Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on August 15, 2005, 7:21 am
Please log in for more thread options Hello I just logged in to a remote router. i typed enable and it got me in enable mode without password. then i did config t and type password enable myenablepassword and write mem. i loged in again to the router but it did not prompt for enable password, does anyon know what could be wrong? thanks | |||||||||||||||||||
Posted by dt1649651@yahoo.com on August 15, 2005, 10:53 am
Please log in for more thread options jcharth@hotmail.com wrote: Do you login with a username who already has priviledge 15 ? I think if it is the case, then 'enable' won't ask you a password any more. DT | |||||||||||||||||||
Posted by on August 16, 2005, 9:50 am
line vty 0 4 privilege level 15 password 7 XXXXXXXXXXXXXXXXXX transport input telnet ! no scheduler allocate ! end May be this explains something? but i still can figure out way. I was reading about auto enable. I believe my user privilage is 7. Looks normal. Thanks | |||||||||||||||||||
Posted by dt1649651@yahoo.com on August 16, 2005, 2:07 pm
jcharth@hotmail.com wrote: > line vty 0 4
> privilege level 15 > password 7 XXXXXXXXXXXXXXXXXX > transport input telnet > ! > no scheduler allocate > ! > end > May be this explains something? but i still can figure out way. I was > reading about auto enable. I believe my user privilage is 7. Looks > normal. Thanks For the above config, I believe anybody who can telnet to your router will have the privilege 15, which will give you the higest permission. So if you can login, you do not have to submit the enable password any more. You can delete that line "privilege level 15", and assign each user an appropriate privilege level. Then it will ask you for a password for the enable command. DT | |||||||||||||||||||
Posted by on August 16, 2005, 5:12 pm
Thanks, i figure it out after googleing for a while.I was starting to think there was something wrong with the router. | |||||||||||||||||||
| Similar Threads | Posted |
| router wont prompt enable | August 15, 2005, 7:21 am |
| no enable prompt | January 9, 2008, 11:54 pm |
| 831 Router with virtual AUX; no prompt | December 15, 2006, 7:06 am |
| Router Booted to Weird Prompt | January 23, 2008, 11:17 am |
| Cisco Router wont allow telnet over port 9999 | July 7, 2006, 2:47 pm |
| 3640 Router, no crypto isakmp enable | February 15, 2005, 1:30 pm |
| Is there a router equivalent of the catalyst's "enable engineer"? | February 22, 2006, 12:52 am |
| How to enable firewall logging on a cisco 857 router | May 26, 2008, 7:46 am |
| how to enable logging for DHCP events on a router> | November 7, 2008, 9:39 pm |
| Access to router without enable password ? (cisco 3620) | October 28, 2007, 1:04 am |
| 3750G wont post | January 8, 2007, 4:26 pm |
| New FR Circuit Wont Stat Up | October 15, 2007, 2:16 pm |
| help on 2500 boot prompt | August 16, 2005, 3:38 pm |
| Login prompt problem | March 27, 2007, 6:31 pm |
| Transfer from voicemail prompt | August 13, 2008, 3:52 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> be wrong? thanks
