Hi there.
I have a 2621 router that I would like to add serial module.
I searched the eBay and saw 4a/s module.
Is that good enough to do frame relay?
I would like to have that 2621 as frame relay clooud.
Please help.
thank you
-Thomas
Hi there.
Please help.
thank you
-Thomas
You will need a connection for each router that the cloud connects to. So if you are simulating three sites, you will need a frame-relay cloud router with 3 interfaces, and 3 routers with one interface each to simulate the end-points.
Sure, but what are you hooking to the other end? More routers with serial cards such as the WIC-1T or WIC-2T?
Is this going to be a WAN using telco circuits? Which kind of circuits?
Those are bigger questions on how to physically connect things rather than seeing if an interface supports a protocol (it almost always will on Cisco devices if you are matching up the right stuff).
I'll use one 2621 with A/S Serial board and have two 2514s
So I would like to use 2621 as the cloud and simulate connecting two
2514 connecting through cloud using frame relay.-Thomas
Okay, thats quite do-able, and fairly easy to cable. You just need the DCE-DTE DB60 cables. Dime a dozen on eBay (well not quite, but just a few bucks). You'll find setups just like this as "labs" on eBay.
Your main limititation is the speed limits of the NM-4A/s module. You aren't going to get anywhere close to 2Mbps on each port, but since it sounds like this is lab setup, it shouldn't matter. Just keep in mind the limits.
