per line. End with CNTL/Z. toto.free.fr(config)#ip dhcp-client network-discovery informs 2 discovers 2 period 15
And this is what the Cisco do :
21:30:02: DHCP: DHCP client process started: 12 21:30:03: DHCP: SInform 21:30:03: B'cast on Ethernet0/0 interface from 192.168.0.244 21:30:03: B'cast on Ethernet0/1 interface from 82.252.140.191^Z toto.free.fr# 21:30:18: DHCP: SInform 21:30:18: B'cast on Ethernet0/0 interface from 192.168.0.244 21:30:18: B'cast on Ethernet0/1 interface from 82.252.140.191 21:30:19: %SYS-5-CONFIG_I: Configured from console by console 21:30:33: DHCP: SInform as discover 21:30:33: B'cast on Ethernet0/0 interface from 192.168.0.244 21:30:33: B'cast on Ethernet0/1 interface from 82.252.140.191 21:30:48: DHCP: SInform as discover 21:30:48: B'cast on Ethernet0/0 interface from 192.168.0.244 21:30:48: B'cast on Ethernet0/1 interface from 82.252.140.191 21:31:03: DHCP: Shutting down from get_netinfo() 21:31:03: DHCP: Attempting to shutdown DHCP Client
And like the others time , i shut / no shut the interface because I still don't have the connection.... :-(
toto.free.fr#conf t Enter configuration commands, one per line. End with CNTL/Z. toto.free.fr(config)#interface ethernet0/1 toto.free.fr(config-if)#shut
21:32:11: DHCP: SRelease attempt # 1 for entry: 21:32:11: Temp IP addr: 82.252.140.191 for peer on Interface: Ethernet0/1 21:32:11: Temp sub net mask: 255.255.255.0 21:32:11: DHCP Lease server: 82.252.140.254, state: 7 Releasing 21:32:11: DHCP transaction id: 2289 21:32:11: Lease: 600 secs, Renewal: 60 secs, Rebind: 600 secs 21:32:11: Temp default-gateway addr: 82.252.140.254 21:32:11: Next timer fires after: 00:00:00 21:32:11: Retry count: 1 Client-ID: cisco-0008.21ea.aa81-Et0/1 21:32:11: Hostname: toto.free.fr 21:32:11: DHCP: SRelease placed Server ID option: 82.252.140.254 21:32:11: DHCP: SRelease: 279 bytes 21:32:11: DHCP: SRelease attempt # 2 for entry: 21:32:11: Temp IP addr: 82.252.140.191 for peer on Interface: Ethernet0/1 21:32:11: Temp sub net mask: 255.255.255.0 21:32:11: DHCP Lease server: 82.252.140.254, state: 7 Releasing 21:32:11: DHCP transaction id: 2289 21:32:11: Lease: 600 secs, Renewal: 60 secs, Rebind: 600 secs 21:32:11: Temp default-gateway addr: 82.252.140.254 21:32:11: Next timer fires after: 00:00:00 21:32:11: Retry count: 2 Client-ID: cisco-0008.21ea.aa81-Et0/1 21:32:11: Hostname: toto.free.fr 21:32:11: DHCP: SRelease placed Server ID option: 82.252.140.254 21:32:11: DHCP: SRelease: 279 bytes 21:32:11: DHCP: Releasing ipl options: 21:32:11: Clearing default gateway and route to 82.252.140.254 21:32:11: Clearing DNS address 213.228.0.212 21:32:11: Clearing DNS address 212.27.32.177 21:32:12: DHCP: SRelease attempt # 3 for entry: 21:32:12: Temp IP addr: 82.252.140.191 for peer on Interface: Ethernet0/1 21:32:12: Temp sub net mask: 255.255.255.0 21:32:12: DHCP Lease server: 82.252.140.254, state: 7 Releasing 21:32:12: DHCP transaction id: 2289 21:32:12: Lease: 600 secs, Renewal: 60 secs, Rebind: 600 secs 21:32:12: Next timer fires after: toto.free.fr(config-if)# 00:00:01 21:32:12: Retry count: 3 Client-ID: cisco-0008.21ea.aa81-Et0/1 21:32:12: Hostname: toto.free.fr 21:32:12: DHCP: SRelease placed Server ID option: 82.252.140.254 21:32:12: DHCP: SRelease: 279 bytes 21:32:13: RAC: DHCP stopped on interface Ethernet0/1 21:32:15: %LINK-5-CHANGED: Interface Ethernet0/1, changed state to administratively down 21:32:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1, changed state to down toto.free.fr(config-if)#no shut toto.free.fr(config-if)# 21:32:29: DHCP: DHCP client process started: 10 21:32:29: RAC: Starting DHCP discover on Ethernet0/1 21:32:29: DHCP: Try 1 to acquire address for Ethernet0/1 21:32:29: DHCP: allocate request 21:32:29: DHCP: zapping entry in DHC_PURGING state for Et0/1 21:32:29: DHCP: new entry. add to queue 21:32:29: DHCP: SDiscover attempt # 1 for entry: 21:32:29: Temp IP addr: 0.0.0.0 for peer on Interface: Ethernet0/1 21:32:29: Temp sub net mask: 0.0.0.0 21:32:29: DHCP Lease server: 0.0.0.0, state: 1 Selecting 21:32:29: DHCP transaction id: 475 21:32:29: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs 21:32:29: Next timer fires after: 00:00:02 21:32:29: Retry count: 1 Client-ID: cisco-0008.21ea.aa81-Et0/1 21:32:29: Hostname: toto.free.fr 21:32:29: DHCP: SDiscover: sending 304 byte length DHCP packet 21:32:29: DHCP: SDiscover 304 bytes 21:32:29: B'cast on Ethernet0/1 interface from 0.0.0.0 21:32:29: DHCP: Received a BOOTREP pkt 21:32:29: DHCP: Scan: Message type: DHCP Offer 21:32:29: DHCP: Scan: Server ID Option: 82.252.145.254 = 52FC91FE 21:32:29: DHCP: Scan: Renewal time: 60 21:32:29: DHCP: Scan: Rebind time: 600 21:32:29: DHCP: Scan: Lease Time: 600 21:32:29: DHCP: Scan: Subnet Address Option: 255.255.255.0 21:32:29: DHCP: Scan: Router Option: 82.252.145.254 21:32:29: DHCP: Scan: DNS Name Server Option: 213.228.0.212, 212.27.32.177 21:32:29: DHCP: rcvd pkt source: 82.252.145.254, destination: 255.255.255.255 21:32:29: UDP sport: 43, dport: 44, length: 556 21:32:29: DHCP op: 2, htype: 1, hlen: 6, hops: 0 21:32:29: DHCP server identifier: 82.252.145.254 21:32:29: xid: 475, secs: 0, flags: 0 21:32:29: client: 0.0.0.0, your: 82.252.145.104 21:32:29: srvr: 82.252.145.254, gw: 0.0.0.0 21:32:29: options block length: 308
21:32:29: DHCP Offer Message Offered AInterface Ethernet0/1 assigned DHCP address 82.252.145.104, mask 255.255.255.0 ddress: 82.252.145.104
21:32:29: DHCP: Lease Seconds: 600 Renewal secs: 60 Rebind secs: 600 21:32:29: DHCP: Server ID Option: 82.252.145.254 21:32:29: DHCP: offer received from 82.252.145.254 21:32:29: DHCP: SRequest attempt # 1 for entry: 21:32:29: Temp IP addr: 82.252.145.104 for peer on Interface: Ethernet0/1 21:32:29: Temp sub net mask: 255.255.255.0 21:32:29: DHCP Lease server: 82.252.145.254, state: 2 Requesting 21:32:29: DHCP transaction id: 475 21:32:29: Lease: 600 secs, Renewal: 0 secs, Rebind: 0 secs 21:32:29: Next timer fires after: 00:00:01 21:32:29: Retry count: 1 Client-ID: cisco-0008.21ea.aa81-Et0/1 21:32:29: Hostname: toto.free.fr 21:32:29: DHCP: SRequest- Server ID option: 82.252.145.254 21:32:29: DHCP: SRequest- Requested IP addr option: 82.252.145.104 21:32:29: DHCP: SRequest placed lease len option: 600 21:32:29: DHCP: SRequest: 322 bytes 21:32:29: DHCP: SRequest: 322 bytes 21:32:29: B'cast on Ethernet0/1 interface from 0.0.0.0 21:32:29: DHCP: Received a BOOTREP pkt 21:32:29: DHCP: Scan: Message type: DHCP Ack 21:32:29: DHCP: Scan: Server ID Option: 82.252.145.254 = 52FC91FE 21:32:29: DHCP: Scan: Renewal time: 60 21:32:29: DHCP: Scan: Rebind time: 600 21:32:29: DHCP: Scan: Lease Time: 600 21:32:29: DHCP: Scan: Subnet Address Option: 255.255.255.0 21:32:29: DHCP: Scan: Router Option: 82.252.145.254 21:32:29: DHCP: Scan: DNS Name Server Option: 213.228.0.212, 212.27.32.177 21:32:29: DHCP: rcvd pkt source: 82.252.145.254, destination: 255.255.255.255 21:32:29: UDP sport: 43, dport: 44, length: 556 21:32:29: DHCP op: 2, htype: 1, hlen: 6, hops: 0 21:32:29: DHCP server identifier: 82.252.145.254 21:32:29: xid: 475, secs: 0, flags: 0 21:32:29: client: 0.0.0.0, your: 82.252.145.104 21:32:29: srvr: 82.252.145.254, gw: 0.0.0.0 21:32:29: options block length: 308
21:32:29: DHCP Ack Message
21:32:29: DHCP: Lease Seconds: 600 Renewal secs: 60 Rebind secs: 600 21:32:29: DHCP: Server ID Option: 82.252.145.254 21:32:31: %LINK-3-UPDOWN: Interface Ethernet0/1, changed state to up 21:32:32: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1, changed state to up 21:32:32: DHCP Client Pooling: ***Allocated IP address: 82.252.145.104 21:32:32: Allocated IP address = 82.252.145.104 255.255.255.0 ^Z toto.free.fr# 21:32:42: %SYS-5-CONFIG_I: Configured from console by console 21:32:43: DHCP: QScan: Purging entry 21:32:43: DHCP: deleting entry 81067950 82.252.140.191 from list 21:32:43: Temp IP addr: 82.252.140.191 for peer on Interface: unknown 21:32:43: Temp sub net mask: 255.255.255.0 21:32:43: DHCP Lease server: 82.252.140.254, state: 8 Purging 21:32:43: DHCP transaction id: 2289 21:32:43: Lease: 600 secs, Renewal: 60 secs, Rebind: 600 secs 21:32:43: No timer running 21:32:43: Retry count: 0 Client-ID: 21:32:43: Hostname: toto.free.fr toto.free.fr#show ip interface brief Interface IP-Address OK? Method Status Protocol Ethernet0/0 192.168.0.244 YES NVRAM up up Ethernet0/1 82.252.145.104 YES DHCP up up toto.free.fr# 21:33:32: DHCP: QScan: Bound..T1 fired..Renewing 21:33:32: DHCP: SRequest attempt # 1 for entry: 21:33:32: Temp IP addr: 82.252.145.104 for peer on Interface: Ethernet0/1 21:33:32: Temp sub net mask: 255.255.255.0 21:33:32: DHCP Lease server: 82.252.145.254, state: 5 Renewing 21:33:32: DHCP transaction id: 475 21:33:32: Lease: 600 secs, Renewal: 60 secs, Rebind: 600 secs 21:33:32: Temp default-gateway addr: 82.252.145.254 21:33:32: Next timer fires after: 00:08:59 21:33:32: Retry count: 1 Client-ID: cisco-0008.21ea.aa81-Et0/1 21:33:32: Hostname: toto.free.fr 21:33:32: DHCP: SRequest - ciaddr: 82.252.145.104 21:33:32: DHCP: SRequest placed lease len option: 600 21:33:32: DHCP: SRequest: 310 bytes 21:33:32: DHCP: SRequest: 310 bytes 21:33:32: DHCP: Received a BOOTREP pkt 21:33:32: DHCP: Scan: Message type: DHCP Ack 21:33:32: DHCP: Scan: Server ID Option: 82.252.145.254 = 52FC91FE 21:33:32: DHCP: Scan: Renewal time: 60 21:33:32: DHCP: Scan: Rebind time: 600 21:33:32: DHCP: Scan: Lease Time: 600 21:33:32: DHCP: Scan: Subnet Address Option: 255.255.255.0 21:33:32: DHCP: Scan: Router Option: 82.252.145.254 21:33:32: DHCP: Scan: DNS Name Server Option: 213.228.0.212, 212.27.32.177 21:33:32: DHCP: rcvd pkt source: 82.252.145.254, destination: 82.252.145.104 21:33:32: UDP sport: 43, dport: 44, length: 556 21:33:32: DHCP op: 2, htype: 1, hlen: 6, hops: 0 21:33:32: DHCP server identifier: 82.252.145.254 21:33:32: xid: 475, secs: 0, flags: 0 21:33:32: client: 0.0.0.0, your: 82.252.145.104 21:33:32: srvr: 82.252.145.254, gw: 0.0.0.0 21:33:32: options block length: 308
21:33:32: DHCP Ack Message
21:33:32: DHCP: Lease Seconds: 600 Renewal secs: 60 Rebind secs: 600 21:33:32: DHCP: Server ID Option: 82.252.145.254 21:33:32: DHCP Client Pooling: ***Allocated IP address: 82.252.145.104 toto.free.fr#no debug dhcp DHCP client activity debugging is off toto.free.fr#
Notice that this test is with another version of IOS (Version
12.2(16)) because someone told me that it is possible the 12.3(5a) i used thus now is perhaps boggus
PLEASE HELP !!!! I'm going mad with this problem !!! Thanks !
sam
Have you considered using a WIC-1ADSL instead, maybe that would fix your problems? They are a little on the pricey side though, they're not too bad on ebay.
John Smith
That isn't possible because the ISP DSL modem have VoIP phone ... and it is absolutely needed... I must issue the problem ... Do you think there is a possibility to create an interface dialer which will be redirect to the interface ethernet0/1 ? how can i do that because no login or password is required ? Thanks for your help
sam
Ah, I see.
I'm not sure I really understand what you mean there. Are you using pppoe or pppoatm by the way?
John Smith
The modem is using pppoa but i don't need to identify to the isp because the MAC address of the Modem is known by the isp. It is like a cable modem or a permanent connection.
In a "standard" DSL connection with wic ADSL you have the ATM0 interface, and you use the Interface Dialer0 like that below .
interface ATM0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0.1 point-to-point description $ES_WAN$$FW_OUTSIDE$ pvc 8/35 encapsulation aal5mux ppp dialer dialer pool-member 1
interface Dialer0 description $FW_OUTSIDE$ ip address negotiated ip access-group 101 in no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip inspect DEFAULT100 out encapsulation ppp ip route-cache flow dialer pool 1 dialer-group 1 ppp authentication chap pap callin ppp chap hostname xxxxxx ppp chap password 7 xxxxx ppp pap sent-username xxxxx xxxxxxx
So the idea is to use like that Interface Dialer0 without pap/chap authentication and it use Enternet0/1 instead of ATM0 & ATM0.1 ....
Is it possible ? How doing that ? Because perhaps the negotiation of dhcp broadcast will be better with Dialer0 than with Ethernet0/1 ... If it is mad , tell it to me , because i'm not very good on Cisco routers : i discover them this month !!!!
Thanks
sam
I don't know for sure but my gut tells me that this isn't possible. Effectively you're asking "can I tunnel PPP over PPPoATM", I don't think this is possible, but if it were then you'd need a server/router at the ISP expecting the connection, which I'm afraid you don't have.
Sorry mate, I'm out of my depth, and out of ideas.
Regards Paul.
John Smith
