Cisco Systems route-map question (how to policy route for all destinations except few subnets?)
Subject Author Date
route-map question (how to policy route for all destinations except few subnets?) binand@gmail.com 08-13-05
Posted by binand@gmail.com on August 13, 2005, 2:05 am
Hi All,
I have a setup like this:
192.168.100.0/24 is a VLAN with internet connection via ISP1.
172.16.100.0/24 is a VLAN with internet connection via ISP2.
Right now, I have these VLANs on separate (Catalyst 4506) switches. I
am trying to combine them onto a single switch, with route-maps. Here
is my configuration:
access-list 160 permit ip 172.16.100.0 0.0.0.255 any
route-map ISP2 permit 20
match ip address 160
set ip next-hop 172.16.100.254
int vlan 50
desc ISP2
ip address 172.16.100.1 255.255.255.0
ip policy route-map ISP2
int vlan 25
desc ISP1
ip address 192.168.100.1 255.255.255.0
This works fine. Now, I'd like to have IP connectivity between the two
VLANs. How should I modify my ACL for that? I tried:
access-list 160 deny ip 172.16.100.0 0.0.0.255 192.168.100.0 0.0.0.255
Which didn't work. I thought if the route-map encountered a deny ACL,
default routing would take place, but that does not seem to be the
case.
The default routing table on the switch looks like:
C 192.168.100.0/24 is directly connected, Vlan25
C 172.16.100.0/24 is directly connected, Vlan50
S* 0.0.0.0/0 [1/0] via 192.168.100.254
192.168.100.254 and 172.16.100.254 are my firewalls (two Netscreens).
TIA,
Binand
Posted by Barry Margolin on August 13, 2005, 4:52 pm
> Hi All,
> int vlan 50
> desc ISP2
> int vlan 25
> desc ISP1
Change "set ip next-hop" to "set ip default next-hop". Then the policy
route will only override the default route. Connected routes, static
routes, and routes learned via a routing protocol will still be used
between the VLANs.
Barry Margolin, barmar@alum.mit.edu
Arlington, MA
*** PLEASE post questions in newsgroups, not directly to me ***
Similar ThreadsPosted
route-map question (how to policy route for all destinations except few subnets?) August 13, 2005, 2:05 am
policy route-map question January 11, 2007, 10:54 am
HSRP and Policy Route May 1, 2007, 3:53 pm
Question about subnets January 14, 2007, 1:54 pm
Routing behind the PIX to multiple destinations June 28, 2005, 11:21 am
ASA Policy NAT Question September 14, 2006, 9:12 am
Question about NAT (maybe need to use policy NAT)? June 30, 2008, 6:09 pm
Outbound Dial Peer for URI Destinations September 19, 2006, 11:47 am
PIX question Policy NAT - quite urgent - March 11, 2005, 11:35 am
question for static route -- default route April 1, 2009, 12:03 am
question for static route -- default route April 1, 2009, 12:04 am
Policy Based Routing Question November 13, 2005, 7:38 pm
Policy Routing: Guaranteeing Bandwidth Question March 27, 2007, 11:23 pm
policy based routing for multiple tracking options question April 9, 2006, 8:42 pm
BGP Route Question October 27, 2005, 9:06 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
