SIP incoming calls in CCM
Hello,
I've configure a Cisco Call Manager to send outgoing calls to a a SIP trunk (configured an outgoing dial-peer). I'm trying to receive calls from the same SIP trunk, but I got 530 (internal error) on the SIP server that tries to send the call. How can I receive calls? Do I have to configure a new dial-peer for the incoming calls?
thanks a.
MadAlex
I assume you are talking about CCME (CallManager Express)? What version you are?
Here is a link on how to configure CCME with a service provider. You can use it as a reference.
... and another example:
Good luck,
Mike CCNP, CCDP, CCSP, Cisco Voice, MCSE W2K, MCSE+I, Security+, etc. CCIE R&S (in progress), CCIE Voice (in progress)
------ Headset Adapters for Cisco IP Phones
headsetadapter.com
Phoneswww.ciscoheadsetadapter.comwww.headsetadapter.com
I have SIP trunk on Call manager (not express) with a voice gw with a private T1.
VGW
VGW has:
dial-peer voice 100 voip description USA preference 4 destination-pattern 9001718....... session protocol sipv2 session target ipv4:10.1.1.1 session transport udp codec g711ulaw
CCM end was pretty much defaults. Can port it if required.
Bod43
