I bought myself a used uBR904 cable router. I hooked it up to the network and was hoping that the DHCP server would be running and would assign an IP to my laptop. That way, I would have had telnet access to the router. It seems though that the DHCP has been disabled.
The router only has the RJ45 port to hook up a terminal and I don't have a "rollover" cable.
So I read all the documentation available on this router in order to figure out how to reset it to factory defaults. But all I was able to find was the console commands to do that. Not really an option for me at this point ;-)
Is there any other way? Maybe a jumper (like wiping out the BIOS of a PC)?
Thanks, Torsten
