Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on May 1, 2008, 5:19 pm
Please log in for more thread options I have been asked to supply the serial number for some 7600s - so they can be explicitly identified for insurance purposes and a bit later for service contract. Not quite sure what might meet this requirement - is there a serial ID physically fixed to the box. Might the MAC address be OK or something else -possibly queried by telnet (or SNMP). TIA JJ | |||||||||||||
Posted by stephen on May 1, 2008, 5:23 pm
Please log in for more thread options try "show hardware" at a console session > Not quite sure what might meet this requirement - is there a serial ID
> physically fixed to the box. probably - but your biggest issue is likely to be which serial number, since every item that could be swapped by an engineer has one, some of the daughter cards etc....... > Might the MAC address be OK or something else -possibly queried by
> telnet (or SNMP). > > TIA > > JJ Regards stephen_hope@xyzworld.com - replace xyz with ntl | |||||||||||||
Posted by Merv on May 1, 2008, 6:38 pm
there are a variety of commands that may give you the info you are looking for show version show hardware show inventory show module show diag show idprom backplane There will be a serial number for the chassis affixed somewhere you need to look at one and them match up the output from the above commands the will be a chgassi serial number and there will be a module serila number for each o the cards in the chassis along with power supplies etc | |||||||||||||
| Similar Threads | Posted |
| serial number for 7600 | May 1, 2008, 5:19 pm |
| serial number of installed gbic/sfp | January 31, 2006, 8:06 am |
| Channelised ISDN E1/PRI and serial interfaces number | September 10, 2007, 3:08 am |
| 7200 vs 7600 VLANs | January 17, 2006, 12:17 pm |
| module memory on 7600 | October 26, 2006, 10:10 am |
| PPPoE Relay on 7600 through MPLS..... | November 19, 2005, 2:02 pm |
| Configuration Tool - 7600 - Select Powersupply | September 2, 2006, 11:47 am |
| 6500/7600 Sup module performance specs | August 4, 2008, 1:36 pm |
| 7600 L4 ports usage in per-flow load-sharing | December 27, 2005, 6:33 am |
| VPN and limit on the number of connections. | October 25, 2005, 10:56 am |
| Number of VPN tunnels on 506E | March 20, 2006, 9:14 am |
| authentication of the destination number | July 25, 2006, 11:19 pm |
| How to determine the IOS product number | February 22, 2007, 5:30 am |
| What is the hex number at the end of an access-list? | March 14, 2007, 1:03 pm |
| how to find a port number | June 25, 2007, 10:03 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
