Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on December 20, 2005, 10:17 am
connecting to an 1841 with a VPN tunnel endpoint on its Dialer0 interface (ADSL WIC on an ISDN line) have no trouble accessing LAN resources (file shares, Exchange mailboxes via a MAPI client, ping, etc.). However, when configuring an IMAP connection on a remote VPN client, outgoing email would not send. The strange thing is that the port 143 traffic between the client and IMAP server flows properly. It turns out that port 25 traffic correctly flows from the client to the SMTP server, but that return traffic from the server to the client does not flow back through the VPN tunnel. Instead it routes back out through the public IP address. Can anyone offer a suggestion? (And please feel free to comment on the config in general, i.e. unnecessary ACL entries, etc.) The VPN address pool is 10.10.10.0/24. The LAN subnet is 10.0.0.0/24. Host 10.0.0.209 is the SMTP server. xxx.xxx.xxx.xxx is the public IP address on Dialer0. The packet trace and startup-config follow: ******S* Seq: 0x65389798 Ack: 0x0 Win: 0x8000 TcpLen: 28 TCP Options (4) => MSS: 1260 NOP NOP SackOK
12/16-07:14:47.845437 xxx.xxx.xxx.xxx:25 -> 10.10.10.17:3753
TCP TTL:127 TOS:0x0 ID:23397 IpLen:20 DgmLen:48 DF
***A**S* Seq: 0x4AE8EFC0 Ack: 0x65389799 Win: 0x44E8 TcpLen: 28 TCP Options (4) => MSS: 1452 NOP NOP SackOK
</snort trace>
version 12.3 no service pad service timestamps debug datetime service timestamps log datetime service password-encryption sntp server yyy.yyy.yyy.yyy clock timezone WET +1 ! boot-start-marker boot-end-marker ! security authentication failure rate 3 log security passwords min-length 6 logging buffered 51200 debugging logging console critical enable secret ***** username admin privilege 15 password ***** ! ! ! <nat config>
ip nat inside source list 110 interface dialer0 overload
! <addresses> ! ! <port forwarding> incoming session-initiating packets
ip nat inside source static tcp 10.0.0.209 25 interface dialer0
25 ! exchange smtp virtual server ip nat inside source static tcp 10.0.0.209 80 interface dialer0 80 ! exchange owa access ip nat inside source static tcp 10.0.0.209 443 interface dialer0 443 ! exchange owa access - ssl ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload ! crypto ! ! <ip - miscellaneous>
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0 ip subnet-zero ip local pool myvpnippool 10.10.10.1 10.10.10.255 ip name-server zzz.zzz.zzz.10 zzz.zzz.zzz.253 ip domain-lookup ip domain-name corp.*******.org ip tftp source-interface Dialer0 no ip finger ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 600 life 86400 requests 10000 no ip source-route ip cef ip tcp synwait-time 10 ip ips po max-events 100 no ip bootp server ip ssh time-out 60 ip ssh authentication-retries 2 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 no ftp-server write-enable logging trap debugging no cdp run route-map SDM_RMAP_1 permit 1 match ip address 110 ! aaa new-model aaa authentication login aaa-authenticated local aaa authorization network aaa-authorized local ! ! <internet security association and key management protocol - isakmp>
crypto isakmp policy 1
! <policy for vpn client phase I negotiations> encryption aes 256 hash md5 authentication pre-share group 2 lifetime 14400 crypto isakmp policy 2 encryption 3des hash md5 authentication pre-share group 2 lifetime 14400 ! <isakmp nat keepalives every 18 seconds>
crypto isakmp nat keepalive 18
! ! <vpn client group>
crypto isakmp client configuration group vpn-client-group
key ***** dns 10.0.0.208 10.0.0.209 domain corp.*******.org pool myvpnippool acl 100 ! ! <phase II policy - actual data encryption>
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac ! ! <dynamic crypto map with associated transform>
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set myset reverse-route ! ! <actual crypto map>
crypto map SDM_CMAP_1 client authentication list aaa-authenticated
crypto map SDM_CMAP_1 isakmp authorization list aaa-authorized crypto map SDM_CMAP_1 client configuration address respond crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1 ! ! <access control lists>
access-list 100 permit ip 10.0.0.0 0.0.0.255 10.10.10.0
! <100 - vpn ip address list - referenced by the isakmp client config> 0.0.0.255 ! ! <110 - nat addresses - interface e1>
access-list 110 deny ip 10.0.0.0 0.0.0.255 10.10.10.0
0.0.0.255 ! no nat for vpn access-list 110 permit ip 10.0.0.0 0.0.0.255 any access-list 110 permit ip 10.10.10.0 0.0.0.255 any ! ! <120 - inbound extended acl - interface Dialer0 (ingress filter)>
access-list 120 permit udp any any eq isakmp
! <vpn> log ! port 500 access-list 120 permit udp any any eq non500-isakmp log ! port 4500 nat-t access-list 120 permit esp any any ! protocol 50 access-list 120 permit ahp any any ! protocol 51 access-list 120 permit ip 10.10.10.0 0.0.0.255 any ! vpn address pool ! <the standard "unlikely's">
access-list 120 deny ip host 0.0.0.0 any
! <deny packets without ip addresses> log ! <deny rfc 1918 addresses - private networks>
access-list 120 deny ip 172.16.0.0 0.15.255.255 any
log access-list 120 deny ip 192.168.0.0 0.0.255.255 any log ! <deny rfc 1112 addresses - multicast (engineer) network>
access-list 120 deny ip 224.0.0.0 15.255.255.255 any
log ! <broadcast (engineer) network>
access-list 120 deny ip 255.0.0.0 0.255.255.255 any
log ! <localhost - loopback address>
access-list 120 deny ip 127.0.0.0 0.255.255.255 any
log ! <ports and ip protocols permitted>
access-list 120 permit udp host zzz.zzz.zzz.10 eq 53 any ! dns
! <dns forwarders> access-list 120 permit udp host zzz.zzz.zzz.253 eq 53 any ! dns2 ! <smtp>
access-list 120 permit tcp any any eq 25
! <anti-spoofing - client internal addresses - rfc 1918 addresses - private networks>
access-list 120 deny ip 10.0.0.0 0.255.255.255 any log
! <https>
access-list 120 permit tcp any any eq 443
! <icmp specifics, !ping request + !ping echo>
access-list 120 permit icmp any any 3 0 log
!net-unreachable access-list 120 permit icmp any any 3 1 log !host-unreachable access-list 120 permit icmp any any 3 3 log !port-unreachable access-list 120 permit icmp any any 3 4 log !packet-too-big access-list 120 permit icmp any any 3 13 log !administratively-prohibited access-list 120 permit icmp any any 4 !source-quench access-list 120 permit icmp any any 11 0 log !ttl-exceeded access-list 120 permit icmp any any echo-reply access-list 120 permit icmp any any echo access-list 120 deny icmp any any ! <sntp>
access-list 120 permit udp host yyy.yyy.yyy.yyy eq 123 any eq
123 ! <telnet>
access-list 120 deny tcp any any eq 23
access-list 120 deny udp any any eq 23 ! <only ack'd packets>
access-list 120 permit tcp any any gt 1023
established ! <deny all other traffic>
access-list 120 deny ip any any
log ! ! <130 - inbound extended acl - interface FastEthernet0/0 (egress filter)>
access-list 130 permit ip any
10.10.10.0 0.0.0.255 !myvpnpool access-list 130 permit 50 any 10.10.10.0 0.0.0.255 !myvpnpool access-list 130 permit 51 any 10.10.10.0 0.0.0.255 !myvpnpool access-list 130 permit ip 10.0.0.0 0.0.0.255 any !<icmp filtering>
access-list 130 deny icmp any any parameter-problem
log-input access-list 130 deny icmp any any reassembly-timeout log-input access-list 130 deny icmp any any port-unreachable log-input access-list 130 permit icmp any any !<deny all other traffic>
access-list 130 deny ip any any
log-input ! ! <outbound cbac commands - interface Dialer0>
ip inspect name my-out-rules cuseeme alert on timeout 3600
ip inspect name my-out-rules ftp alert on timeout 3600 ip inspect name my-out-rules rcmd alert on timeout 3600 ip inspect name my-out-rules realaudio alert on timeout 3600 ip inspect name my-out-rules smtp alert on timeout 3600 ip inspect name my-out-rules tftp alert on timeout 30 ip inspect name my-out-rules udp alert on timeout 15 ip inspect name my-out-rules tcp alert on timeout 3600 ip inspect name my-out-rules h323 alert on timeout 3600 ip inspect name my-out-rules fragment max 100 timeout 4 ! ! <cbac commands - not bound to any particular interface>
ip inspect dns-timeout 31
ip inspect tcp finwait-time 6 ip inspect tcp synwait-time 31 ! interface FastEthernet0/0 description - secure network ip address 10.0.0.250 255.255.255.0 ip nat inside ip tcp adjust-mss 1452 no ip redirects no ip unreachables no ip proxy-arp ip virtual-reassembly ip route-cache flow duplex auto speed auto no cdp enable no mop enabled hold-queue 32 in hold-queue 100 out ip access-group 130 in no shutdown ! interface FastEthernet0/1 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow shutdown duplex auto speed auto no cdp enable no mop enabled ! interface ATM0/0/0 description adsl interface - bound by the dialer interface no ip address no atm ilmi-keepalive bundle-enable dsl operating-mode auto hold-queue 224 in pvc 8/35 encapsulation aal5snap protocol ppp dialer dialer pool-member 1 ! interface Dialer0 description - internet ip address negotiated ip access-group 120 in ip mtu 1492 ip nat outside ip inspect my-out-rules out encapsulation ppp ip tcp adjust-mss 1452 dialer pool 1 dialer-group 1 ppp authentication chap pap callin ppp chap hostname ****@****.*** ppp chap password ***** ppp pap sent-username ****@****.*** password ***** crypto map SDM_CMAP_1 ! line con 0 login authentication aaa-authenticated exec-timeout 120 0 stopbits 1 line aux 0 line vty 0 4 login authentication aaa-authenticated exec-timeout 120 0 length 0 ! ! <syslog server>
logging 10.0.0.180
logging sss.sss.sss.sss logging facility local1 ! scheduler max-task-time 5000 end | |||||||
*some* return traffic not going through vpn tunnel (although not all)
Yahoo!
Windows Live
del.icio.us
digg
Netscape
12/16-07:14:47.757578 10.10.10.17:3753 -> 10.0.0.209:25
