Cisco Systems server load balancing using a cisco
Subject Author Date
server load balancing using a cisco Elia Mazzawi 07-14-05
Posted by Elia Mazzawi on July 14, 2005, 9:34 am
Hello,
i need some advice selecting cisco hardware for the place i work at.
we need to load balance some high traffic high B/W apache web servers
the servers are all identical and they do not use any type of sessions
( stateless )
so a user can go to a different server each request.
i was thinking about getting a cisco to do layer 2 or 3 load balancing,
my quesions are:
can this be done at layer 2 or 3 ?
what hardware do we need?
it also needs to have some failover.
how much B/W and concurrent connections can it do?
we wanted to go with a router instead of those hardware load balancers
for scalability
i read about SLB in the cisco catalyst 6500, is this the best way to do
this?
thanks.
Posted by BradReeseCom on July 14, 2005, 4:00 pm
Hi Elia,
You may find the WS-X6066-SLB-APC Data Sheet helpful:
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_data_sheet09186a00800887f3.html
Brad Reese
BradReese.Com Cisco Repair Service Experts
1293 Hendersonville Road, Suite 17
Asheville, North Carolina USA 28803
Toll Free: 877-549-2680
International: 828-277-7272
Website:   http://www.bradreese.com/cisco-big-iron-repair.htm
Posted by Make on July 15, 2005, 6:48 pm
There is also IOS SLB in Catalyst 6500. But this "requires" IOS SLB license
fee.
viestissä:1121382019.742168.3020@g47g2000cwa.googlegroups.com...
Posted by Elia Mazzawi on July 15, 2005, 12:25 pm
does the content switching module scale better than the ISO - SLB?
why would some one get one rather than the other?
i just know i'm going to be asked that if i say it can do it in 2 ways.
Posted by BradReeseCom on July 15, 2005, 7:52 pm
Hi Elia,
Here is advice from two CCIEs regarding IOS SLB vs. CSM on the Cisco
6500.
IOS SLB is only intended for low volume load balancing with very
limited functionality.
The two solutions are worlds apart from a performance perspective, and
as you've read, the CSM has many more features (including HTTP probes
for checking server availability).
IOS SLB offers a L4-7 load balancing solution.
Be aware that as soon as you do L7 or do some nating, you will get poor
performance with just IOS SLB compared to a CSM.
One advantage of IOS SLB is the capacity to do Radius load balancing
[inspecting Radius packets to identify Framed IP, ...]
If you just need VPN or Firewall load balancing, IOS SLB is enough.
Should you need HTTP or any other traffic the CSM is a better choice.
Or you can combine both IOS SLB and CSM.
IOS SLB is used to load balance Radius and the CSM is used to load
balance the rest of the traffic.
Sincerely,
Brad Reese
BradReese.Com Cisco Repair Worldwide
http://www.bradreese.com/ebay-cisco-repair.htm
Similar ThreadsPosted
server load balancing using a cisco July 14, 2005, 9:34 am
How To Force Load Balancing For Incoming Traffic to One Server Through 5500 / 6500 Switches? September 14, 2005, 1:46 pm
Cisco for load balancing w/o BGP October 11, 2006, 12:14 pm
Load Balancing / Load Sharing over parallel paths November 21, 2005, 9:14 am
configure cisco load balancing with daul isp May 20, 2007, 6:46 am
Load Balancing February 15, 2005, 6:13 pm
load-balancing t1s August 30, 2005, 2:54 pm
Load Balancing February 20, 2006, 11:33 am
OER and load balancing March 2, 2006, 10:06 am
load balancing January 3, 2007, 8:35 pm
load-balancing t1s February 16, 2007, 1:43 pm
To QoS or load-balancing or both July 21, 2008, 5:35 pm
Load Balancing NxSTM1s August 23, 2005, 10:36 pm
RV042 and pix with load balancing October 12, 2005, 9:01 am
Load Balancing 2 Routes October 17, 2005, 8:08 am
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
