Hi folks
I have some problems doing SNAT. Here is my router's configuration.
interface FastEthernet0/0.6 encapsulation dot1Q 6 ip address 10.10.12.4 255.255.255.0 ip nat inside
interface FastEthernet0/0.33 encapsulation dot1Q 33 ip address 94.200.15.253 255.255.255.0 secondary ip address 192.168.99.253 255.255.255.0 ip nat outside
ip nat inside source route-map EUREX1 interface FastEthernet0/0.33 overload
route-map EUREX1 permit 1 match ip next-hop 33
access-list 33 permit 192.168.99.0 0.0.0.255 access-list 33 permit 94.200.15.0 0.0.0.255
If i do #sh ip nat trans
i get Pro Inside global Inside local Outside local Outside global udp 192.168.99.253:4698 10.10.12.36:4698 94.200.15.21:161 94.200.15.21:161 # inside global should be 94.200.15.253 udp 192.168.99.253:4699 10.10.12.36:4699 94.200.15.21:161 94.200.15.21:161 # inside global should be 94.200.15.253 udp 192.168.99.253:4698 10.10.12.36:4698 192.168.99.21:161 192.168.99.21:161 udp 192.168.99.253:4699 10.10.12.36:4699 192.168.99.21:161 192.168.99.21:161
I tried to set up different subinterfaces for network 192.168.99.0 and
94.200.15.0 but both networks are in the same VLAN and my IOS tells me that VLAN ID 6 is already used by an other interface.I can't use different interfaces for both networks because i am already using all of the 4 installed fastethernet interfaces. I'm using an Cisco 3620 with IOS C3620-IS-M, Version 12.2(16)
So what can i do to set this up correctly?
Hope someone can help.
Regards,
Andre
