Hi I am trying to connect to a PIX (a very old version) firewall and I get the dreaded 412 error (The remote peer is no longer responding). Googled it and no relevant posts. Can someone kindly help me figure this out?
Cisco Systems VPN Client Version 4.0.5 (Rel) Copyright (C) 1998-2003 Cisco Systems, Inc. All Rights Reserved. Client Type(s): Windows, WinNT Running on: 5.1.2600 Service Pack 2
1 21:52:59.515 12/14/06 Sev=Info/4 CM/0x63100002 Begin connection process2 21:52:59.718 12/14/06 Sev=Info/4 CM/0x63100004 Establish secure connection using Ethernet
3 21:52:59.718 12/14/06 Sev=Info/4 CM/0x63100024 Attempt connection with server "209.178.198.242"4 21:53:02.781 12/14/06 Sev=Critical/1 CVPND/0xE3400003 Function SocketApiBind() failed with an error code of
0xFFFFFFF8(f:\\temp\\IPSecClient\\Rel\\PubKeyPK\\SRC\\ike-init-state.cpp:390)5 21:53:02.781 12/14/06 Sev=Critical/1 CVPND/0x63400012 Unable to bind to IKE port. This could be because there is another VPN client installed or running. Please disable or uninstall all VPN Clients other than the Cisco VPN Client.
6 21:53:02.828 12/14/06 Sev=Info/4 CM/0xE3100003 Failure to Initialize IKE ports7 21:53:02.828 12/14/06 Sev=Info/5 CM/0x63100025 Initializing CVPNDrv
8 21:53:02.906 12/14/06 Sev=Info/4 IPSEC/0x63700008 IPSec driver successfully started9 21:53:02.906 12/14/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
10 21:53:02.906 12/14/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys11 21:53:02.906 12/14/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
12 21:53:02.906 12/14/06 Sev=Info/4 IPSEC/0x6370000A IPSec driver successfully stopped13 21:54:28.671 12/14/06 Sev=Info/4 CM/0x63100002 Begin connection process
14 21:54:28.765 12/14/06 Sev=Info/4 CM/0x63100004 Establish secure connection using Ethernet15 21:54:28.765 12/14/06 Sev=Info/4 CM/0x63100024 Attempt connection with server "209.178.198.242"
16 21:54:28.796 12/14/06 Sev=Info/6 IKE/0x6300003B Attempting to establish a connection with 209.178.198.242.17 21:54:29.109 12/14/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Nat-T), VID(Frag), VID(Unity)) to 209.178.198.242
18 21:54:29.453 12/14/06 Sev=Info/4 IPSEC/0x63700008 IPSec driver successfully started19 21:54:29.453 12/14/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
20 21:54:29.578 12/14/06 Sev=Info/5 IKE/0x6300002F Received ISAKMP packet: peer = 209.178.198.24221 21:54:29.578 12/14/06 Sev=Info/4 IKE/0x63000014 RECEIVING > ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, VID(?), VID(Unity)) to 209.178.198.242
27 21:54:29.593 12/14/06 Sev=Info/4 IKE/0x63000082 IKE Port in use - Local Port = 0x01F4, Remote Port = 0x01F428 21:54:29.593 12/14/06 Sev=Info/4 CM/0x6310000E Established Phase 1 SA. 1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
29 21:54:29.593 12/14/06 Sev=Info/4 CM/0x6310000E Established Phase 1 SA. 1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system30 21:54:30.046 12/14/06 Sev=Info/5 IKE/0x6300005D Client sending a firewall request to concentrator
31 21:54:30.046 12/14/06 Sev=Info/5 IKE/0x6300005C Firewall Policy: Product=Cisco Systems Integrated Client, Capability= (Centralized Protection Policy).32 21:54:30.046 12/14/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 209.178.198.242
33 21:54:30.109 12/14/06 Sev=Info/5 IKE/0x6300002F Received ISAKMP packet: peer = 209.178.198.24234 21:54:30.109 12/14/06 Sev=Info/4 IKE/0x63000014 RECEIVING > ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to 209.178.198.242
42 21:54:30.406 12/14/06 Sev=Info/5 IKE/0x6300002F Received ISAKMP packet: peer = 209.178.198.24243 21:54:30.406 12/14/06 Sev=Info/4 IKE/0x63000014 RECEIVING > ISAKMP OAK QM *(Retransmission) to 209.178.198.242
48 21:54:40.453 12/14/06 Sev=Info/4 IKE/0x63000021 Retransmitting last packet!49 21:54:40.453 12/14/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK QM *(Retransmission) to 209.178.198.242
50 21:54:45.453 12/14/06 Sev=Info/4 IKE/0x63000021 Retransmitting last packet!51 21:54:45.453 12/14/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK QM *(Retransmission) to 209.178.198.242
52 21:54:50.453 12/14/06 Sev=Info/4 IKE/0x6300002D Phase-2 retransmission count exceeded: MsgID=586F5A3353 21:54:50.453 12/14/06 Sev=Info/6 IKE/0x6300003D Sending DPD request to 209.178.198.242, seq# = 3403392917
54 21:54:50.453 12/14/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) to 209.178.198.24255 21:54:50.453 12/14/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to 209.178.198.242
56 21:54:50.453 12/14/06 Sev=Info/4 IKE/0x63000048 Discarding IPsec SA negotiation, MsgID=586F5A3357 21:54:50.500 12/14/06 Sev=Info/5 IKE/0x6300002F Received ISAKMP packet: peer = 209.178.198.242
58 21:54:50.500 12/14/06 Sev=Info/4 IKE/0x63000014 RECEIVING > ISAKMP OAK INFO *(HASH, DEL) to 209.178.198.24262 21:55:20.953 12/14/06 Sev=Info/4 IKE/0x6300004A Discarding IKE SA negotiation (I_Cookie=37BCC08204AE4596 R_Cookie=4DFC26D470437156) reason = DEL_REASON_PEER_NOT_RESPONDING
63 21:55:20.953 12/14/06 Sev=Info/4 CM/0x63100012 Phase 1 SA deleted before first Phase 2 SA is up cause by "DEL_REASON_PEER_NOT_RESPONDING". 0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system64 21:55:20.953 12/14/06 Sev=Info/5 CM/0x63100025 Initializing CVPNDrv
65 21:55:20.984 12/14/06 Sev=Info/4 IKE/0x63000001 IKE received signal to terminate VPN connection66 21:55:21.453 12/14/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
67 21:55:21.453 12/14/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys68 21:55:21.453 12/14/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
69 21:55:21.453 12/14/06 Sev=Info/4 IPSEC/0x6370000A IPSec driver successfully stopped
