I'm having problems configuring Radius attributes for a VPN 3000 Concentrator on ACS 3.3(2) Build 2. I have added an AAA client and set it to authenticate using Radius (Cisco VPN 3000). I then went into 'Interface Configuration' and selected 'RADIUS (Cisco VPN 3000)' and selected a range of attributes.
When I edit any of my groups, I can see a section header of "Cisco VPN
3000 Concentrator RADIUS Attributes", but no entries are displayed.I've tried enabling 'Per-user TACACS+/RADIUS Attributes' under the advanced configuration options in 'Interface Configuration' and enabling all the radius attributes on a per-user basis, but if I edit an existing user I still see no options for VPN 3000 RADIUS.
I've double-checked the list of AAA clients and I can definitely see at least one that is authenticating via RADIUS (Cisco VPN 3000). Has anyone else seen a similar problem?
Cheers, Chris
