Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by tony on October 20, 2006, 1:45 pm
Please log in for more thread options links? | ||||||||||||||||||||||
Posted by Martin Bilgrav on October 20, 2006, 2:59 pm
Please log in for more thread options depends.... Do you like the idea, that your hole network is down, because a silly user plugged both ends of a UTP cable into the switch ? (This actually happends alot more than ppl like to think!) STP gives you a loopfree environment, so if you worry about loops, then STP can help you. HTH Martin | ||||||||||||||||||||||
Posted by Markus Marquardt on October 20, 2006, 6:03 pm
> plugged both ends of a UTP cable into the switch ? > (This actually happends alot more than ppl like to think!) Somewhere i read about the injection of malicious STP packets for DoS attacks and other bad things... so what would be the best way to achieve both, security and loop free connections? Regards, Markus | ||||||||||||||||||||||
Posted by Markus Marquardt on October 20, 2006, 6:09 pm
> both, security and loop free connections? BPDU guard? Regards, Markus | ||||||||||||||||||||||
| Similar Threads | Posted |
| spantree. No redundant links | October 20, 2006, 1:45 pm |
| Redundant links between subnets | June 20, 2006, 11:02 am |
| ASA 5520 Redundant Links Inbound/Outbound | March 28, 2007, 8:51 pm |
| Redundant Fiber Links between 4507 and 6509s? | December 31, 2007, 8:42 pm |
| %SPANTREE-7-BLOCK_PORT_TYPE: | March 6, 2007, 12:47 pm |
| %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 3 What does this mean? | August 8, 2006, 10:01 am |
| NAT and failover wan links | July 9, 2007, 7:38 pm |
| pix and two internet links | September 19, 2008, 5:11 am |
| NAT problem over multiple links | June 6, 2006, 11:06 pm |
| RV042 - Information / Links / etc? | August 30, 2007, 6:30 pm |
| Firewalling 2 live WAN links | September 4, 2007, 4:10 pm |
| ASA with VPN access on 2 internet links | October 20, 2008, 4:25 am |
| Multiple Active Internet Links | July 30, 2005, 3:49 pm |
| Serial links / clock rates? | March 28, 2006, 5:46 am |
| LSAs accross WAN links in OSPF | May 11, 2006, 10:12 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> links?
