Hi guys Having problems using reverse telnet.
Using the AUX port on a 2610 connecting to the Console port of a 3550 switch using a straight through cable.
AUX port on 2610 is configured like this: line aux 0 modem InOut transport input all stopbits 1 speed 19200 flowcontrol hardware
Loopback 0
10.0.0.1 255.255.255.0The AUX port is on line 65 so therefore telnet 10.0.0.1 4065
I get the prompt for username and password.
The first problem was that each character I typed I got twice so I used the /noecho switch on the telnet command which resolved this.
The next problem is that I enter the username and password, but I then get nothing. It locks up and accepts no further input. I have to disconnected and start again but the same thing happens everytime.
Any help appreciated. Cheers Mike
