I need a solution for cable management for 48 port blades in 6500s.
RJ21 is what I would like to do but they don't seem to have an RJ21 blade that does Gigabit Ethernet (copper), they do have them in 48 port RJ45 though.
So, I need a successful method for cable management of RJ45 ports (48) so that if I need to replace a blade for any reason I can easily remove all 48 ethernet connections and connect them back up correctly.
A couple of weeks ago I needed to replace a Sup720 and the RJ45 cables were all over the place and in the way (I didn't do it). It took me 15 minutes to get things so that I could pull the blade out and then another 10 to get it back in. PAINFUL!
Any suggestions would be appreciated.
