Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on May 12, 2008, 11:44 am
Please log in for more thread options microwave links. the links are of different brand and can not be redundant by them self. if one link fails i am currently shutting down that interface and bring up the interface for the spare link on the catalyst. here the current interface config: 3548-XL interface FastEthernet0/43 description ll02 duplex full speed 100 switchport trunk encapsulation dot1q switchport mode trunk ........ interface FastEthernet0/48 description ll01 shutdown duplex full speed 100 switchport trunk encapsulation dot1q switchport mode trunk and the other side the 3524-XL interface FastEthernet0/19 description ll02 duplex full speed 100 switchport trunk encapsulation dot1q switchport mode trunk ........ interface FastEthernet0/23 description ll01 duplex full speed 100 switchport trunk encapsulation dot1q switchport mode trunk fe0/43 - fe0/19 are one link and fe0/48 - fe0/23 are one link. i have read about port group and have tried to configure that today, i can issue the commands and the config does show the ports in the port group but i cant pass any traffic. i had all 4 interfaces in port group 1. is port group the wrong thing to do for what i try to achieve ? any advice is very welcome. regards Jan | |||||||||||||
Posted by Trendkill on May 13, 2008, 2:13 pm
Please log in for more thread options Do you have to trunk? Why not turn up a diff subnet on the remote side and turn up layer 3 routing between sites via both links? If one drops, routing will failover to the second link since the adjacency will drop. If you can't do this, I'm not sure why a link failure wouldn't failover with your configuration anyway. If you have two trunks, only one is being used at any given time (to avoid a loop), and if it fails, spanning-tree should run and it should go forwarding on the other trunk. What am I missing? | |||||||||||||
Posted by Trendkill on May 13, 2008, 2:16 pm
Please log in for more thread options > On May 12, 11:44 am, jan.paul...@gmail.com wrote:
> > > > > the current situation is that we have 2 sites connected with 2
> > microwave links. the links are of different brand and can not be > > redundant by them self. if one link fails i am currently shutting down > > that interface and bring up the interface for the spare link on the > > catalyst. here the current interface config: >
> > 3548-XL
> > interface FastEthernet0/43 > > description ll02 > > duplex full > > speed 100 > > switchport trunk encapsulation dot1q > > switchport mode trunk > > ........ > > interface FastEthernet0/48 > > description ll01 > > shutdown > > duplex full > > speed 100 > > switchport trunk encapsulation dot1q > > switchport mode trunk >
> > interface FastEthernet0/19 > > description ll02 > > duplex full > > speed 100 > > switchport trunk encapsulation dot1q > > switchport mode trunk > > ........ > > interface FastEthernet0/23 > > description ll01 > > duplex full > > speed 100 > > switchport trunk encapsulation dot1q > > switchport mode trunk >
> > can issue the commands and the config does show the ports in the port > > group but i cant pass any traffic. i had all 4 interfaces in port > > group 1. is port group the wrong thing to do for what i try to > > achieve ? >
> > regards
> > Jan >
> Do you have to trunk? Why not turn up a diff subnet on the remote > side and turn up layer 3 routing between sites via both links? If one > drops, routing will failover to the second link since the adjacency > will drop. If you can't do this, I'm not sure why a link failure > wouldn't failover with your configuration anyway. If you have two > trunks, only one is being used at any given time (to avoid a loop), > and if it fails, spanning-tree should run and it should go forwarding > on the other trunk. What am I missing? If you want to load share, and presuming both links are equal bandwidth and go between the same two switches, have you tried etherchannel? If its just a layer 2 connection at each switch, they most likely have no idea that there is a microwave between them, and etherchannel would allow both ports to belong in the same channel unless one went down. Else the layer 3 suggestion from my previous post will work fine, as long as both links are equal bandwidth, any decent routing protocol should load share the paths presuming its the same end points on both sides. | |||||||||||||
Posted by on May 14, 2008, 2:18 am
Please log in for more thread options routing is not possible, for "historic" reasons i have to stick to the
current setup. the microwave links behaving transparent to the switches and the switches "believe" there is a cable between them. yes both links have the same capabilities, 34mbit/s. i had tried just to enable all for interfaces and leave spanning tree do the job. i noticed it takes about 5 minutes for traffic to pass if the currently active link fails. so i was looking for something which will fail over within seconds. i believe port group is etherchannel on cisco switches, if not please elaborate, i try in the meanwhile to find some documentation on the web. thanks to both of you. Jan | |||||||||||||
Posted by on May 14, 2008, 3:47 am
Please log in for more thread options On 14 May, 08:18, jan.paul...@gmail.com wrote:
> current setup. the microwave links behaving transparent to the > switches and the switches "believe" there is a cable between them. yes > both links have the same capabilities, 34mbit/s. i had tried just to > enable all for interfaces and leave spanning tree do the job. i > noticed it takes about 5 minutes for traffic to pass if the currently > active link fails. so i was looking for something which will fail over > within seconds. i believe port group is etherchannel on cisco > switches, if not please elaborate, i try in the meanwhile to find some > documentation on the web. > > thanks to both of you. I think that the key here is 'how realistic a wire does the microwave link provide'. If it really does look like a wire to the switch and the port goes DOWN iif the link does then I think that you could use etherchannel. This uses port groups in its confguration statements. If on the other hand it is not such a good simulation of a wire you will I think have to use Spanning tree. You can do a form of load balancing with STP if you have more than one VLAN in use by having some VLANS use one link by preference and some VLANs using the other. By defaut STP takes 30 (35?) seconds I seem to recall to transition to forwarding in the event of a link failure in your topology. Thre is now RSTP but maybe your old switched do not do it. The timers are tunable to make convergence faster. Thing is you say that yours is taking 5 mins. Unless your timers have been changed the other way then something else is causing the delay. If you post the whole config maybe someone will have a look? | |||||||||||||
redundancy and load balancing between catalyst 3524-XL and catalyst 3548-XL
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> 3548-XL
> description ll02
> duplex full
> speed 100
> description ll01
> shutdown
> duplex full
> speed 100
> description ll02
> duplex full
> speed 100
> description ll01
> duplex full
> speed 100
> achieve ?
> regards
> Jan
