I have a Cisco 2620 router running IOS ver 12.0(7)T. FastEthernet 0/0 has an ip 69.92.216.130 255.255.255.252 FastEthernet 0/1 has
69.92.216.145 255.255.255.240.When I run show ip route it shows:
69.0.0.0/8 is variably subnetted, 2 subnets, 2 masks C 69.92.216.144/28 is directly connected, Ethernet1/0 C 69.92.216.128/30 is directly connected, FastEthernet0/0This works fine.
My problem is I want to configure an older router as a spare. It is a
2514 running IOS version 12.1(16). When I configure the Ethernet0 with 69.92.216.130 255.255.255.252, the port comes up and the line protocol comes up. When I configure Ethernet1 with 69.92.216.145 255.255.255.240 the interface comes up but the line protocol does not.When I run show ip route it shows:
69.0.0.0/30 is subnetted. 1 subnets 69.92.216.128 is directly connected. Ethernet 0Any ideas on how I can get the 2514 to route those two subnets?
Thanks
