Cisco Systems solution for load sharing ?
Subject Author Date
solution for load sharing ? Fwed 08-17-05
Posted by Fwed on August 17, 2005, 12:03 pm
What solution can i have for share internet connection with 2 atm link ?
So if i have 2 links (2x2M) i have finaly 4M
Thanks a lot,
Fwed
Posted by on August 17, 2005, 8:39 am
You can try Radware`s linkproof.
http://www.radware.com/content/products/lp/default.asp
Posted by Fwed on August 17, 2005, 5:43 pm
Thanks ! but ... i prefere with cisco :)
So i would like a solution with cisco's product ... but i do not find
.... HSRP do not make that, MHSRP also ...
If someone have a solution !
Thanks
Posted by on August 17, 2005, 9:09 am
Add two static route with same AD can enable your two links work
together,but this is a bad idea.You cannot bundle two Internet links
like FEC in LAN.
I think you can not do it with Cisco`s device only.
BTW,HSRP is a standby protocol,when it operates,only one router is
active in the HSRP group at the same time.
Posted by Aaron Leonard on August 17, 2005, 10:47 am
Use IMA, MLPPP, CEF per-packet or CEF per-flow.
White Paper
Alternatives for High Bandwidth Connections Using Parallel T1/E1 Links
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_white_paper09186a0080091d4b.shtml
Cheers,
Aaron
~ Hi,
~ What solution can i have for share internet connection with 2 atm link ?
~ So if i have 2 links (2x2M) i have finaly 4M
~ Thanks a lot,
~ Fwed
Similar ThreadsPosted
solution for load sharing ? August 17, 2005, 12:03 pm
Load Balancing / Load Sharing over parallel paths November 21, 2005, 9:14 am
BGP Load Sharing November 30, 2005, 10:27 am
BGP load-sharing September 16, 2006, 11:37 pm
PBR for load sharing purposes October 30, 2005, 7:30 pm
NAT Overload and load sharing March 25, 2007, 3:03 pm
Traffic Load sharing March 25, 2007, 7:19 pm
Using Netflow and per packet load-sharing October 25, 2005, 7:04 am
BGP load sharing with 2 default gateways November 29, 2005, 10:04 pm
BGP load sharing with 2 default gateways November 29, 2005, 10:07 pm
Load sharing between full T1 and fractional T1 January 9, 2006, 2:58 pm
Circuit group for load-sharing February 20, 2006, 11:15 am
ospf load sharing ASA to Router March 28, 2007, 10:17 pm
Re: Load sharing on 2xWIC 1ADSL May 26, 2007, 8:12 am
load-sharing in two ethernet port of a router October 18, 2007, 2:31 am
