Cisco Systems question about timeout conn
Subject Author Date
question about timeout conn Joseph R 04-21-06
Posted by Joseph R on April 21, 2006, 11:55 am
'timeout conn' Controls all active tcp sessions through a pix correct?
Such as rdp, telnet, client-server communications etc...
What are the repercusions of setting the timeout to a high value around
5-9 hours. We are working with a highly distributed network of vpn's
joing roughly 15 offices. I worry that setting the timeout to a high
value that it might impact the pix unit adversely.
Any input would be great. Thanks,
Posted by Walter Roberson on April 21, 2006, 8:41 pm
Close, but not -exactly-, in that a few TCP protocols have individual
timers -- RPC for example.
timeout conn only affects -idle- connections. Each active
connection uses some memory. If your systems generate idle connections
faster than they are cleaned up by 'timeout conn' then you would
eventually run out of memory.
RDP and telnet and most client-server communications don't generate
many connections. http can generate a lot of connections, but it is
not common for http connections to sit idle (but it could happen.)
The only thing I've encountered so far that generated a noticable
number of idle connections is MS Exchange client talking to
an Exchange 2000 server.
Similar ThreadsPosted
FWSM "timeout conn" setting - Applies to inbound conn.s? February 9, 2005, 5:47 pm
question about timeout conn April 21, 2006, 11:50 am
question about timeout conn April 21, 2006, 11:55 am
Help with "sho conn" flag (PIX 7.x) March 13, 2007, 7:46 pm
Teardown TCP conn...... Flow closed by inspection November 28, 2006, 7:29 am
Cisco FWSM- snmpwalking for the show conn information September 11, 2006, 6:13 pm
Cisco FWSM- snmpwalking for the show conn information September 11, 2006, 6:24 pm
FIN Timeout August 26, 2005, 1:18 pm
VPN Timeout October 18, 2005, 1:57 pm
NAT timeout June 6, 2006, 3:01 pm
Cisco SDM timeout April 19, 2007, 2:09 pm
timeout xlate BCP August 30, 2007, 11:28 am
FWSM - SAP timeout ? April 7, 2008, 3:26 pm
tftp timeout June 5, 2009, 9:58 pm
exec-timeout on line November 29, 2005, 11:44 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
