Hello, Trendkill! You wrote on 29 Mar 2007 05:48:58 -0700:
??>> I need information about a replacement product for the cisco ??>> 2511 with 16 x RJ45 Which one can I use ? In the cisco doc I ??>> found as replacement the 2610XM...but I don't think it has 16 x ??>> RJ45 ?! ??>> ??>> And also what about the cables for the 2511? Is ist possible ??>> that I can order additional cables for the 2511 ?
T> Why not just buy a L3 switch with 24 or 48 ports that you can turn T> up router interfaces on? I'd like some more information on why T> you need a router with 16 ethernet interfaces...then we may be T> able to suggest better alternatives.
Well, 16 RJ45 interfaces on 2511 are not ethernet ones.
With best regards, Andrey.
