Cisco Systems show traffic-shape stat
Subject Author Date
show traffic-shape stat netproj 12-22-05
Posted by netproj on December 22, 2005, 10:56 am
Hello folks
Does anyone know what does "bytes" and "bytes delayed" mean when you do
a sho traffic-shape stat
Is "bytes" the total outbound bytes on the PVC?? If so, how can it be
smaller than "bytes delayed"??
router>sh traffic-shape stat
Access Queue Packets Bytes Packets Bytes
Shaping
I/F List Depth
Delayed Delayed Active
Se2/0.801 0 34260790 673347899 2758814
1991701018 no
Se2/0.803 0 29306533 2734857450 3927828
2851669852 no
Se2/0.804 0 75011411 98453957 2938821
2009853228 no
Posted by Igor Mamuzic on December 24, 2005, 9:29 am
This is because in your case bigger packets (that is, more bytes) have been
delayed in the traffic shaper's queue, so that's why you have more bytes
under delayed column...
If you look into packets counter instead of bytes counter then you will
notice that you have less packets counted under delay column then that you
have under total packets counter...
B.R.
Igor
> Hello folks
> Shaping
> I/F List Depth
> 1991701018 no
> 2851669852 no
> 2009853228 no
Posted by netproj on December 29, 2005, 1:32 pm
Igor, Thanks for the note, actually that is not what I am referring to.
The router was showing an anomaly when you do a show traffiic-shap
stat. The delayed bytes should never be more than the total bytes,
worst case they can be equal, but normally the delayed will be less
than the total, ideally delayed should be no more than 50% of total
bytes.
Similar ThreadsPosted
show traffic-shape stat December 22, 2005, 10:56 am
New FR Circuit Wont Stat Up October 15, 2007, 2:16 pm
show calendar show clock September 17, 2006, 10:39 pm
show ver October 13, 2005, 8:34 am
Show dsl int atm0 February 11, 2005, 3:20 pm
Show commands June 20, 2007, 6:32 pm
Show Crypto Map July 2, 2006, 4:47 am
Show WAN information July 6, 2006, 11:46 am
exiting out of "show run" on PIX July 11, 2006, 3:32 pm
Howto Show RIB and FIB ? March 18, 2007, 12:21 pm
show log filtering August 13, 2008, 1:17 am
LS1010 show version July 12, 2005, 7:57 pm
Timestamps in show log history October 20, 2005, 8:06 am
any way to break out of show command November 15, 2005, 11:48 am
"show ip interfaces brief" and SNMP December 21, 2005, 6:10 pm
