Hello, Scott! You wrote on 29 Mar 2005 08:56:49 -0800:
S> G.729 with 60 bytes voice payload size, according to cisco that S> should be about 16.52 kbps per call.
S> So about 6Mbps total
OK. Why do you think it's 1841? Given that you tried without CEF and didn't see any difference I doubt it's a problem with router performance. As for places to look - duplex negotiation between 1841, VoIP GW and any switches in between; ability of VoIP GW to handle 16 T1; how WAN is capped and if there other traffic creating a problem. Do you run any fancy queuing? What's about other end of WAN link, what do you have there?
With best regards, Andrey.
