Cisco Systems show amount of traffic passing throw interface
Subject Author Date
show amount of traffic passing throw interface juanbabi@gmail.com 10-18-07
Posted by juanbabi@gmail.com on October 18, 2007, 10:41 am
what is the IOS command to view how much traffic is passing in/out an
interface in a cisco switch/router?
I need it in kbps
it there such a command?
thanks a lot !
Juan
Posted by Trendkill on October 18, 2007, 11:35 am
> Hi,
> I need it in kbps
> thanks a lot !
> Juan
Show int <interface> (example: show int f0/1).
You are looking for txload and rxload (transmit and receive), and it
will be in a number from 0 to 255. You then use that to calculate
your bandwidth. As an example, if its a 100 meg ethernet interface,
126/255 would be 50 megabits. If it was a 45 meg DS3, 200/255 would
be about 35.3 meg. Only other way to do it easier is to get an snmp
poller to get it off the router via snmp, but it still uses the same
function and just does the math for you.
Posted by Sam Wilson on October 18, 2007, 11:54 am
> > Hi,
> > I need it in kbps
> > thanks a lot !
> > Juan
Or, if your traffic is fairly stable, just take the 5 minute input and
output rates given by "show int ..." - these are exponentially weighted
moving averages of the traffic levels so they only approximate to the
traffic level at any particular time. You can also read the input and
output packet and byte counts at set times and subtract them (like an
SNMP poller would). Beware that on some models the interface counts are
only updated at intervals (10 sec on the 6500 I've just tried it on) so
either read them frequently and look for the points at which they
change, or read them infrequently so the update period doesn't matter.
Sam
Posted by on October 18, 2007, 12:24 pm
>> Hi,
>> I need it in kbps
>> thanks a lot !
>> Juan
Interesting. That approach seems somewhat backward to me.
If you look further on the show interface display you'll see
"5 minute input rate" and "5 minute output rate".
My testing indicates that the "5 minute input rate" and "5 minute
output rate" are used as the basis for computing txload and rxload.
txload = floor ( 255 * 5 minute input rate / interface bandwidth )
rxload = floor ( 255 * 5 minute output rate / interface bandwidth )
Posted by alexd on October 18, 2007, 2:31 pm
> According to Cisco: "Load on the interface (in the transmit "tx" and
> receive "rx" directions) as a fraction of 255 (255/255 is completely
> saturated), calculated as an exponential average over 5 minutes."
> However, I need to understand what 'exponential average' means.
Just as a guess, I would imagine it means that more recent values [within
the five minute window] have an exponentially greater weighting when
calculating the average. So whilst it's an average over five minutes, it
reacts quicker to changes in network usage than an unweighted one.
<http://ale.cx/> (AIM:troffasky) (UnSoEsNpEaTm@ale.cx)
19:29:19 up 17 days, 21:18, 3 users, load average: 0.12, 0.15, 0.17
09 f9 11 02 9d 74 e3 5b d8 41 56 c5 63 56 88 c0
Similar ThreadsPosted
show amount of traffic passing throw interface October 18, 2007, 10:41 am
Passing traffic through an ASA August 2, 2007, 7:29 pm
PIX 515 to PIX 515e not passing traffic May 10, 2006, 12:04 pm
passing wccp traffic via firewall May 25, 2006, 11:04 am
udp traffic not passing over vpnclient connection to pix ASA 7.2 August 29, 2006, 4:24 pm
ASA Stops passing traffic but does not crash November 22, 2006, 2:24 pm
ASA5505 not passing inbound TCP traffic (what am I missing)? August 24, 2007, 2:45 pm
cisco vpn connection to vpn concentrator 3000 not passing web traffic August 21, 2006, 11:44 pm
What does the DLY mean in a "show interface" command? February 2, 2006, 8:35 am
show traffic-shape stat December 22, 2005, 10:56 am
"show policy-map interface" and SNMP August 30, 2005, 10:41 am
High latency when idle, low latency when passing traffic April 24, 2006, 7:15 pm
Show policy-map interface output with nested class-maps November 30, 2005, 11:52 am
traffic routing between serial and dsl interface October 5, 2005, 11:36 am
Route voip traffic to different interface October 19, 2007, 12:15 pm
